Question about Kenmore Dishwashers
Kenmore dishwasher model # 16615
Hot water pipe to dishwasher vibrates severely when inlet valve to dishwasher is open. This does not happen when any other hot water valve in the house is opened. What do you think the problem might be?
catriver
  • 878 Answers
SOURCE: Kenmore dishwasher 665.1671590
Your inlet hose probably came loose on the left side of the dishwasher. If you pull the d/w out 6 inch. or so you will see the s-shaped hose going to the inlet port on the tub. Make sure it's not pinched or leaking..Catriver
Posted on Jun 07, 2006
  • 11 Answers
SOURCE: Bosch SHU4300 Water Fill Issue.
Similar problem for us turned out to be water accumulating in the tray which set off the float switch.  I vacuumed the water out and function returned to normal.  However, we are now facing a repairman's assertion the clay in our well clogged the water inlet systems necessitating $285 in repair parts and labor.
Posted on Oct 13, 2007
markevans
  • 148 Answers
SOURCE: Whirlpool Dishwasher Problem
the dishwasher will probably heat the water the rest of the way for you. depending on the specs and features.
hot water is not likely an issue with the dishwasher itself.
you could have cold water plumbed to the unit by mistake.
also, it could be that it is not fully pumping out, and the water going in is mixing with water in the sump.
try running it for few minutes and then pump it out. start a new cycle and see if you are getting hot water. if not, then at try to confirm that the unit is heating the water on its own. run it for about half a cycle and check the water temp again.
you do need hot water to clean in most units.
for certain this is a plumbing problem that is delivering cold water. and if its not heating, make sure that it should be per manufacturers specs, and call for repairs if its not heating the water.
good luck
mark
Posted on Dec 28, 2007
  • 1314 Answers
SOURCE: Connecting the hot water line to a new dishwasher.
use teflon tape on the elbow if you did the back it off put some more on it and stop when its snugged facing the right direction now ive torqued them things pretty tight my self they don't strip that easy
Posted on Feb 16, 2008
  • 1073 Answers
SOURCE: does dishwasher need hot
the dish washer need hot water coming into it to work right
Posted on Apr 25, 2008
My Kenmore Portable Dishwasher model number 665.17769K600 will not fill with water, I have to manually fill with water and it will then work. What could be causing this?
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly.
Hope this helps... Please post back for any further assistance.
Daniel
Mar 24, 2011 | Kenmore Dishwashers
I have an Electrolux ESI 6104x. Regularly just after starting the dishwasher as it starts to fill for the first time the water inlet cuts out. If you turn the water off at the mains disconnect the inlet...
Disconnect the fill pipe from the back of the machine and you should see a small mesh strainer in side the dishwashers inlet valve. Check that this is not dirty - to clean it pull out the strainer and rinse under the tap.
Dec 29, 2010 | Dishwashers
Water won't shut off, flooded kitchen
Check inlet water solenoid valve. May require cleaning. It's stuck and in open position or due to valve not getting seated properly inside valve body. Check incoming water pressure. If too high a pressure, this can happen.
It is advisable to close the inlet pipe **** after the days work.
May 28, 2010 | Whirlpool 24 in. GU940SCG Built-in...
THE UPPER TRY DOES NOT GET CLEAN, THE SPRAY ARM ON THE BOTTOM OF THE UPPER TRY AND THE SPRAYER AT THE TOP DO NOT TURN?THE WATER THAT COME SOUT AT THE BOTTOM IS WEAK ? WHY?
It could be that your dishwasher is not getting enough water. Let the water fill the dishwasher, set the spray arms in the same direction. Add a large pot of hot water and run the dishwasher. Open the door and check to see if the spray arms have moved. If they have moved, replace the water inlet valve.
Remove the 4 screws holding the lower kick panel. Remove kick panel. Locate the water inlet valve. This is the electrical valve where the water pipe hooks into the dishwasher. Shut off the water to the Dishwasher and electrical to the dishwasher. Disconect the 2 wire plug at the water inlet valve. Disconect the water supply to the dishwasher at the valve and disconect the rubber hose attached to the valve. Install new valve and test machine.
I hope this helps.
Jan 05, 2010 | Dishwashers
The water pipes rattle violently in the beginning of the cycle.
My Kenmore 16464 dishwasher caused a buzz in the water pipes at the start of the cycle that I thought was just water hammer. It turned out to be a bad water inlet valve on the dishwasher that has water hoses (inlet and outlet) attached plus has an electrical connector. It is located near the front left underneath the tub. I pulled the dishwaher out and replaced it and all is quiet again. - Jim
Nov 13, 2009 | Kenmore 24 in. 16462 / 16464 / 16469...
Leaks water from under dishwasher, some one suggested the fill valve assembly needs replacing???? kenmore
Hi
Thanks for using FixYa. If your dishwasher leaks, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
Lower rack
Spray arm
Spray arm support
Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 03, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Vibrating dishwasher pipes
a plumber needs to install a anti knock pipe at the valve under the sink ....this should stop the vibes ...should only cost about 50 -75 bucks ...depending on the per hour rate of the plumber
Jul 26, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Smeg dishwasher intermittenty opens and shuts off the water inlet
if you put clamps on the pipes this sound will stop.you may need to get to the pipes in the wall near the unit,also you maybe overloading the unit if water remains in unit.try less and see what happens.
Jul 24, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
GE Dishwasher Model # GSD2400N00WW Starts but I do not get any water. How to check for the problem? Thank You!
First check under the sink to see it the supply valve is on. Next listen to the unit when it should be filling, do you hear and spitting, or water sounds? If not the inlet valve may be bad or the inlet valve screen may just be full of debris from the hot water pipes (common problem) and needs to be cleaned. It is possible as well that the controller, or timer is not giving a signal for the valve to open but this is less likely.
Jul 21, 2009 | General Electric GSD2400NWW Built-in...
Need help with GE triton
That knocking noise is probably coming from your water line, and that happens when there is some kind of a ripple/wave effect when the water goes into your dishwasher (DW) thru the inlet/fill water valve. First turn your hot water valve off, underneath the sink coming from the wall and it usually is also going to your kitchen faucet. Then turn the electricity off by locating the breaker to the DW line and turning it off, or if it is plugged in an outlet under your sink, just unplug it. Then take the kick toe panel (panel with 2 or 4, 1/4" or philips screws) from the bottom of the dishwasher. You will then see the water hose, or could be a copper pipe, going into the valve (will have a selenoide, cylinder shape on top and have 2 wires plugged in to it). Unscrew the hose/pipe from the water valve and get a small wide bucket or pot and aim the hose/pipe to it. Slowly have someone open the water valve from under the sink while you hold it in the bucket/pot. If you hear the knocking again, you will need a plumber to check the pipes, hoses and water valve at your wall. If you don't here the knocking noise, just replace the dishwasher inlet/fill water valve part # 785330. http://www.repairclinic.com/0080.asp. Please post back.
Oct 07, 2006 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
