Question about Dyson Flowcheck CRO1 Front Load Washer
How to repair a F 11 fault on a DYSON CR01 flow check
When turned on programmed and started. It fills with a little bit of water the drum does not turn, it empties and displays F11 fault notice.
  • John Harris Dec 03, 2008
    is f11 flow check or motor fault?
    Scholar:
  • 105 Answers
To Clear F11 Code after a power cut.
1, Power off at the machine. Do the next 4 steps within 3 seconds.
2, Press Temperature Button in.
3, Power on
4, Release temperature button
5, press Soil Type button
You will now hear the door lock release so you can get to your pants.
Diagnostic code is now displayed. You can switch the washer off and back on and the error code is clear. If you do this it will work.
Posted on Feb 10, 2009
3 Suggested Answers
  • 4 Answers
SOURCE: how to repair a F 11 fault on a DYSON CR01 flow check
f11 fault code is a problem with the main power board (could be blown fuse) or a blown board check the fuse the board is behind the back plate in the bottem right corner (looking from the back of the machine.(!unplug before you take apart!)
Posted on Sep 17, 2009
taran_2005
  • 10515 Answers
3, Power on
Thanks for using Fixya.
Posted on May 28, 2009
Dyson repair manual
Hi there, it's Jack at Dyson.
An F11 fault code means 'no motor action'. Unfortunately since 31st December 2012, we have been unable to support CR01 and CR02 washing machines with spare parts or servicing. In October 2012 proactively wrote to all CR01 and CR02 owners that we'd interacted with within the last 3 years to make them aware of this.
If you would like to discuss your concerns further with one of our experts, you can reach us on 0800 298 0298. Calls are free from UK landlines, and we're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends.
Aug 11, 2014 | Dyson Memory CRO1 Front Load Washer
Dyson contrarotatorwater sensor problem
Hi Kath, it's Jack at Dyson.
Unfortunately since 31st December 2012, we have been unable to support CR01 and CR02 washing machines with spare parts or servicing. In October 2012 we proactively wrote to all CR01 and CR02 owners that we'd interacted with within the last 3 years to make them aware of this.
Alternatively you may wish to check with local repair services for advice - please note, we cannot recommend or endorse specific repair companies.
Apr 10, 2014 | Dyson Memory CRO1 Front Load Washer
Dyson cr01 washing machine filling up with water but is not spinning
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Jun 25, 2011 | Dyson Memory CRO1 Front Load Washer
Water won't drain
Do the diagnostic test:
SHU 53 MODELS
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show “88′ when REGULAR WASH button is pressed and “8h” when Delay Start button is pressed.
To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault
1 = Aqua Sensor (“Sensotronic”) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), display will show fault code “4′ and unit will continually fill and drain where testing won’t be completed. If flow switch (e5) has failed (opened), display will show “0′, water won’t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code “8′ immediately and testing will end shortly after water has started circulating.
The dishwasher not draining is most probably faulty drain pump or drain hose is got bit loose.It has to be checked and confirmed
.You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 27, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
Dyson CR01 - How to clear F8 - Overfilling : Turn Off Water?
Don't panic, simply call our Helpline free on 0800 298 0298. One of our advisors will be able to assist you!
Kind regards
Darran
Dyson Customer Service
Apr 07, 2010 | Dyson Flowcheck CRO1 Front Load Washer
This morning got F11 fault on Dyson CR01 front loading machine, before that drum wouldnt turn and making grinding noises. Dyson have already removed the contra rotating cycle on this machine, is this...
may be the rear bearing has gone,my con/rota packed in and i took the drum out cleaned ,replaced, greesed, and alls well , if it is the rear bearing DON"T let them tell you its scrap if you are good at diy you can take the bearing out and fit new one, bit of a time comsumeing job
Mar 08, 2010 | Dyson Memory CRO1 Front Load Washer
I live in Portugal and my Dyson Cr01(bought in Belgium in 2002) has had problems every year since then. Dyson helped until now,by sending parts that I installed myself, but last week I got fault 11 and 15...
I have decided that was time to end my Dyson induced headaches, and i actually dismounted the machine into single components.
Every component except for the tub and drum assembly is in good working condition, and available for whoever needs them, for a very cheap price. From cables and panels to electrical and mechanical components, every part of my Dyson CR01 ready to ship, whoever is in need anything just get in touch with me to my gmail adress (luismanuelantunes@gmail.com) and we will arrange a good deal.
I want to get rid of all of it before the end of the year, if possible, for space reasons.
Dec 16, 2009 | Dyson Flowcheck CRO1 Front Load Washer
May 29, 2009 | Dyson Flowcheck CRO1 Front Load Washer
3, Power on
May 28, 2009 | Dyson Flowcheck CRO1 Front Load Washer
Dyson washing machine fault
Hi its Darran at Dyson. If you paid for a repair then there is a 12 month guarantee on any work that was carried out. To arrange a visit, please contact our Helpline on 0800 298 0298, between the hours of 7am - 10pm, 7 days a week.
Kind regards
Darran
Mar 26, 2008 | Dyson Flowcheck CRO1 Front Load Washer
Dyson Flowcheck CRO1 Front Load Washer Logo
1,224 people viewed this question
Top Dyson Washing Machines Experts
Starnley Johnwells
Starnley Johnwells
Gerry Harvey
Gerry Harvey
Are you a Dyson Washing Machine Expert? Answer questions, earn points and help others
