Question about Humax FOXAT HDR DTV Receiver
Humax Foxsat HDR stuck on one channel and will not respond to remote or to buttons on front panel - can't even switch off
Checked remote batteries were ok and that remote is set to PVR. Tried using buttons on front panel - no response
  • G_Man1
    G_Man1 Oct 23, 2013
    Had same problem - took the box apart (3 screws for the top cover, 2 screws for front panel) & the main front panel connector (8 pin in line) was not fully 'clicked' in! Once pushed in fully, it's impossible to remove - front panel & remote work perfectly now!
SOURCE: lost all sound from foxsat hdr to tv,also ITV1
can not get any sound pvr-9300t
Posted on Dec 03, 2009
DerStrom
  • 103 Answers
SOURCE: my humax rm-f01 remote has stopped working. The
What are you trying to control with the remote? Try pressing the button on the remote that corresponds to the device you are trying to control first, and then try the remote again. I hope this helps, and good luck! Der Strom
Posted on Apr 05, 2010
  • 212 Answers
SOURCE: My Humax Duovisio PVR-9200T often freezes
Remove the Aerial.
Switch on or if it's frozen switch off at the mains and on again.
Press Menu
Installation and enter password - 0000
Select 'Default Setting' and OK
Select 'YES' and OK to restore all settings to factory default.
Confirm again to start loading, enter the password again and it will start scanning for channels but won't find any.
Replace the aerial and press OK to rescan and now it will find channels. On completion press SAVE then EXIT on your keypad.
You won't lose any saved programmes but you will have to re-schedule your recordings.
Posted on May 04, 2010
Hi all. Humax pvr-9200t all itv programes have ditital break up. all other chanels is good. aerial is new and is set up correctly. tried rescaning severly times to no avail. done all the obvious procedures. can any one help. Thanks
Posted on Jul 04, 2010
electrotech1
  • 1126 Answers
SOURCE: Our 5 day old Foxsat has locked and will not
Unplug the unit from the wall folr 40Min, and that will reset back to normal.
Posted on Aug 28, 2011
Humax foxsat HDR suck on BBC1 controller does not work though have unplugged dhanged batteries. sill no response
Check that the remote is working by pointing it at a digital camera. The camera will see the Infra Red signal when a button is pushed.
May 31, 2014 | Humax FOXAT HDR DTV Receiver
Humax cable and Channel connections
see the connections:God bless you
Jul 16, 2012 | Humax Televison & Video
Can I reset factory setting manually for Humax foxsat-hd
Have the remote tested--all shops have either a card tester (laminated card with a strip that lights when a remote is pointed and buttons pressed) or another style.
Some digital cameras in a very dim room will react in same way on the display screen when buttons are pressed with remote held to camera.
May 29, 2012 | Televison & Video
Humax foxsat hdr code to be used on sony rm-ed012
Hello
Four digit universal remote codes for Sony TV with Humax Foxsat remote are:
0037, 1505, 0036, 1925, 1825, 1751, 1685,
1651,1625, 1551, 1317, 1010, 0834, 0810,
0353, 0074,0011
Three digit codes are:
006, 301, 005, 446, 412, 393, 375,
360, 325, 255, 203, 185, 174, 058,
003
OK.
Jun 18, 2011 | Televison & Video
My Humax Foxsat is just out of guarantee & the remote has suddenly stopped working. We have changed the remote batteries & it is lighting up but doesn't interact with the foxsat box. The box works...
If you still have the owners manual i would recommend looking for the section on how to program the remote to the receiver. If the remote works with other accessories that would probably be it if not you can find universal remotes pretty cheap.
May 04, 2011 | Humax Televison & Video
Humax foxsat remote control problems went away on
Try factory reseting the remote control.
Feb 28, 2011 | Televison & Video
Can i download a manual/user guide for my foxsat-hdr recorder?
Yes. Try this manual;
www.humaxfoxsathdr.co.uk/.../Humax-Foxsat-HDR-User-Manual.pdf
Feb 21, 2011 | Humax Televison & Video
Humax Foxsat HDR sudden Remote Control failure..
Make sure you have pressed the "PVR" button at the top. If you have accidentally pressed on on the others TV, DVD or AUDIO then they will light up when you press another button signifying that the remote is trying to send a signal to them rather than the PVR...which is where you want it to go.
Nov 10, 2009 | Televison & Video
Setting humax foxsat hdr remote to control panasonic tx32lxd60 tv
Had the same problem with my panasonic - it would appear that none of the codes will actually turn the TV off because they need a longer signal to turn off. I eventually found that code 0650 works for mine - input the code as instructed in the manual and then selected OK - holding down the standby button on the humax controller then turns the TV off. Try all the codes and see which gives most control functions. Hope this helps.
Jan 01, 2009 | RCA 3-Device Universal Remote with...
Humax FOXAT HDR DTV Receiver Logo
418 people viewed this question
Top Humax Televison & Video Experts
Tony
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
