Question about Microsoft Xbox 360 Console
Xbox 360 code 0002
I have replaced the x-clamp method, still had 3 rd's so been trying differant methods to sort it i've just tried unscrewing the heatsink untill it was loose then unplugged the fan and turned it on and left it on 2 red lights for 2 mins and rescrewing it bit by bit but all im getting now is 3 red lights and the code 0002. the copper has become scratched from the spring washers but that had already happened and didn't seem to make a differance
  • 70 Answers
Go here you will fix your Xbox in 2 hours dont mess around you may do more damage http://xbox360repaircenter.info They help me out a lot
Posted on Jan 09, 2009
I currently have the 0002 error code on my xbox 360... I have tried replacing everything. How can I fix this?
replace the C8U1 fuse... The "C"
it's around at the U8U1 on the bottom of the main board. Coordinate
"8U". If you try to remove this capacitor, the XBOX release for you
a nice code "0002". ;)
Thanks
www.1RepairStop.com
Sep 18, 2011 | Microsoft Xbox 360 Console
My xbox 360 keep restarting...and it has that red light on it...what should i do?
hi dear i was having problems with my xbox then i tried the xbox repair guide and i was able to solve my problems within 3 hours it has different methods to solve the problem hope it will help you out too the link is
May 27, 2011 | Microsoft Xbox 360 Console
Cure for xbox 360 fault e73
You have an overheating problem. The quickest and easiest and least risky way to fix it is to do an X-clamp fix. If you don't want to open your 360 DUE TO WARRENTY, then send it to microsoft. IF YOU HAVE NO WARRENTY, do the x clamp fix. Or you could try the towel trick. All these methods can be found on google.
Jul 23, 2010 | Microsoft Xbox 360 Console
How to fix my xbox 360 from 2 red lights
Towel Trick This part is more for reference. I don’t recommend doing this method.
I read about the towel trick before I found out about the X-Clamp replacement, so thought I would give it a try. At the time, it was either this or the heat gun trick, which seemed a bit more risky, so I went with the towel method.
This method basically involves wrapping your xbox 360 up in a towel to prevent any airflow from getting in, or out, of the xbox 360. This in turn forces the xbox to get really hot. You must leave the video plug attached, so that the xbox does not auto shut off. I left it running for about 15 minutes. It got pretty warm...
I’m not sure on the specifics, but I believe this just allows the solder on the cpu/gpu/ram to reflow, and fix the bad connections. As the x-clamp is still in use, this method generally will fail, and it did for me after about 2 days (and I wasn’t using it heavily).
Dec 14, 2009 | Microsoft Xbox 360 Console
E73 PERMANENT FIX
poop on it,that should fix it
Jun 26, 2009 | Microsoft Xbox 360 Pro System Console
Xbox 360 error code 0002
Hi sir
0002 Network Interface problem
May 31, 2009 | Microsoft Xbox 360 Console
Xbox 360
E74: AV cable error… There is a problem with the AV cable, try using a different AV cable. (this could also be a problem with the internal AV encoder chip)
Oct 20, 2008 | Microsoft Xbox 360 Console
Picture breaking up
Please try the following:
http://news.teamxbox.com/xbox/11131/Xbox-360-Cache-Clear-Code-Revealed/
I think I remember people saying they had that problem, and it was caused by an update to the game. This method should not delete any save games, key word SHOULD NOT.
Good luck, guys!
Jan 18, 2008 | Microsoft Xbox 360 Console
So far there is 1 major theory for what causes most of these errors is that the Ram, CPU, or GPU are not soldered properly to the mother board due either to poor manufacturing or excessive heat up and cool down cycles that stress, weaken and eventually break the soldered connection. Error code "0002" is a Network Interface problem. Since you have already replaced the clamps (I'm assuming your talking about the "X" clamps) there is only one other thing that might bring it back to life is re-heating the chips, sounds odd but has worked. Use a heat gun and slowly heat up the chip's, be careful not to overheat them. Try turning it on and see if anything changes, do this every so often until you get the results you need. REMEMBER< DO NOT OVERHEAT OR MELT THEM, USE CAUTION ANS COMMON SENSE. DO NOT attempt either of these if your console is still under warranty. If your console is still under warranty return it to the store where it was purchased or call MS to have it replaced.
If this doesn't work you may have to get a new one.
Jan 06, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
354 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
