Question about AEG Washing Machines
AEG 1051 VI Sensortronic. Come up with Error 10 and does not finish cycle?
2 Suggested Answers
richroth
  • 9472 Answers
SOURCE: error code E20 on a AEG washer dryer
Ok if its only bring the E20 up on the drying side then this will be a blocked dryer condenser chamber.
To get at this you need to take the back half of the washer off and from there you will see a big plastic chamber going from the bottom up to the top.
Take this chamber off and give it a good clean out with a hose pipe.
Once this is clear refit it and the dryer should be back to normal from there.
Posted on Oct 15, 2012
I have a AEG Favorit 65011 VI dishwasher which stops in the middle of a programm an shows error ,60 that is not mentioned in the Users Manual. Can you please help me?
Fault in heating phase. Could be:
Heating element, wiring between heating element and power board,
power board (usually relay). Sometimes can help to resoldering (cold solder joint) or replaced relay on power board.
Dado
Mar 10, 2015 | AEG Dishwashers
In which way can i reset my dw AEG favorit F 65450 vi?
Hold and press the end cycle by 5 seconds, and try again. However you can disconnect the c.breaker by 5 seconds too. and try again.
Merry Christmas.
Dec 19, 2013 | AEG 24 in. Favorit 86050Vi Built-in...
Noisey AEG washing machine.
Hmm, could possibly be a relay or transformer going bad. Control panels are usually easy to remove, see if you can locate the noise. If it sounds like it is speed related to the drum turning you could have a more expensive problem related to a motor inverter if it has variable speed controls.
Apr 10, 2013 | Washing Machines
I have just had a repairer replace the mother board (mojo i think they call it - the main chip that controls all the programs) He charged me for a new one but I suspect it was just taken from another...
You will need to cross check with the dealership to establish this fact but if this is a new one it will have a valid bill with a warranty .so call up the authorised Sensortronic dealer in your city to confirm.
You can get the price of the new one for your model and then it will be confirmed. Now was the old one taken back or given back to you.... as he can have it repaired and replaced else where.if with minor errors.
Sep 30, 2010 | Washing Machines
My AEG Lavamat 62810 keeps coming up with an error code E60. What is this?
On my AEG Lavamat 62810, when I turn on a wash cycle a motor (pump?) runs for 10–20 seconds then the machine switches off, with no error message. When this happened a few weeks agao running a drain cycle seemed to cure it; now the same thing happens on spin/drain/rinse cycles too. Any ideas?
Aug 06, 2010 | AEG Washing Machines
I had a power cut just as I set the aeg oko lavamat sensortronic to wash. When it cam back on the duration is showing 4h and any attempt to change shows error.
try unplugging for about an hour that should reset the brain if it dont ur probably gonna have to change the brain out sorry
Feb 25, 2010 | Dryers
AEG Lavamat 74800 stops part way through the cycle - Error E50
I suggest trying this link. They will help you online.
https://www.justanswer.com/uk-appliance/23fl9-aeg-lavamat-74800-error-50-reported.html
Oct 28, 2017 | AEG Lavamat 72640 Front Load Washer
AEG Favorit dishwasher AAA shows Error code 10
Normally if washer doesnt complete cycle, its because the element has tripped the over temp.th/stat.(underneath), or is faulty. otherwise 1 of the 2 boards are faulty. Often the board at the bottom front left.(behind the kick panel.)is the issue. Roaches seem to accumulate on the bottom board and disrupt the circuit. If you have a mechanical timer, wiggle it side to side and note if there is a difference.
Feb 02, 2009 | AEG 24 in. Favorit 3A Free-standing...
AEG Washer dryer will not complete cycle
I ended up trying the machine on a few different cycles all of which failed to complete. Finally tried a 'Drying' only cycle and it emptied out quite alot of water which was odd. It now seems fine. guessing it was a blockage and a certain amount of water was backed up in the machine??? any clarity welcome.
Mar 24, 2008 | AEG Washing Machines
Washing Machines Logo
59 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
