Question about Electrolux Washing Machines
Washing machine ewf1495 no incoming water check tap and hose
Message comes up: "No incoming water, check tan and hose.
  • 183 Answers
SOURCE: cold water will not flow into machine
either the valveis faulty or the dispenser box is blocked, remove the internal hose from the valve anf see if you have full pressure at that point if yes box is blocked. Regards Advisor
Posted on Aug 22, 2007
  • 105 Answers
SOURCE: error message: water tap closed .
check water inlet valve clean of rubbish from water inlet hose
otherwise water inlet valve maybe faulty
Posted on Jan 02, 2008
SOURCE: Washing Machine keeps stopping and says "water tap closed?"
Wonderful!! Would you mind giving me a "problem solved" rating -- there should be icons on the screen to do that.
thanks...
Charlie
Posted on May 29, 2009
SOURCE: check hose error on electrolux wave touch washing machine
I'm sure nojallo1 has already fixed his but I just ran into the same problem and didn't find anything in my searches for a solution. The problem I had was the test cycle wasn't long enough to get hot water through my water lines so it could verify the hot and cold hoses were in the proper places. Solution: Turn the hot water on in all the sinks in your house until they have hot water running through them. This will prime your hot water line so it is full of hot water instead of cold water. Then run the install cycle again and it should be fine.
Posted on Jan 21, 2010
SOURCE: Problem : Water leaking out from under washing machine
NOTE. PLEASE UN-PLUG THE UNIT FROM THE ELECTRICITY SUPPLY BEFORE ATTEMPTING THE FOLLOWING JUST TO BE SAFE:-
Problem may be due to a blocked dispenser hole. Completely remove the dispenser unit and check for blockages in the hole where the water goes in. If you cant see anything immediate, take the top off. (Remove the 2 self tapping screws on the back holding the top on). Looking at the unit from the front. look inside where you took the top off and locate the rubber hose that connects the dispenser unit to the drum (it's a tight space, but if you look inside , front left you will see where the hose connects to the drum). Remove the hose and check for blockages. (The hose just pushes into the drum). Let me know. I had a similar problem and found that somebody had shoved a sock and pair of knickers down the water dispenser hole. This was also causing the machine to make a loud noise when spinning. Have you also checked the filter in the bottom right hand corner of the unit ? You have to remove the kick panel to get access to it.
Posted on Mar 01, 2010
My whirlpool duet washing machine is making s strange hum and appears that the water is entering slower. I've checked the water taps and don't see anything different than before. Any suggestions?
In addation to checking the actual taps,also check where the hoses connect to at the rear of the washer for sediment build up in the filter screens...also while hoses are disconnected from the washer while checking the screens also place hoses in bucket and turn on taps and see if good water flow is coming from the hoses/taps. If screens are clear and water flow through hoses is good the water inlet valve the hoses attach to would need to be replaced.
GENE
Sep 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Tap to washing machine is working fine, but water only trickles into the machine when filling. What can I do? Hoover washing machine model 200 MONZL
hi just read your posting.1st remove both inlet hoses from the taps and the machine.Check if there are little filters on the ends of the hoses,They could be blocked.Next check the filters on the water valves.The water valves are where the hoses connect to the machine.If the hose and water valve filters are clean then you will need to replace the water valve.Did you check how much water pressure is coming out of the taps?Please reply on how you got on and with additional information and I am sure I can help you on this problem.Looking forward to your reply.
May 20, 2011 | Hoover Washing Machines
H20 ERROR SPIN DRYING
The error indicates a problem with the incoming water supply.
Check for restricted or kinked inlet hose/s, check that tap/s are fully turned on and that you have adequate water pressure.
Mar 27, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Error code PF
The answer above is from Washerhelp. Here's the full diy help from Washerhelp regarding advice about a washing machine not taking in any water http://www.washerhelp.co.uk/diy-repair-help.html
Nov 04, 2009 | LG WM-2277HW Front Load Washer
No water is coming in the washer before the agitator starts
The above answer is copied from Washerhelp Please only use small quotes and link to the original source
Mar 29, 2009 | Whirlpool Washing Machines
Water flow very very slow though the pressure from main tap is fine
almost certainly not a fault with washer. check small filters in the fill hose and make sure hose not kinked
Jul 18, 2008 | LG WFT1071TP Top Load Washer
Error message: water tap closed .
Dec 08, 2007 | Bosch Axxis WFL 2060 Front Load Washer
E02 message
Error relates to water taking to long to get into machine. Check tap is open fully, water pressure is ok, hoses are not kinked. also check the small filters either end of the inlet hoses (inlet valves as well) as quite often they can clog up especialy on a new install. Regards
Jul 22, 2007 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
49 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
