Question about Health & Beauty
Walgreens Digital Blood Pressure Monitor Model 83
Walgreens is the "Brand" Says on back mfg for Walgreen Co., Deerfield, IL 60015 Made in China. This is Walgreens Model #83 Digital BP Monitor - I need the user manual/instructions please!
SOURCE: How to clear mem of prev checks on Walgreen wrist Homedic
How can I check that my Homedics Thera P is giving me an accurate blood pressure reading. My blood pressure appears to be jumping all around during the day and then spikes during the night. I am going to my doctor but I don't know if my readings are correct. I will replace the batteries today. My device is about two years old and I have never replaced the batteries. Any ideas?
Posted on Jul 22, 2009
Max J
  • 22 Answers
SOURCE: Blood pressure reading 150/76. Manual Blood pressure 130/72
A monitor using Hg is only a valid monitor reading. Most electronic devices produce approximate results and are mostly good for taking several readings daily and obtaining a mean daily BP. Device calibration appears to be not accessible to the the user.Also, depending on age & condition of your dad, sequential reading must take place after elapse of enough time for circulation to be at steady state in the arm again, or if you immediately after a measurement make another, even with the same monitor you will obtain a different result.
Posted on Sep 07, 2009
SOURCE: Walgreens HD303 Blood Pressure Monitor error 3
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Posted on Jan 19, 2011
SOURCE: i have a walgreens by homedics bpa-430wgn blood
CA means CALIBRATION required and you must send it in.
Posted on Apr 03, 2011
  • 4736 Answers
SOURCE: Can't find the instruction book
You can obtain one by calling the manufacturer's (HoMedics) Customer Service Dept 800-466-3342. Mon - Fri, 8:30am - 5pm ET.
Posted on Apr 14, 2011
Blood pressure cuff does not inflate
If it is an older device then rubber seals may have dried out. If not in warranty and you are capable then take it apart and use olive oil on the rubbers. If it does not even pump then get a replacement.
Aug 01, 2016 | Walgreens Health & Beauty
Directions to use Model 83 Walgreens digital blood pressure monitor
The Walgreens Model 83 was not made by Homedics, but in 1999 by Omron at http://www.omronhealthcare.com
I called the 800-634-4350 number on the back of the device, and got someone who immediately emailed me the instruction manual! Now that is unusually good service for this day-and-age.
I would have posted the PDF here, but this site doesn't allow PDF uploads.
Feb 09, 2012 | Walgreens Blood Pressure And Pulse Monitor
My Walgreens BA-616W Blood Pressure Monitor stopped functioning as a blood pressure reader. The batteries are fine; the LCD screen activates itself; the process of pumping up the cuff and slowly...
Most of the Walgreen's Automatic BP Monitors are manufactured by HoMedics. I'm not sure yours is or isn't. Try to locate your Owner's Manual, as it will tell you who manufactured it. Most have a 5 year limited warranty, as long as you have your Proof of Purchase.
To contact HoMedics Customer Support, call 1-800-466-3342.
I hope this helps you and thanks for choosing FixYa.
Aug 08, 2011 | Health & Beauty
Need Owners Manual for UB-322 Cuff Blood Pressure
Walgreens stocks and sells this monitor. Simply go to your closest Walgreens, speak to the pharmacist and I'm sure they'd be happy to make you a copy of the Owners Manual from one on the shelf.
Feb 25, 2011 | Lifesource Digital Wrist Blood Pressure...
How I can test the accuracy of the Wlagreen blood pressure monitor
If you don't have highly accurate static pressure meter and BPM simulator you are not able to fully test the accuracy of a BPM. However, the simple way to test it is use the same human body to compare the Dia. & Sys. result you got from this walgreen mahine and the traditional manual mercury type BPM.
Jan 11, 2011 | Walgreens Blood Pressure And Pulse Monitor
I have a HD502 Walgreen Digital Blood Pressure Monitor and I cannot get a reading after inflation of the bulb. The monitor blinks and makes noises and then the Err1, Err4 or Err8 message appears.
Hi, I'm sorry I don't have a solution for you. I have the same monitor but I'm actually looking for the "t" plastic part that unite the hoses together and connects into the actual monitor. Not sure if you got it to fix it but if you still have ir, are interested in selling that little piece to me? I would be greatly appreciate it. Thanks
Sep 21, 2010 | Walgreens Blood Pressure And Pulse Monitor
Need instruction manual
Homedics makes several units that are virtually identical to the Walgreen counterparts. Why not try the Homedics web site? It has a support section. Be sure to list your model number as there are several wrist cuff models. If the web site doesn't help, either call Homedics or try a web search by listing your model number followed by 'manual'. I would have tried to find the manual for you but I don't know the model number. Good luck.
Jul 12, 2009 | Walgreens By HoMedics Automatic Wrist...
Health & Beauty Logo
293 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
