Question about Bosch 24 in. SHU43 Built-in Dishwasher
Poor cleaning My Bosch dishwasher has stopped claning my dishes properly. They come out covered in a sediment.
  • Melania Oct 27, 2008
    There is a cloudy film left on dishware at completion of wash.
  • pinkcar Nov 27, 2008
    Yes i have the same problem I didn't like this dishwasher from the very start . but my men had to have it. i wash every thing almost befor i put them in and they never dry i will never bye a bosch again about 5 hundred
  • 38 Answers
Check the waste hose to see if it has gunk in it, it may not be emtying properly because of this and rinsing with dirty water
Posted on Oct 27, 2008
Dishes are not cleaned on the top level, the bottom level is OK, seem like the spray arm is not revolving
top spray arm will be blocked with sediment/food deposits etc remove clean thoroughly with hot soap water and shake/tap it on side of sink to dislodge deposits if the outermost holes are blocked the arm will not turn and you will get poor wash results.
Aug 17, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Hi- my dishwasher is not cleaning properly. It seems to get enough heat, there is no noise, etc. About a week ago, it just stopped cleaning. It will go through an entire cycle and the cups are always...
Probably a blocked spray arm (part that spins around). Remove each of the spray arms and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
Hope this helps
Jun 09, 2010 | Bosch SHU5315UC Dishwasher
I have maytag dishwasher leaves food residue
there is a filter on the inside bottom of the dishwasher check and clean it
May 16, 2010 | Maytag 24 in. MDBH970AWS Built-in...
Bottom rack pots and bowls dont get clean
Probably blocked spray arms is the cause of the unit not cleaning properly. Remove each spray arm (there are 3 in total) and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
Jan 26, 2010 | Bosch Dishwashers
Clogged dishwasher drain?
clean the filter, check the water inlet and outlets for blockages
Jun 29, 2009 | Bosch SHU9915UC Dishwasher
Dish washer not filling
I had the same problem. It was a clogged water inlet valve. Packed with sediment. Accessible from the bottom if you have the right tools. Just clean out and replace. Or the valve could be bad.
Apr 10, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Have very strong film build up on Bosch diswasher
two things that works well may sound funny but it works get yourself a packade of thang orange juice crystal dump it in the dishwasher let it run a cycle it will cleane the film of the interior anothe thing that works verry well is clr it is a mild acid you will find it at your homedeot or any hardware store trust me it works i have been using is for 30 years i am in the comercial dishwasher busness i see this every day thanks from gilles
Mar 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Not cleaning dishes
Our Bosch does a pretty good job of washing dishes. But we rinse most of the time. Not a hard rinse, but a rinse.
Are both spray bars rotating? You can test by seeing that the bars rotate easily by hand, and also by starting a cycle and opening the door real quick when you hear the spray hit the door.
Make sure the spray bar nozzles are all clear.
Has it ever done a good job of cleaning dishes?
DI you leave a heavy build-up of food on the dishes, and allow it to dry before washing?
Jan 26, 2009 | Bosch SHU5315UC Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
147 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
