Question about Daewoo Microwave Ovens
Daewoo MT1510W microwave oven shuts off
Oven shuts down completely (as if a circuit breaker was thrown) after running less than two minutes on the heat food cycle. The light that normally goes on, does not come on. When the oven shuts down, it takes about 5-10 minutes for it to cycle back on with a prompt. It's of absolutely no use since everything takes longer than the time it will stay on!
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Profile Advantium Wall Oven 240 volts 950 Watts
How long does it run before it fails? Does it look like the display is getting scrambled characters? I'm leaning toward a bad magnetron, but it may be more or less than that. If you can give more details and especially the actual full model number (as opposed to the model name Advantium 120) that would help. Thanks!
Posted on Oct 05, 2007
  • 17 Answers
SOURCE: GEJE2160 Stop Working
It probably blew the main power fuse in side the oven. This may have happen because of a failure in the microwave or a line voltage surge or what ever. Repalce the fuse and see if it work. be sure to unplug it before doing this, If this does not fix it then you have a failure in the oven some were.
good luck
Posted on May 17, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: kenmore microwave wont heat food
I would suspect you have a failed high voltage transformer or maybe magnetron.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find exploded views and part prices by entering your FULL model number here: http://www.searspartsdirect.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
SOURCE: Panasonic Model No. NN-S933BF Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
Posted on Oct 21, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: oven won't heat and shuts down after approx. 20 seconds
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Posted on Dec 18, 2008
My Kitchenaide KEMC378KSS0 Oven Microwave Combo shut down.
Is it possible the cord got knocked loose during the work?
The parts list with exploded views is here.
My site is MicrowaveControl.com so feel free to e-Mail me at pupista@gmail.com for details and free advice.
Sep 27, 2016 | Microwave Ovens
Runs 20 sec stops reads F1E5
Error Code/Message - Oven - F1 Error Code - F1 E5
Control displaying F1 E5:
There may be a problem with the Oven Control, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Oct 23, 2015 | KitchenAid KEMS309BSS Combination...
FMV152KWA microwave buzzes when not running
Missy Uhland Bauman,
I understand that you are hearing a buzzing noise from your microwave, even though the door is shut and and it is not running. I would suggest to give the appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back. If you are still hearing a buzzing sound, I suggest either contacting the manufacturer or your local authorized technician.
-Best Regards-
Jan 10, 2014 | Frigidaire FMT118E1B Microwave Oven
I have an over the range DAEWOO MT1510W Microwave i think the fuse blowed my manual doesn't show where it located at
The fuse probably is internal. It may be necessary to remove your OTR microwave to get access inside.
Jan 13, 2012 | Daewoo Microwave Ovens
GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Jun 19, 2010 | GE JVM1441 Microwave Oven
Mt1510w will only run 1min&20 sec. then shuts power off
I would say that the magnetron is overheating and its thermostat is being tripped, which will interrupt all power until it cools down a few minutes later.
It may be failing because the internal cooling fan is not running, because the filter is clogged, or because the magnetron is failing.
If you cooktop lights recently failed (wouldn't come on, wouldn't shut off, stayed on bright or dim, etc.) then the surge that caused that failure may have interrupted the power circuit to the internal cooling fan.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
It is vital that the cooling fan runs, or the magnetron will be destroyed.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jan 28, 2010 | Daewoo Microwave Ovens
Turn table broke
You can visit Daewoo online or call them at 877-393-7823 or 973-249-3448 to find parts.
Feb 02, 2009 | Daewoo KOR-630A Microwave Oven
Microwave shuts off during use
These units have an issue with the microwave generator overheating. When this happens the unit shuts down to prevent damage to it. When it cools off, it comes back on. That part called a magnetron is not listed to for purchase.
Nov 27, 2017 | Daewoo KOR-630A Microwave Oven
Jenn-air model jmc7000
Can someone tell me where i can find fuse for microwave convection/grill oven 5kv 700ma There is a other no on the fuse TUV5m41GF
Aug 29, 2006 | Jenn-Air JMC7000 Microwave Oven
Microwave Ovens Logo
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Ian Summerfield
Ian Summerfield
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
