Question about Aurora Electronics AS1010TX Cross-cut Shredder
Shredder does not shred now...seems like the sensor is not picking up the paper that was put for shredding. What to do?
SOURCE: Shredder stops after about 10 minutes
spray the sheddred wheels with wd40 or any lubricant
Posted on Jan 26, 2008
sublimegreen
  • 65 Answers
SOURCE: jammed shredder
try shredding a old card, carefully but forcibly push the jammed plastic strip through the teeth.
might be faulty alignment of teeth, a factory defect!
Posted on May 11, 2008
  • 329 Answers
SOURCE: shredding
check door safty switch or is the bag or box full that has a switch also? just a suggestion.
Posted on Jun 24, 2008
SOURCE: Won't shut off after shredding.
I FIXED MINE!!! Hey folks same problem AS1018CD would not shut off. CURE: Take apart and clean electronic eye. PROCEDURE: 1. Unplug. 2.  Remove shredder and turn upside down. 3. Remove 6 phillips head screws on back of unit ( 1 is under sticker in middle peel back sticker to access screw. 4. Carefully separate unit. 5. Pull off shredder piece. It is a snug rubber grommet fit and just lifts off( gears everything comes off as one piece. 6. Electric Eye is exposed remove screw holding in and gently slide out and wipe clean. Do both sides. While apart clear all debris and wipe entire unit as clean as you can. Put gear assembly back on grommets. Put top and bottom back together. Replace screws. Plug in. FIXED :-)
Posted on Jul 11, 2008
SOURCE: Machine will not accept papers
The problem is the acrylic gear that runs directly off the motor. The threads on it are small, so it easily gets stripped. The engine can grab it better in reverse, since that side of the gears isn't rounded off. That gear needs to be replaced. I'm looking for a replacement short of exchanging it for a new one at target.
This post looks promising:
Link
Posted on Mar 29, 2009
My Staples 16 sheet Microcut shredder starts the shredding operation after I push the button and continues the shredding operation after I shred a paper. How can I get the shredding mechanism to stop...
It's a tedious process to clean it out. Most auto switch shredders use either a tiny little lever or an optical sensor in the paper feed slot. Usually removing the shred head, picking all the paper out and blasting all the dust out with air will clean it up. Then run a few sheets of paper with shredder lubricant (basically clean mineral oil) to oil the blades and it should be good to go again. Just be careful cleaning that cutting head. I've donated many drops of blood to office equipment over the years.
Mar 14, 2015 | Staples Office Equipment & Supplies
Why paper won't feed when shredder turns?
This may seem to simple but.......sometimes when you put too much oil into the blades through the top portion, the paper get drenched with oil and will not feed in. Plz try a few sheets or a thicker paper to push through. It may just be that simple. Good luck.
Plz N' Thnx, Bogie
Jul 11, 2014 | Fellowes DM8C Cross-Cut Shredder
Tried to clean some shredded paper in the shred area that was stuck, and now shredder won't work.
Disconnect the shredder Turn the top unit over to reveal the 'teeth' With a pair of needle-pointed pliers or cosmetic tweezers gently pick out the pieces of paper that you can see. You'll probably notice that there was some self-adhesive label material included (that seems to cause jamming more than staples!
Hope this helps.
Peter
Apr 20, 2011 | Dynex Cross-cut Shredder
When I put paper to shred ,all I get is motor noise but no shred
You probably have a stripped drive gear. let me know what brand shredder you have.
May 14, 2010 | Office Equipment & Supplies
ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
Aug 11, 2009 | Royal 1280MX Shredder
Paper shredder does not turn off. I have to open
I'm assuming that it automatically detects the presence of paper... .
By opening the drawer you're disabling it from the safety switch. (they dont want you to shred your fingers from the bottom) There is probably a small piece of paper holding the feed sensor down.
If you're confidant, unplug the unit and take apart the plastic cover. Do not remove anything inside. Look for the small switch between the blades which 'feels' the presence of paper. There is probably a small piece of paper wedged between the housing and the switch which would fool the unit into thinking it has paper that still needs to be shredded.
Carefully put your unit back together and happy shredding.
This may happen often, remember what you did!!!
Jul 30, 2009 | World Office Products Papermate PM-1550CD...
Need a sensor switch for fellows powershred 220. Won't sense paper.
The top sensors may be bad or even the main board that they are connected to is bad. Try cleaning them with a lightly moistened swab or compressed air. Fellowes will sell you the parts.
Apr 29, 2009 | Fellowes Powershred 220 Shredder
Shrededer motor remains on after shredding is complete
Blow out the sensors with some compressed air.(Computer Duster) they are likely covered in paper dust and the machine believes paper is present.
Please be sure to unplug the machine before attempting any sort of repairs
Hope this is of some help
Ed
Apr 20, 2009 | Fellowes SB-99Ci Shredder
Royal 10X confetti shredder
More than likely, there is a lot of paper debris jammed between the cutters and strippers. If you are handy, try the following.
Disconnect the power.
Disassemble the shredder from the lower bin to access the cutting head. Clear the head of all debris with a small screw driver or ice pick. Reassemble and oil the cutters with shredder oil, being careful not to get any oil on the optics. This should solve the sluggish problem. Oil on a regular basis, before every use.
Jan 06, 2009 | Royal 10X Shredder
SPL 1506X Shredder
Have you looked for hidden staples in the machine. Sometimes they can be hard to spot.
Aug 01, 2008 | Office Depot Ativa DQ60M Shredder
Aurora Electronics AS1010TX Cross-cut Shredder Logo
22 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
k24674
Jim Keysor
ka4iup
ka4iup
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
