Question about Samsung WF337AA Front Load Washer
Won't spin heavy loads
My washer is only six months old...the problem is there are no service companies in my area (suburb of seattle!!) who will come fix it. samsung refunded my money after much hassle, but i still have a non-spinning washer. it gets to 10 or 11 minutes and sits there swishing back and forth. there is no error message, just the timer showing. help!
  • 3 more comments
  • cuykendall Oct 23, 2008
    thank you so much...i will order the part and have my husband put it in...he is very mechanical but didn't know where to begin on this high-tech washer. you were certainly more helpful than samsung, i will never buy another of their products. i'll let you know if it works!!
    i hate to be a pain but i tracked down parts for this model, unfortunately sears didn't carry them for some reason. anyway, there are 251 (!!) parts available, down to the last screw. the only thing i can guess is i need an ASSY PCB PARTS (M); F (around $90), or an ASSY-PCB PARTS; FRONT (around $100). any idea how i can tell?? thank you!
    i found the parts but like i said there are 251 to choose from. any idea which one i should order?
    ASSY PCB PARTS (M); F (around $90), or an ASSY-PCB PARTS; FRONT (around $100). thank you!
  • cuykendall Nov 21, 2008
    Mike, hi again, we got the front motor control board and my husband popped it in, no big deal. we threw in a heavy sweatshirt and waited feverishly to see what would happen. tragedy....there it sat, at 10 minutes, swishing back and forth, eternally. Any other ideas? No clue on the screen, nothing but the 10 and the swishing back and forth.
  • cuykendall Nov 24, 2008
    No..we put in the new board and it did the exact same thing. So frustrating! We may have found a work around though, in reading the (skinny) manual it said it would not do small loads. Now, I've done plenty of small loads, but they must have been light enough to get away with. Just for the heck of it I threw in the heavy sweatshirt we'd been using for a test, which wouldn't spin, then I loaded up the machine with a couple towels, jeans, tshirts, and let it go. I'll be darned if the damn thing didn't go through the whole cycle. We don't know why we never got any error message like we should or anything else but we're just going to try it for a while with full loads if we're doing something heavy like a bathmat and see if it works. At this point it's either that or go buy a new washer. We've had it with this one! Good luck, fellow Samsung owner.
We have the same problem with our Samsung washer, has been in the shop and had that board relaced, got it home, first wash same old problem, no spin. Did you find a solution?
Cory
Posted on Nov 24, 2008
    Genius:
  • 1,122 Answers
YOUR PC MOTOR CONTROL BOARD THAT TURNS THE MOTOR FROM WASH TO HIGH SPEED SPIN HAS FAILED,YOU CAN GO TO SEARS .COM CLICK ON PARTS PUT YOUR MODEL NUMBER IN AND YOU BUY AND SEE ALL PARTS AND WHERE THEY GO ON YOUR WASHER,LET ME KNOW HOW YOU DO-MIKE
Posted on Oct 22, 2008
  • 1 more comment
  • MIKE major Oct 23, 2008
    also try repair clinic .com- for parts-mike
    i'am not sure but most of the front loader have the motor control board inside the front bottom,so i would guess,the front board-mike
  • MIKE major Nov 21, 2008
    is your door lock light coming on?is there a main pc control board?if so check for burnt spots on the resistors,did you check the old motor control board for burnt spot?
Whirlpool duet fw95hedco washer won't spin at max speed & leaves all clothes wet. No error codes during tech diagnostic visit. Washer only 18 months old.
Possible Defective washer transmission. Do you overload the washer with heavy items like towels or blue jeans very often? That can cause early failure.
Feb 16, 2017 | Whirlpool Washing Machines
Washer will not start at all less then 2 months old! Stop working after a extra heavy load
unplug it,try spinning the tub by hand,if the tub turns try it again with smaller load.
Dec 21, 2012 | Washing Machines
Frigidaire code EAE call service
you must call to the company for warranty. otherwise you must lost the warranty.Normally the instruction manual appear the code error for fix it.
God bless you
Jun 19, 2012 | Frigidaire ATF6000ES Front Load Washer
H2low whirlpool top load washer turns on, fills with water for a second and stops...keeps making a sound on the sensing mode but does not get to wash mode to continue washing.
if the washer is only one month old contact whirlpool and they will give you a service company in your area to contact and it the repair will be free of charge as long as the problem is with the washer and not something that you are doing wrong or something wrong with the way that it is installed, the unit is under mfg. warrnty for one year from date of purchase.
things to check before calling would be, water connections correct? hot to hot cold to cold. are both the hot and cold water turned on?
kinked lines?
i would call a whirlpool certified repair company, they will send a guy out and if its broken they will fix it for free.
Nov 27, 2011 | Whirlpool Washing Machines
The spinning thing won't spin all of a sudden. The washer is making a lot of noise and will drain but won't spin. How do you take the back off?
The motor has a double pole on it. The pump is driven on one side of the motor. The basket is driven on the other end of the motor. So if the water is pumped out then the lid switch is fine. What you have is a broken drive coupler. Usually breaks on a heavy load like rugs or quilts. Low water on a heavy load can break it too. Or simply old age.
Video:
Repair manual and more photos HERE
May 07, 2011 | Whirlpool LSN2000LW Washer
Have a 6 mounth old top loader washer GE and the spin will not work
A six month old washer should be under warranty. Did you register the product and do you have your receipt? I would call the place where you purchased it first and see what they have to say.
Dec 16, 2010 | GE WBSR3140DW Top Load Washer
NOT GOING INTO FULL SPIN
Check the water pump and see if anything is clogging it up.
May 01, 2009 | Washing Machines
It appears your main control board has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 03, 2009 | Washing Machines
Looking for LG LMV1915NV service company in Seattle area
Television & Video Sales & Service 525 Dexter North, Seattle, WA 98105 (206) 784-4178 A M Stereo & Video 12509 Lake City Way Northeast, Seattle, WA 98125 (206) 364-5904 AAT Television 3429 4th Avenue South, Seattle, WA 98134 (206) 447-2288 AC TV & Video Sales & Service Mobile Svc & Installations - Authorized Dealer (206) 784-4178 (360) 643-3254 (877) 764-5539 (toll-free) Email: kenactvvideo.com Adams TV 4411 Fremont Avenue North, Seattle, WA 98103 (206) 632-4211 (206) 632-1280 (fax)
Oct 14, 2006 | LG LMV1915NV 1000 Watts Microwave Oven
Samsung WF337AA Front Load Washer Logo
342 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
