Question about Kenmore Elite 21086
Same problem with washing machine you had in 07'
Was it the belt or the motor?
thanks,
stephaniejwheeler@hotmail.com
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Hello, information request (birth date)
The manufacture date is determined by the SERIAL NUMBER on the appliance. The serial number should be located along with the model number on a nameplate along the wash tub rim under the lid. Kenmore washers are manufactured by Whirlpool. The serial number format is explained in the following link:
http://www.fixya.com/support/r3576437-determining_the_age_of_your_whirlpool_ap
The second digit in the serial number will represent the YEAR in was manufactured. The first two NUMBERS following that second digit represents the WEEK (52 weeks in a year) that it was manufactured.
If you locate the serial number and still need assistance in how to detemine the age, post back and let me know. I hope you find this information helpful.
Posted on May 31, 2010
Testimonial: "Answered my question, Thank you, nice day."
Spin dry
I have washer Model # XQB60-91BF It do all functions eccept spinning when it comes on spinning drum does't rotate. I replaced drain pump but does't spin. Can you guide me about trouble.
Thanks. email: khansaleemuddin@hotmail.com
Jan 20, 2013 | Haier XQB60-91BF 1.92 cu.ft. Portable...
Tip
Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/07 error code on...
The error F/07 is shown on the display due to Motor Control Unit Error in the washing machine. The motor speed is not getting detected by the control board in the machine or there is a confirm short in the motor control unit.
This will Help.Good Luck.
on Mar 11, 2010 | Washing Machines
HEC 1050 I HAVE LOST MANUAL HOW DO I STOP FROM SPINNING AFTER WASH IF I AM OUT SO AS NOT TO CREASE WASHING RM.CRUTT@hotmail.co.uk
my hec 1050s had stopped turning, to fix this i could see the bushes couldnt get proper contact with the copper cylinder in the motor, first turn off at wall, turn machine on side, turn motor by pulling the belt, use a fine grade wet n dry sand paper to remove the black build up from the copper cylinder while turning motor by pulling on the belt and thats it job done and good luck
Mar 12, 2011 | Washing Machines
Can let me know how to go about changing the
hi joe i do these machines on a reg time almost every day.it easy to do the way you are doing it is the wrong way .so heres how to do just take top of the machine and put the belt on the small pully on the motor then half way round the drum wheel and turn it till its on make sure the belt is in middle of the pully if its not it will slip off i belive this is a hotpoint wma31 if belt keeeps comming off your bearings have gone it will need new bearing s good luck any more help just email me at marrathedolphin@hotmail.com
Mar 26, 2010 | Hotpoint WMA31 Front Load Washer
The drum wont rotate, is it belt driven from the motor, if so how do you get in to change? cant get lid off
take the back panel off to get to ure belt, but first put ure hand inside ure machine n spin the drum if there is no strain wen tryin t spin the drum n the drum feels very light to spin ure belt has snapped if there is abit of strain u will need ure motor brushes changing
Feb 03, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Washer fills no agitation spin cycle ok
It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
May 07, 2009 | Washing Machines
Maytag Mav2755AWW
hi tecate.
This can be a few things, either bearing,transmission, drivebelt or motor.
Start with the drive belt. Take it off and see if the drum when rotated makes the same squeak as befor when you apply a little pressure to the drum.
If it does not do it it can be the tension in the belt. Or the belt is gone HERE are drawings and partslist. You can also obtain the parts here
Jun 30, 2008 | Fisher and Paykel GWL11 Top Load Washer
Need to ask about Maytag 7600
You should reove the belt and check for roughness in the way the water pump bearings "feel". If they are tighter one way than the other you may have "string" or something wound inside the pump or bad bearings. also do thew same test on the motor it should spin free both directions also. And check the "thrust" the in and out play on both shafts. Lastly check the transmisssion mAIN DRIVE PULLY for true and streightness a warped or bent pulley could cause a noise problem but usually will do the same noise in either direction.
Mar 26, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Whirlpool top loading lsq9549l
your coupling is broken..this is a rubber and plastic peice that connects the motor and transmission.. a simple fix if you are handy
Feb 17, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
No spin cycle
Get the plug off the wall, open up behind & check what it is. Maybe the belt is off...........Only severe cyclones are catastrophic........
Dec 04, 2007 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
19 people viewed this question
Sal De
fordexpert
Robert Rankin
