Question about GE Kitchen Ranges
Have a GE gas range model #JGSP23WEY3WW and after last cleaning cycle completed the oven door is locked and will not unlock, have unpluged power to unit for long time and also tried runing thru another cycle and still will not unlock. is there a way to bypass selfcleaning program and used as manual cleaning without affecting other programs on stoveand use oven
  • 87 Answers
SOURCE: Ge oven problem
Look for a microswitch connected to the lock mechanism at the back of the stove. The switch is probably broken.
Posted on Jun 08, 2007
fridgetech
  • 473 Answers
SOURCE: Ge range model #JSP42BK4BB
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
F0 or F7 Shorted Clear/Off Key due to membrane switch, control or connector Shorted key panel membrane switch; Check Electronic Range Control (ERC)
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
These are the codes for ge depending on the model.
Posted on Oct 26, 2007
Krazytech
  • 725 Answers
door lock is not work check wires motor and switchs.. you may have to replace the door lock
Posted on Jun 04, 2008
huuum
  • 750 Answers
SOURCE: ge oven profile spectra xl44
Hello ,
Welcome to fixya.
I'm Huuum and happy to assist you,
You asked, is there anyway to bypass the oven lock or bypass the self cleaning mode to get oven working?
Why do you need to do this?
If the door lock is stuck in closed position and preventing you from using the range?
You may free this by following this procedure.
Threat it like an error code.
This can reset the system.
Turn the breaker off to cut the power for 5 minutes.
Then restart the breaker and try the range.
It's like rebooting your computer when its acting strange!
Usually it corrects most problems!.
Or they are sometimes just a glitch.
If this does not remedy the problem, then the lock switch itself is bad and if you think you can bypass it then you may as well change it. Same labor!!.
Let me know how it works out.
Huuum
Please remember to leave a rating.
Posted on Sep 25, 2008
docjohn174
  • 943 Answers
SOURCE: Maytag gas range model MGR5750ADW
hi thanks for the question the part you need is the oven sensor witch is located , in the oven top left /looks like a pen replace that part the number i got is 1365 from repair clinic . thanks the appliance doc
Posted on Sep 28, 2008
What can i do to keep it unlocked and stop the beeping so i can use my oven
Search Results
    Why would my GE range display "unlock door" when the ...
    www.shopyourway.com > Manage My Life > Questions
    If it does, replace the latch assembly. If it continues to display "unlock door", the electronic oven control will need to be replaced. Note: The range will not go into ...
    Troubleshooting a GE Oven That Can Not Get Out of Locked ...
    motherhood.modernmom.com > Around the House > Home Appliances
    Self-cleaning GE ovens have a locking oven door as a safety feature. A self-cleaning cycle drastically ... The oven lock helps keep kids safe while the oven is hot.
    Oven is confused - GE unlockdoor lockeddoor ' Ask MetaFilter
    ask.metafilter.com/255547/Oven-is-confused
    Jan 18, 2014 - The saving grace is that unplugging the oven for 10 seconds and ...There are lots of hits on Google when searching for "GE oven unlock door message".... not lock, which meant that it would not do the self-cleaning cycle.
    How to Unlock a GE Oven: 9 Steps (with Pictures) - wikiHow
    www.wikihow.com > ... > Microwave Ovens
    wikiHowThe self-cleaning oven function is a time-saver and it increases the safety of ovencleaning. During the ... Luckily, there are several ways to unlock a GE oven. Ad ...
    Range - Oven Door Won't Unlock - GE Appliances
Jan 25, 2016 | Ovens
Gas range oven door with not open
Your self cleaning cycle is running. When self cleaning is running the door is automatically locked and will not unlock until the self cleaning cycle completes or self cleaning is turned off. You should be able to just turn off the self cleaning cycle and the door will unlock. Do not try to pry open the oven door. You will just damage the door and/or the catch.
Oct 15, 2014 | Amana ARGS7650SS Gas Kitchen Range
Whrilpool gas range Mod. GW395LEGD0 Serial IMJ0663181 OVEN DOOR LOCKED CAN NOT OPEN
If its a self cleaning model and you tried to stop it in the middle of the cleaning cycle the door will not unlock. Disconnect it from the power, let it stand a few hours then plug in. If not opening try running the self cleaning mode and let it finish completely. When it finishes after it cools down sufficiently the door lock should go off.
