Question about Toys
How to operate the laser on a nerf c-015c
Put new batt. in the nerf gun and the laser does not work trying to find out how to work it
3 Suggested Answers
SOURCE: Nerf Vulcan Jammed Belt
If the belt is off the track towards the barrel, you can use a thin flat head screw driver to pry the cartridge away from the barrel to allow the belt to be pulled through. That worked for me.
Posted on Jan 07, 2010
SOURCE: when my nerf finder ex-3
me too ?? where the answer? plas help me..
Posted on Jan 30, 2011
Nerf gun lazer tag
i have the same problem and i noticed that when i go outdoor, the trigger will work again. i think it is something about interference by some sort of radiofrequenceis.
Nov 08, 2013 | Toys
Nerf pallets
Hehe, a little inter office competition. I would recommend you google your respective nerf gun with the question including AMMO for nerf gun. You'd be surprised. You can actually find it in BULK, so if you keep this to yourself, you can outlast your competitors..
Mar 22, 2013 | Toys
My 8 year old grandson brought home his ner n-strike raider CS-35 and without reading instructions promptly shoved the drum magazine directly into the main gun body without first inserting the drum...
unscrew the entier gun... all nerf guns are screwed together. you can practically cut the gun in half by unscrewing it. just make sure to put everything back how you found it. good luck to you.
Mar 29, 2011 | Nerf Toys
I have the Nerf Stampede ECS and I have brand new batteries in, the jam door is closed all the way, the clip is inserted and the on/off is switched to on. It is like the gun is getting no power.
1.) Check to see if the batteries are inserted right.
2.) If for some reason they aren't pressed up against the metal right, add metal between the batteries and the conductors to insure they are in full contact.
3.) Did you screw in the battery pack all the way? I'd check that.
4.) (The hard) look inside the gun (unscrew the plates) and find out if the circuit is 'complete'. One of the factors in the gun's circuit being complete (jam door, batteries, or clip) may not be working the proper way.
Good luck with your problem.
Also- are you sure they are brand new?
Try getting a full refund if you can, if all else fails.
Take a few pictures of the internals and email them to me at dluzzio@gmail.com. I'll try to see if I can come up with a probable answer.
Feb 23, 2011 | Hasbro Nerf N-Strike Stampede ECS Blaster
My Nerf Nite finder laser doesn't work, we have the batteries in and in the correct way. Any ideas please????
Here's one--
Although I am not completely familiar with the internals of the NERF NIGHTFINDER I have a good idea what is wrong.
Sometimes factories screw up, etc...
Lemme get to the point.
The circuit operating your light (if you don't know what that is look it up and find out) is probably not connected. Open up the laser and look online at what the internals look like. Make sure that the circuit is complete.
That's all, email me at dluzzio@gmail.com for more info on modding and nerf guns.
Jan 31, 2011 | Nerf Nite Finder
Nerf Vulcan won't auto-fire
I had the same problem with two guns out of the box. Turned out that the dividers in the battery tray kept the batteries from touching each other on some brands of batteries. Remove the dividers and should work. You can verify this by measuring the voltage on the two terminals of the battery pack.
Jan 04, 2010 | Nerf Toys
Nerf gun wont shoot its cocked and when i pull the trigger nothing happens
the relese mechanism came loose and i put the pin back in if anyone needs help ill be happy to help fix it
Sep 06, 2009 | Hasbro Nerf Dart Tag Strike Fire Two Pack
Both cordless drill batteries dead.
Your battery could say its good by just testing voltage,but when a load is put on it , its a different story. My dewalt batt. did the same thing I opened up the batt. case and there was 12 "C" sized batteries inside linked together with little metal strips. I bought 12 rechargeable "C" batts. and carefully drilled where the metal strips are soldered, changed out batt. and re solder. It's been over a year now and still drilling . Also you should do this one batt. at a time so you don't put one in the wrong order .
Mar 17, 2009 | Craftsman Drills
Toys Logo
279 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
