Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
1999 harley davison
How do i adjust dna chrome shocks on 1999 harley flht
  • 216 Answers
Are those air shocks ?
Posted on Oct 24, 2008
How do i put oil in rear shocks on 1985 harley electra
Hi Anonymous, the rear hydraulic shocks are sealed units, sorry
Apr 08, 2014 | 2002 Harley Davidson FLHT Electra Glide...
Are All Harley Davidson Touring Shocks Interchangeable?
Easy to tell. Measure shock length, also mounts must be same. Such as eye on each end or clevis.
Nov 17, 2013 | Motorcycles
How to remove starter for a 1999 harley davison night train
Hi Anonymous, it's too bad you can't find the very first and best tool you ever bought for your Harley Davidson. Despair not, for a mere $6.50 you may be able to download another one from the website below and good luck. Harley Davidson Manuals Mark Workshop
Jan 22, 2013 | 2000 Harley Davidson FXSTB Night Train
2005 flht wont shift into 1st
Hi Anonymous, it's either a clutch adjustment issue or a transmission shifting problem, shifter pawl, shifter cam or follower, shifter fork. The websites below will help guide you through these procedures:
How To Properly Adjust The Clutch Clutch Cable Harley Davidson
tony encalade harley trans shift cam avi
Good luck
Jul 29, 2012 | 2005 Harley Davidson FLHTC - FLHTCI...
I want install new chrome shock covers on my harley shocks,need to know how to remove old shock covers.
Normaly to remove these covers you have to set the spring at its lowest tension, compress the spring and remove the collets from the top of the shock that fit inside the chrome cover, if your shock has no collets you will have to push down on the chrome cover to gain accsess to the lock nut securing the mounting eye to the shock on the damper rod, slacken this and the top will unsrew from the shock alowing removal of the chrome shroud you refere to, hope this helps, paul
Jun 05, 2011 | Harley Davidson FLHT Electra Glide...
Radio Harley FLHT 2005. The sound of the radio
Are you saying the radio gets louder as you go faster? If so, it is supposed to do that, and it is adjustable.
Jun 01, 2010 | 2003 Harley Davidson FLHT Electra Glide...
I'm trying to find the PSI in rear shock for 2001 HD FLH
rear shocks recomended pressure is 10 psi for rider weight up to 150 lbs for each 50 lbs extra you can add 1.5 psi extra. do not use an air compressor to air up your shocks, if you do you might blow out the seals you need a little hand pump Harley sells a real nice one.
Jun 27, 2009 | 2001 Harley Davidson FLHT Electra Glide...
Shocks FXST
Loosen the lock nuts ...u'll need a spanner wrench ( harley part # 94455-89) .
Mark the adjuster plate for reference....turning that plate out increases preload to carry a heavier weight.... turning in decreases the laod.... keep the adjustment the same for both shock.... tighten the locknuts and u are done.......
happy trails
Mar 01, 2009 | 2003 Harley Davidson FXST Softail Standard
2003 harleydavidson rear shocks leaking how to check
in the arely forum pages, they say to put soap around the connexctor at the top of the shock. Start with the hoses and check them for cracks. The Harley shocks are known for this problem and is usually in the head of the shcok where the connector installs and can be replaced with new air shock parts for the connector to the shock. Hope this helps. TOm
Feb 10, 2009 | 2002 Harley Davidson FLHT Electra Glide...
Lands Phones Logo
103 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