Aug 09, 2014 | Whirlpool GS460 Gas Kitchen Range
My Kenmore Range Model #95014 is displaying an E1 F5 error and will NOT unlock!
This error code has to do with the oven door lock assembly.
What is the complete model number listed on the unit? Look in the door area or the storage area on the bottom if you have one.
Dec 08, 2012 | Kenmore 95012 / 95014 Electric Kitchen...
We have a Five Star gas oven and attempted to use the self cleaning process to clean the oven. We started yesterday and it appeared to complete the cleaning cycle. This morning, however, the locking...
There are two reasons for the lock to remain locked. One: the thermostat/wiring failed. This results in the oven's control still believing that the oven is too hot (over 450 degrees) and thus will not unlock. The other possible problem is that the unlock mechanism failed.
You can try to unlock the oven manually. (For some ranges, you can do this from the back of the range.) Please add a comment with the model of the oven/range for more assistance.
I hope this gets you started on solving the problem.
Jul 06, 2017 | Five Star 48 in. TTN045 Gas Cooktop
The lock will not release after cleaning
This is GE's trouble shooting advise:
Range - Oven Door Won't Unlock After Self Clean
The Oven Door has been Locked Accidentally:
  • If no food or utensils are in oven, put it into a short self-clean cycle (1-2 hours).
  • If there is food in the oven, let the oven cool to room temperature and try to unlatch the door.
  • With electronic ranges there is a small chance that turning the circuit breaker off for a few minutes and turning it back on can release the door. latch to the "off"
  • Note: Do not force the latch at anytime!
Door Will Not Unlock After Cleaning:
On models with mechanical latches:
  • Once the oven is cool after a self-clean cycle (approximately 30-90 minutes), slide the latch over to the left.(Some older models have a latch release button that must be pushed in while sliding the latch over.)
Note: Some models with oven Set and Temperature knobs must have those knobs set in the Clean position before the latch can be moved to the left. If your door won't unlock, try turning those knobs back to Clean, then slide the latch over.
If the above suggestions do not work try the following to unlock your door:
  1. Disconnect power to range for 30 seconds.
  2. Reconnect power and see if door will unlatch.
  3. If door does not unlatch, and you do have food in the oven, wait for oven to cool completely and try again. If it still will not open you will need service.
  4. If door does not unlatch, and you do not have food in the oven, set the oven up to clean for 1-2 hours.
  5. Wait approximately 30 minutes and try to unlock the door.
  6. If the door unlocks, the control has reset itself and there should not be any other problems.
  7. If the door will not unlock or if you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
Note: Under no circumstances should you ever force the door or latch open.
May 17, 2010 | GE SCA2001FSS Advantium Electric Single...
Oven door after self clean cycle won't unlock
Both the oven" ON " light and " Clean " light will flash when the clean has finished . When the " clean " light flashes , slide the latch handle to the left as far as it will go , then turn the " OVEN SET " knob to " OFF " to open the door.
Mar 26, 2010 | GE Profile JGS968SHSS Gas Kitchen Range
VIKING STOVE DOOR IS LOCKED AND WILL NOT OPEN , STOVE WAS IN A SELF CLEANING MODE AND DOOR WON'T OPEN AFTER CYCLE COMPLETE
unplug or turn off breaker to stove for 10 minutes...then try to gently open.....the oven has to be completely cool before it will unlock....when cleaning is done release lock before turning cleaning off
Nov 28, 2009 | Viking VGSC306-4B Gas Kitchen Range
Ge xl44 after self clean cycle the door won't open and the display says "locked door" flashing.
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Sep 25, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I used the self cleaning selection on my Admiral Designer Series gas range. The oven went through the complete cycle of 3 hours. I unlocked the door and was able to open the oven door no problem. Later...
Hello Friends Creek.
Welcome to Fixya
You said, you used the self cleaning selection on my Admiral Designer Series gas range. The oven went through the complete cycle of 3 hours. You then unlocked the door and was able to open the oven door no problem. Later on you went to use the oven, pushed the bake button and the lock light would flash. And you could not get past that to get the oven to come on.
You did the right thing to turn off the electricity and then turned it back on.
Did you wait 5 minutes before turning the power back on?Or just flick it off and on?
You said, the lock light still blinked.
But did it lockup again?
Please send me the model and year of your range.
Huuum
Oct 02, 2008 | Kitchen Ranges
Kitchen Ranges Logo
151 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
