Question about Bosch 36V Litheon Drill/Driver With 2 Compact Batteries
36 volt dewalt drill chuck loosens in reverse
3 Suggested Answers
SOURCE: bosch 18volt brute force cordless drill how do i remove chuck
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
Posted on Jan 31, 2009
comax
  • 154 Answers
SOURCE: how to repairreplace brushes
There are black access panels on each side if the drill toward the rear. Remove the screw that holds them in, and remove the panel. This will expose the bruch holder, take a small screw driver and carefully remove the old brushes and replace them. Replace the panels.
Posted on Jan 26, 2010
Drill bit falls out , cannot use reverse to extract srews or bolts
are you installing the bit correctly. is the chuck defective... is the a name for the product. does it have a keyless chuck... are you inept ???
Oct 24, 2013 | Dewalt 18 Volt Compact Drill Kit
Cannot get the chuck to release the bit it is a dewalt and yes I am in reverse
On some of the DeWalt drills I have owned with keyless chucks, the chuck has a locking mechanism.
You have to grip the chuck and slide the outer sleeve forward to release the lock, then you can tighten or loosen the chuck.
Apr 14, 2011 | Drills
Drill chuck opens easily when in reverse
As it should ... exactly normal. To prevent, give it a little extra nudge when you tighten the chuck.
Thanks for your interest in this web site.
Jan 30, 2011 | Dewalt DC900KL Heavy - Duty 36 - Volt...
How do I change the drill bit?
you would hold chuck in a firm grasp as your hand around a pipe and hold tight,run drill in reverse and that should loosen the chuck and the bit. If its to tight for your hand get a pair of channel locks and hold chuck.
Jan 16, 2011 | Dewalt 18 Volt Compact Drill Kit
How do I change the drill bits and then tighten so the bits stay in the drill?
The chuck will not turn. So to loosen just turn the black plastic counter clockwise. The chuck will loosen. Or you can hold the black part on the chuck tight and put the drill in reverse and slowly squeeze the trigger and the chuck will loosen also. Do the opposite to put a new bit in. Put the drill in forward and hold the black part of the chuck and squeeze the trigger with the bit in place and it will tighten down on the bit.
Dec 16, 2010 | Dewalt 18 Volt Compact Drill Kit
The chuck on my Dewalt 18v hammer drill will not stay tight. it loosens whether I am in forward or reverse
the chuck on my dewalt 18 volts hammer drill will not stay tight it loosenss whether i am in forward or reverse
Oct 14, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt XRP chuck is locked tight on a 1/8'' bit. Can't loosen chuck.
take 2 pr of large channel locks and grab both sections of the chuck, on section in each channel lock, and use this to break it loose
Dec 05, 2009 | Dewalt 18 Volt Compact Drill Kit
How do you relase a drill bit from the chuck on a Dewalt cordless drill
opposite of the way you put it in. Grip the chuck and put the drill in reverse and turn the chuck. or hold on tight and pull the trigger.
Jun 07, 2009 | Dewalt 18 Volt Compact Drill Kit
My chuck is stuck
Your chuck is held onto the motor shaft by a screw located inside the chuck. This screw has loosened and requires tightening. This screw has reverse threads and in order to tighten it, you need to turn the screw in the opposite direction or in oither words, in the reverse direction.
Jul 08, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt dc920 repair instructions chuck
To remove the chuck on your drill follow the instructions for the type of drill chuck you have:
Instructions for removing a keyed chuck
Most reversing drills have a left hand threaded screw located inside the bottom of the chuck.
1.) If the unit has this screw place the chuck key, with the chuck facing toward you, into one of the holes on the right side of the chuck. Strike the key in a clockwise direction with a wooden mallet or similar object. This will loosen the screw inside the chuck.
2.) Open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
3.) With the chuck facing toward you place the key into one of the holes on the left side of the chuck. Using a wooden mallet or similar object, strike the key sharply in a counter-clockwise direction. This will loosen the chuck so that it may be unscrewed by hand.
There is no way to stop the motor from turning.
It may require several attempts to loosen the chuck
Instructions for removing a keyless chuck
1.) If the unit has this screw open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
2.) Insert the short end of a 1/4" or larger hex Allen wrench into the chuck and tighten. Facing the tool strike the long end of the hex wrench sharply counter clockwise as it is a standard right hand thread. This will loosen the chuck so that it may be unscrewed by hand.
Oct 15, 2007 | Dewalt 18 Volt Compact Drill Kit
Bosch 36V Litheon Drill/Driver With 2 Compact Batteries Logo
23 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
