Question about Measuring Tools & Sensors
Need settings for culligan wg 844 water softener
BillB-SA
  • 2761 Answers
SOURCE: I NEED A SERVICE MANUAL FOR MY CULLIGAN WATER
Your best course of action is to contact Culligan here:
http://www.culligan-store.com/contact.asp
Posted on Nov 15, 2009
  • 175 Answers
SOURCE: No salt leaving Culligan softener during regen
It sounds like your salt in your salt compartment is stuck. Poor about a couple of gallons of hot water on top of your salt and see if that will break it up and fall down to the bottom of your salt container. Then regenerate your softener after about 3 hours have gone by. You should be back in business.
Posted on Nov 20, 2009
SOURCE: I have a culligan,gold series water softener.The
call your culligan service department. they will tell you what to look for.
Posted on Dec 22, 2009
ftw1952
  • 10319 Answers
SOURCE: Culligan 01010091 (mark 89) softener will not auto
clean the drainage filter then it will work correctly again
Posted on Mar 06, 2010
  • 8 Answers
SOURCE: water softener is inoperative and is displaying E1
Usually, an E1 error code means the circuit board is bad. Try unplugging the unit for 5 minutes. Upon plugging it back in, if it does not reset itself, that means you need a new board. It is really easy to replace ( just a few wires) and will cost around $160.
Posted on Jul 21, 2010
How do I back wash a culligan water softener
Back wash is done by a program on the softener . I would google your make and model and see if you can set this up or talk with a tech at culligan.
Feb 28, 2018 | Water Dispensing & Filtration
What causes culligan water softener tank to mak noise
The noise is normal during regeneration and draining.
You can manually set the regen clock to a different time.
There are Noises in My Culligan Water Softener Regeneration System Hunker
Dec 21, 2017 | Water Filters & Coolers
WHERE IS OUR SOFT WATER!? A few years back we had the Culligan man out to check our water because it was not soft (at the time, we had the Culligan Mark 100 model). After testing our water, the suggested...
The most frequent causes for intermittent hard water would be the gallon settings set too low causing the softener to run out of capacity or a meter that is not measuring the gallons. I would set the "hardness" setting on your culligan softener 30% higher than actual hardness. The softening resins they use are low in crosslink and very inefficient. Also make sure there are no toilets leaking causing hard water to "bleed" through softener. Iron filters require regular maintenance to clear oxidized iron from nozzles and the valve. Generally it is better to have the iron filter regenerate at least every 3 days to keep the bed refreshed.
RJ
Mar 01, 2012 | Culligan Sediment Water Filter
I need the opporating instructions for iron filter model WG 1054.
Here is a link for Culligan manual. This is a Medallist Iron Filter. You should also be able to pick one up at your local Culligan dealer.
RJ
Mar 28, 2011 | Culligan 34" Whole House Water Filter...
Need manual for a Culligan WG 844 - any suggestions?
You may find your manual at this web site.
www.culliganwater.com/residential/resources/timers_manuals.php.
I believe this is a Gold series softener.
RJ
Feb 12, 2011 | NRS Fleck 5600 - 64,000 Grain Timer Water...
How do i manually renerate culligan wg 844
To manually regenerate at 2am push regen button once. To regen immediately push regen button 2 times.
RJ
May 08, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Softener WG 844 needs flushing to remove dirt
If there is DIRT/SEDIMENT coming through system then you have a bigger problem. Well problems! Bypass the softener and run water into white bucket to see if it is coming from well. If so keep unit bypassed and call well man. The call Culligan to rebed softener.
RJ
Mar 23, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
I need a culligan n8 custom water conditioner manual
The Culligan N8 Custom and Estate 2 water softener systems are basically the same system. Here are a couple links for N8 manual to reset timer and Est 2 manual for other settings on systems that have "DIP" switches to set gallons settings.
http://www.culliganprowater.com/timer-reset.aspx
http://www.culliganwater.com/residential/resources/pdfs/reference/household_and_commercial_circuit_boards.pdf
RJ
Dec 27, 2009 | Culligan Sediment Water Filter
I NEED A SERVICE MANUAL FOR MY CULLIGAN WATER SOFTENER. MODEL# 01014556 SERIAL# 2903H0010
Nov 15, 2009 | Culligan Sediment Water Filter
Measuring Tools & Sensors Logo
223 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
