Question about Garden
Karcher KB3030 Pressure Washer
Died at 13 months light use. Not fuse or socket.
  • Anonymous Mar 29, 2014
    When switching on the KB3030 water comes out of the on/off switch and from the bottom of the machine
  • 92 Answers
Dear doc doz,
Most probably you have the spill valve stuck in a position that keeps the machine off. This could happen for various reasons. It could get stuck by using plenty detergents or chemicals, without rinsing the machine afterwards. It could happen by leaving the machine under pressure for a long time. Most probably (with all respect) you used to store the machine when not in use, with the pressure still in the system. To fix this problem the machine has to be opened. When you come to the spill valve, you can bypass the micro switch and if the machine works, then it is the spill valve. Most probably it is the spill valve and you have not much expencies to fix the machine. If you do not know how to fix it yourself, I suggest that you take it to an expirienced technician.
Regards,
MG.
Posted on Nov 05, 2008
  • Martin Grech Nov 05, 2008
    Dear doc doz,
    I wish to add that there were cases that the electrical supply wire got broken along the way from the plug to the machine. Many electrical wires like to break at the machine end. Also another probability could be a damaged switch.
    These are all inexpensive problems to fix. And in my opinion worth fixing, because the pump side of the machine should still be in a good condition.
    Regards,
    MG.
Karcher pressure washer doesn't work
it;s normally a switch interrupter must replace with actual with for motor protection.
Aug 14, 2014 | Karcher Garden
I have no pressure and the pump surges when i release the trigger on my electric karcher modle k 2.360
If you have a Karcher then you should always post your machines barcode.
Because you have the low pressure and pulse this will be the valve block. Your machine has 3 piston and each has 2 valves (inlet and outlet). Because you dont have the barcode, i cant be sure if you will buy a valve kit of 6 valves or a pre-assembled manifold block.
it could be this machine and spares :
http://www.sparesgiant.com/cleaning-equipment/pressure-washers/karcher/k-series-parts/k2-range/k2-36m16724300/
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Sep 01, 2013 | Karcher K238CCK 1600 PSI 13 GPM Electric...
My Karcher pulses when on standby,stops when i use the trigger,but it also seems to have lost pressure.Is less than 6 months old but have lost receipt!
Is there a leak from the bottom ?
If so Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A design weakness.. A New Manifold Complete Replacement approx. $61.03.
If not you may replace the Pump Manifold Housing from Karcher, or locate a local Karcher Service Center.
If under 1 year old, and you can find a receipt,Karcher will replace the entire Pressure Washer under warranty.
May 03, 2010 | Karcher K 5.85 M Electric Pressure Washer
Clean and unloader valve on Karcher hd3500 pressure washer -intermittent pressure on and off. Cleaned inlet screen. Think unloader valve is is under pressure knob? Will cleaning help?
Hi:
Cleaning it is not enough. You need to make sure the o-rings are in good shape and grease it with a very very good waterproof grease. Here is a schematic of the pump. The unloader is parts 7 to 13 on D-2
Sep 08, 2009 | Karcher Garden
I started working with the Karcher KB4040 pressure washer and all was well for 1-2mins, then it sputered a bit and all power died. All hoses were still attached properly, it hadn't blown a fuse in my house...
if the water is in anyway impeded, like kink in hose the unit turns off and goes into protection mode. That it it shuts down for a pewriod of time depending on how hot it may have got.
When its rested try it again ensuring you definitely have water flow.If the solenoid has failed it costs about !60-200 to fix as they replace all seals regardless
Jul 22, 2009 | Karcher 1750 psi Electric Pressure Washer
Power washer just died
hi. you will need to go inside the machine to have a look, but it might just be a micro switch on the bypass valve stuck.
you can not miss it, there is a wire going to it, just unclip and check with a meter when pressing the little switch in and out.
Apr 21, 2009 | Karcher K2.26 Electric Power Washer
Losing pressure somewhere
Hi, I work in the italian factory of Karcher. In my opinion the problem is caused by the breaking of the collector. This is a black component of plastic where is inserted the detergent suction valve and the safety valve. To replace this component you have to go in a repair center Karcher.
Nov 24, 2008 | Karcher 1750 psi Electric Pressure Washer
Pressure washer karcher
Sounds as simple a fix as " The Fuse Has Blown "
Check the fuse in the plug, and it,s Rating.
I,d assume this should be rated at 13 AMPs.
If the fuse is 3-5 amps it,s under-rated.
You should get it tested out if your not electrical minded, you may have a short circuit. live/earth et.c.
hope this helps.
Mike @ Compurepair.
Mar 26, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
1,060 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
