Question about SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue
I bought new simpletech 320gig hard drive of BOM #96200-41001-057 and lost the instruction and however i cant open it when connected
I plug it to the computer USB port and I tried to format it but no indication shown at all on the left corner to shown any sign
  • 8 Answers
SOURCE: SimpleTech hard drive not found by my computer
You might need to initialize the drive.
Right click on “My Computer” or “Computer” on Vista.
Select “Manage”
On the next screen select “Disk Management”
In the lower middle section you should be able to find your drive.
It will show up as Disk 1 or Disk 2….depending on how many drives you have in your computer.
If you click on the area that says Disk # you should get and option to “initialize drive”.
Also to the right it should show the allocation information for the drive. If it says “unallocated” then the drive needs to be partitioned.
Right click on the white box next to the drive listing.
Select the option “New Partition”
This will bring up the partition wizard and you will need to step through this process.
Select a primary partition.
On the next screen accept the maximum size it will provide.
On the next screen you assign a drive letter.
On the next screen you will do the format and accept the default settings.
The formatting will start and will be busy until it is complete.
You can monitor this from the disk management window.
Posted on Jun 05, 2008
fossilruins
  • 114 Answers
if you are running windows, then check the following:
go to control panel -> administrative tools -> computer management -> storage -> disk management.
you probably have a drive (located on the bottom right) that is listed with no drive letter, just assign it a drive letter and see if it comes back, if not, the drive is probably not initializing and you might have to either format it or replace it.
Posted on Jun 21, 2008
SOURCE: files on device become ''read only'' locked
i) i think this type of behaviours speciall due to presence of spware, virus in your system, initially to perform a full system scan on your disk and make sure that this not repeating in near future ...
ii) after do this try to change its mode(read only) by right-click on the folder or file u want to use and at the bottom you have to uncheck read only.........
Thanking youy
M. Sridhar
Posted on Dec 30, 2008
  • 336 Answers
SOURCE: I have a simpletech 1TB ext. hard drive BOM No.
You need to install the hard drive driver for the PC to recognize it. If you don't have one, just look in the internet for a free driver.
Regards,
Jeep Brainy
Posted on Aug 14, 2009
bob_computer
  • 3153 Answers
SOURCE: Computer won't recognize hard drive and I have a lot of data
I devised these simple steps that tend to remedy quite a few issues with most portable / external hard drives (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply
Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again.
If you checked and fixed anything there and still have issues carry on reading.
Go to your control panel and then administrative tools, select Computer Management.
Now select Disk Management and expand the window.
Your drive should be listed here, if not then you need to check your computer hardware has not got any issues before proceeding.
If your drive is listed and says healthy then right click on it an select Properties, click Tools and then Error Checking, Check now, tick the two boxes and then Start.
This will attempt to fix most minor / common errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed but did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. When it is done restart your computer and you should be good to go.
If you still have problems with the drive you might want to look at other areas.
Posted on Aug 23, 2009
I have a SimpleTech 120GB external hard drive. The USB connection port at the circuit board is broken. Can I buy a new plug-in circuit board and hard case for this unit?
Simpletechs have a three year warranty so if your drive is newer than that it is covered. You can go to www.simpletech.com (they are really hitachi drives) for details on warranty repair. If you are sure its not covered the case can be opened and inside you will find a SATA drive and you can buy a new SATA external enclosure for 19.99 at Radioshack. This includes the circuit board, cable, and new case.
Jun 05, 2010 | SimpleTech 120GB SIMPLEDRIVE PORTABLE USB...
Lost instruction booklet fo simpletech 250 ex hd
The drive is USB. To access the drive, plug it into a USB port of the computer.
The drive should be recognized by the computer.
I am not sure about Simpletech, however, most drives do not have an "instruction book".
What are you looking for in this documentation?
Dec 14, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
Regards,
Jeep Brainy
Aug 14, 2009 | SimpleTech 1TB SimpleDrive Pro External...
Simpletech 320GB BOM No.: 96300-41001-012 is new has never worked
The original power supply is "SB2D-020-1HA SIMPLETECH AC ADAPTER 12V 1.5A FOR EXTERNAL HARD DRIVE" . Just find a replacement with the correct size plug (center positive) that supplies 12v DC at 1.5amps (1500ma)
Mar 10, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
PC cant detect my Simpletech 500gb hard drive
well..you can 'see' it on the my computer, right? welll, then perhaps you'll check the usb cable, no?
Apr 03, 2008 | SimpleTech STORAGE, SIMPLETECH 500GB PIN...
SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue Logo
365 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
