Canon i9900 Error reads as follows. Operator error. Press printer’s RESUME button. If this doesn’t clear the error, cancel printing and turn the printer off and then back on. I've cycled through this 12 or more times but it will not print. The light flashes Green and then 5 orange flashes and then repeats on a continuing basis.
  • Anonymous Mar 27, 2009
    exactly the same problem. What is the solution?
There is something inside the printer, i have the same problem and that was it, a paper or something blocking the headprint to run from right to left
Posted on May 28, 2009
I have changed all ink cartridges on my canon pixma ip4200 printer and it now doesn't work, the green and amber lights flash for 11 times and the cartridge carrier doesn't move. Please can someone advice...
From Canon Help Files.
Automatic Print Head alignment failed
Possible causes are as follows:
6128_image_6.gif A4 or Letter-sized paper is not loaded on the Auto Sheet Feeder.
Press the RESUME/CANCEL button on the printer to clear the error, then load one sheet of A4 or Letter-sized paper in the Auto Sheet Feeder.
Automatic print head alignment cannot be performed using paper from the Cassette. For automatic print head alignment, always load paper in the Auto Sheet Feeder.
6128_image_6.gif Print Head nozzles are clogged.
Press the RESUME/CANCEL button on the printer to clear the error, and then print out the nozzle check pattern to examine the print head condition.
For information on how to print a nozzle check pattern, see "Printing the Nozzle Check Pattern."
6128_image_6.gif The Paper Output Slot has been exposed to a strong light source preventing correct Print Head alignment.
Press the RESUME/CANCEL button to clear the error and move the printer to a darker location.
After carrying out the above measures, if the problem continues after aligning the Print Head again, press the RESUME/CANCEL button to clear the error, and then perform manual print head alignment. For details on manual print head alignment, see "Manual Print Head Alignment."
Sep 10, 2014 | Canon PIXMA Office Equipment & Supplies
Canon printer i865 Orange light blinks 5 times and the following message appears: "Operator error. Press printer's RESUME button. If this doesn't clear the error, cancel printing and turn the...
Dear Bruce,
Blinking in orange 5 times indicates that the print head of your printer is faulty. To ensure this you can compare by using another print head. But first,please remove the print head and check whether it is burnt. Some short circuitry may cause the problem. Thanks.
Source:
Printer Clinic
Dec 26, 2010 | Canon Office Equipment & Supplies
I keep getting this error Operator error. Press the printer's RESUME button. If this doesn't clear the error, cancel printing and turn the printer off and then on again.
Go to start... control panel
look for printer and devices or something of that sort till you find your printer model.
Double click on the printer... you should see a doucument queue that is waiting to be printed...
Right click on all pending jobs and say cancel or delete....
Jul 25, 2010 | Canon BubleJet i965 InkJet Printer
Flashing orange light 5 times followed by green
I am also having this problem, would love someone to give us a solution before I through it out the window.....
May 10, 2010 | Canon BubbleJet i560 InkJet Printer
My Canon i 560 s will not print and this is the error message, I followed instructions, no change, won't print, yellow light flashes ,"Operator error. Press the printer's RESUME button. If this doesn't...
Turn off your PC, turn off the printer. Open the printer and check for paper jams, push/pull the ink cartridge carrier left to right to ensure it also isn't jammed.
Only use a small amount of paper (10 sheets). Too much paper can sometimes block the feeder
Turn everything back on, try again.
Jul 02, 2009 | Canon BubbleJet i560 InkJet Printer
5 amber flashes
Operator error.
If this doesn't clear the error, cancel printing and turn the printer off and then back on.
When press Resume button, ip3000 not responed(not print)
Aug 07, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon S 520 doesn`t print
Two flashes: Out of paper, paper jam or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL
button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer
Four flashes: Empty ink tank
One of the ink tanks is empty. Replace it.
Six flashes: No print head installed
Install a print head.
Seven flashes: Defective print head
Remove and reinstall the print head.
Also, ensure that the protective tape has been removed. If reinstalling the print head
does not resolve the problem, replace it with a new one.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight
flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL
button to cancel the error so you can continue printing. Before the waste ink tank
becomes completely full, contact a Canon service representative to have the waste ink
tank replaced. Canon recommends to call for service as soon as this error occurs. Once
the waste ink tank becomes completely full, printing will be no longer
possible.
Oct 19, 2007 | Canon S520 InkJet Photo Printer
1,114 people viewed this question
jasbo
jasbo
