Question about BenQ T905 19" LCD Monitor
Service manual for BENQ T905
Display shows a black screen
4 Suggested Answers
dragon_sun25
  • 107 Answers
SOURCE: benq t905 monitor blank
Fist check the fuse on the inverter board if it is blown replace it if not you need another inverter board as it has fried. But I looked and was unable to find a new/replacement inverter online so I wish you the best of luck
Posted on Dec 08, 2008
budmrtn
  • 11361 Answers
SOURCE: Benq T905 Monitor's green light turns on and then
Check for blown MOSFET IRFU9024N and transistors C5707/5706, and fuse in the inverter circuits section. Also look for bad caps with bulging top/seal. See some pictures of failed Dell monitors (BenQ made alot of monitors for Dell), http://s807.photobucket.com/home/budm/allalbums
Posted on Mar 14, 2010
  • 112 Answers
SOURCE: model is BENQ T905, AFTER
Make sure cable to the computer is properly connected and also your PC is in normal condition.
Posted on Aug 06, 2011
Model is BENQ T905, AFTER SWITCHING MONITOR ON, IT SAYS ' NO SIGNAL DETECTED ! ' AND GOES ON TO STANDBY
Aug 06, 2011 | BenQ T905 (Black, Silver) 19 inch LCD...
I received a benq t905 from my parents the other day and i just hooked it up to my computer and it won't work. everytime i press the on button it blinks green and makes a quiet beeping noise and then...
On rereading that post, I note that it shut itself off; perhaps it is time to open it up and fix it (if you're up on your electronics safety) per the _stinks_ note, below; you get to resolder some stuff running the backlight and replace a couple of standard capacitors and transistors, from what I can tell.
Things sound sort of normal for a driver being finicky about DVI modes; did the monitor driver not install, or just not bring visible results? You set your OS to 1280x1024 having booted to VESA (safe mode,) right? Normally when the resolution/sync is out of range, the status light is green constantly and you get a little note; maybe it's just too far out of the 56-76Hz video rate for that.
It's also possible that your backlight is failing (they fail short, as in too few ohms) or the monitor settings are set incompatibly...DMI or VGA cable? Does it stink?
Jul 25, 2011 | BenQ T905 (Black, Silver) 19 inch LCD...
Can not see picture very dark
You may want to read this:
http://www.badcaps.net/forum/showthread.php?t=6053
And also look at failed Dell monitors (made by BenQ)
Please post back what you find.
Apr 24, 2010 | BenQ T905 19" LCD Monitor
Benq T905 Monitor's green light turns on and then off
Mar 14, 2010 | BenQ T905 (Black, Silver) 19 inch LCD...
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
Benq t905 monitor blank
Dec 08, 2008 | BenQ T905 19" LCD Monitor
Charging my BenQ DC E800
sir..i hav digit camera benq dc E800.when i start my cam it will displayed as black screen without light..if i take photo or vdo ,after took it shows with dim light and mixed with violet colour..plzz say whats the reasons and it can solve..where i want to go
Aug 03, 2008 | BenQ Cameras
Secondary monitor
When you first switch on Does it show Benq?If not the inverter circuit has failed.If you are technically able you can try resoldering transistors on inverter board.If your display is black all of the time transistors could have failed as also related fuse etc.
And yes please check with BenQ Normally these have a 3 year warranty.
Mar 05, 2008 | BenQ FP757 Monitor
Projector only displays Black and White / No color images.
The problem is the color wheel. It may have broken or motor stopped on clear. Either way the image will remain unchanged just without color. It will need to be sent in for service. Not an unusual problem for BENQ. I have had 3 that have come apart after making a loud whirring sound. Good luck getting someone with BENQ to help they are horrible when it comes to service. Buyers beware!!!
Jul 27, 2007 | BenQ PB8240 Multimedia Projector
BenQ T905 19" LCD Monitor Logo
270 people viewed this question
Top BenQ Computers & Internet Experts
Tony
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
