Question about LG Washing Machines
Wm2501hva washer makes loud pulsing noise
Hot water inlet or valve seems to make a loud pulsating noise during the wash cycle. You can here this at the hot water heater.
  • 1462 Answers
SOURCE: Washing Machine fills slowly how to change inlet valve
switch off power remove top switch off water and remove hose. remove inside pipe from valve - usually held by just a spring clip remove electrical terminals valve is just held with a couple of screws usually - remove these and valve will come away. put back in same order
Posted on Jun 22, 2007
  • 99 Answers
SOURCE: roper washing machine mod# RAS8245EQ1
The problem is one of two parts. One is your water temperature switch or your hot water solinoid. To get to the back you must remove the hex screws on the back and then the panel is removeable.
Posted on Jan 27, 2008
  • 351 Answers
SOURCE: 7 kg intellowasher noise when in wash cycle
if its a direct drive remove the rotor and see if theres a loose magnet etc,hope this helps
Posted on Mar 04, 2008
  • 1294 Answers
SOURCE: GE washing machine overflows water fill will not shut off
You just have to replace the inlet valve, can do it yourself.
Posted on Jun 13, 2008
SOURCE: LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Posted on Sep 02, 2008
What can cause a washer to not fill with cold water during the wash cycle?
well it would seem these are the possibilities:
1. cold water not turned on
2. hose kinked
3. inlet valves not working
4. wiring issue
5. control board issue
oh and plugged inlet fill filter
good luck
Sep 02, 2015 | LG Washing Machines
Ariston li 700
follow the steps and fix it. God bless you
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Jul 06, 2013 | Dishwashers
Water is not running into the machine. This
There's no water at all If there's no water at all, make these checks: Is there water getting to the machine? Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way? If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown? Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Jan 02, 2010 | GE WBSR3140DW Top Load Washer
No water , when running, loud pulsating noise
Usally when there is no water comming in it is the water inlet valve. First turn selector swith to see if it is only hot or cold water that is the problem. Take the hoses off the back of the washer and make sure that when you turn the water on that there is lots of water pressure comming out of the hoses. If ok. its probably the water inlet valve. There are two screws holding the valve from the back. Access the valve. Remove the fill hose from the valve. Remove the four wires off the valve and put on the new valve. Reinstall fill hose and install valve with two self taping screws you took out. Put your hoses back on and your ready to go.
Dec 22, 2009 | Kenmore Washing Machines
Dishwasher makes grinding noise during wash cycle (after pre-wash). noise persists for 15-20 minutes. It seems as though the inlet valve doesn't open during this phase of the cycle. adding water to the...
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it. Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Nov 19, 2009 | KitchenAid Dishwashers
Washer makes a loud, pulsing, screeching noise with no spinning
With a manufacturing date of 7/15/97, your washing machine is clearly worn out.
Nov 07, 2017 | Whirlpool Washing Machines
GE Profile Harmony Washer has loud squeak when filling
Based on your description, it sounds like the water inlet valve is making noise, since you hear a squeaking noise during the filling of the washer. If it sounds like a constant squeak or squealing noise, i'd say it's caused by either the water inlet valve not being pulled all the way open, or because the water supply shut off valve at the house end isn't open all the way. Try opening the water supply shut off valves all the way open, (check to see that they are).
What is interesting is that the squeaking comes back during the draining of the water. Is this while the tub is spinning or only at the very end of the cycle? Again, it could be the water inlet valve, since the washer will "spray" some fresh water into the washer during the final spin cycle to help remove any soap residue, etc.
The part ins't cheap at around $123.00 for this valve, so unless it's really annoying you to no end, I'd wait for the valve to stop working before getting the repair done, unless you want to do the repair yourself, which isn't difficult, with some basic tools and time.
If you wait and let this go until it fails, you'll notice the water in the tub might not fill all the way for the level set, or the valve will start getting even more as it gets worse.
Here's a drawing that shows your washer and the part I'm talking about.
pd_0026_363_wh13x10017?$pddetailsth$ Part #WH13X10017 $123.49 @ searspartsdirect.com
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WPGT9360E0PL&productCategoryId=0153200&brandId=0432&modelName=WASHER&diagramPageId=00001&componentDescription=CONTROLS,%20BACKSPLASH%20&%20TOP%20PANEL&documentId=G0901083&backToLink=Return%20to%20Sub%20Components%20list
Hope you find this Very Helpful and best regards!
Aug 22, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
No water going to feed machine
There's no hot water Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine isn't working the way it used to--or should--try these tests:
  • Is the hot water turned on? If not, turn it on.
  • Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct.
  • Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
There's no cold water Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
There's no water at allIf there's no water at all, make these checks:
  • Is there water getting to the machine?
  • Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
  • If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown?
  • Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
  • From Repairclinic
    Oct 12, 2008 | Dishwashers
    Washing Machines Logo
    118 people viewed this question
    Top LG Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a LG Washing Machine Expert? Answer questions, earn points and help others
