Question about PfaFF Sewing Machines
Threading diagram pfaff 1212 sewing machine
Need to see how to thread this oldie but goodie sewing machine of my mother in laws. It also needs an oiling, what exactly do I oil.
louislevel_2
  • 374 Answers
SOURCE: How do you thread a SInger Sewing machine 2623
hi! there,
you can show some actual bobbins winder and threading go to internet explorer and type the address of "www.youtube.com" then on search type "sewing machine".there is a slide show for sewing instruction.just click the slot and it play the video showing what you want.regards don' t forget to rate me.
Posted on Apr 09, 2009
  • 2973 Answers
SOURCE: Pfaff sewing machine 1469.
It is not that the thread is not being picked, it is just that the tension of both the top and bottom threads is not equal. That is why the thread at the bottom gets collected because the lower thread is loose compared to the top one. Loosen the top thread by unscrewing the thread tightner a little at a time. The problem will be sorted out when tension get equal or near equal.
Posted on Nov 30, 2009
Sewtech1
  • 69 Answers
SOURCE: My Pfaff 7550 sewing machine will ball-up thread on underside
Make sure your tension is set on 5 and you don't have dirt stuck in your tension unit.
Posted on Jan 20, 2010
  • 35 Answers
SOURCE: pfaff 1212
check your needle and make sure that you put it in the right way. You should have the flat side of it to the back.
Posted on Mar 19, 2010
  • 255 Answers
SOURCE: Pfaff 260 bobbin thread not picking up
Hi. This can be terribly frustrating, but the most likely cause for the bobbin thread not catching is that the needle is inserted wrong. There is a flat side on the shank of every needle and that has to be facing a specific way on your machine or the needle's grooves can't make the stitch. On most modern machines, it's my experience that the flat side goes to the rear, facing away from the operator, but some of my older machines need the flat side facing to the left or to the right.
Another thing that can cause the bobbin thread not to pick up is a bent needle, but in my experience it's usually the needle not in correctly.
(Cost me $85.00 to find this out!)
Let me know if this works, ok?
Happy Sewing!
Robbie
Posted on Apr 01, 2010
Manual for Kenmore 158120
Sears carries manuals for their products.
The Kenmore that I had, takes the needle with the flat side facing the back of the machine. Then the needle is threaded front to back.
You machine is an oldie but "goodie." Make sure you clean and oil (only fresh good quality sewing machine oil or Tri-Flow Synthetic Lube) 1-2 drops every place where metal rubs against metal. Open the top, the area where the bobbin is located, and the side covering the needlebar. Gently rock the handwheel and watch where things move. Do NOT oil CAMS, plastic/nylon gears, or belts. Oh, don't forget to move the dials and levers and lube those too to keep them moving freely. Do this every 40 hours or so of sewing (or after it has been stored or unused for a period of time) and your machine will serve for many more years. If the machine starts laboring or seizing, it needs TLC.
Jan 12, 2017 | Kenmore Sewing Machines
My hand wheel is hard to move and will not make a complete turn unless I manually move it. Foot pedal all the way down.
Is the motor straining? If so, do not continue to force the motor to run the machine. It could burn it out and you will then be replacing the motor in addition to repairing the other problem.
Is your machine mechanical or computerized? If computerized, check that no thread is wrapped in the bobbin area or around the handwheel. May need to be taken to a technician for repair.
If mechanical, the machine could be seized due to lack of regular cleaning and oiling. With a soft brush, remove any lint, dust, thread pieces, fuzz, etc. from the bobbin area, the feed dogs, and under the needle plate. Then oil:
Need to know where to oil parts in my oldie but goodie Kenmore Do not have...
Apr 14, 2016 | Sewing Machines
Need to know where to oil parts in my oldie but goodie Kenmore! Do not have manual. Where can I download a free manual for this model?
If it's an oldie (mechanical), then you can probably remove the top, slowly hand-rotate the handwheel and apply a couple drops of fresh, good quality sewing machine oil every place that metal rubs on metal. Do Not oil plastic, cams, or belts! You may see oil ports (little holes located near joints) where you can apply oil.
Then access the bottom part of the machine and do the same there. Be sure to oil the feed dog mechanism. Apply a drop of oil to the outside of the shuttle.
Move the dials and levers and oil those mechanisms too.
Be sure to run some scrap fabric through the machine in case there is excess oil.
If things are a little sluggish, direct heated air from a handheld hair dryer into the internal mechanics (top & bottom).
Cleaning and oiling your machine frequently will keep it (and you) happy and healthy!
Apr 07, 2016 | Sewing Machines
How to oil 1958 singer sewing machine
Your Singer is an oldie but goodie! As such, it needs oil, frequently. There are probably some oil ports that appear as small holes where an oil spout would fit. Apply only 1-2 drops of oil each spot. Use ONLY fresh, good quality oil (not the old stuff from Grandma's sewing box, 3-in-1, WD-40, or cooking oil).
The other thing you can do is gently hand-rotate the handwheel and watch where metal parts rub against other metal parts and apply a drop or two of oil. Do NOT oil any plastic parts, rubber, leather.
Be sure to apply a drop or two to the bobbin race where the bobbin turns. By all, means, don't skip the selector lever or dial mechanisms as those usually require oil to move freely.
After oiling, gently hand rotate your machine and if it is still sticky, then you need to hit it again. If things are stubborn, you can direct heated air from a handheld hair dryer into the mechanics.
Lots of patience, elbow grease, and good oil will generally get your machine in fine working condition.
Oct 21, 2015 | Singer Sewing Machines
I've inherited this from my mother. Worth?
nothing without a make or model
Oct 07, 2015 | Sewing Machines
Just been given this machine. Newhome 131. I am turning the handle of my machine but needle is not going up and down?
Okay, from the pictures I found, you have an oldie but a goodie. This is a mechanical machine and most likely has been setting without use for some time. It needs a good cleaning and oiling. The old oil has dried and turned to goo, preventing the parts from moving. If you have the manual, consult the instructions for oiling and cleaning. Use good quality sewing machine oil (NOT 3-in-1, WD-40, cooking oil, or the oil you found in your grandmother's sewing basket).
With the old mechanicals, the best thing to do is take any covers off that you can. Gently wiggle the handwheel and watch where metal rubs against metal and apply one-two drops of oil in each spot. Look for oil ports where oil should be applied. Do NOT oil any plastic gears, Cams, or belts. Don't forget the top left side where the needle mechanism resides and the bottom of the machine, especially the mechanics for the bobbin area. Also, move any dials and levers and oil those if possible. To speed things up, direct hot air from a handheld hairdryer into the machine's interior. (Don't burn yourself!) Then re-test and see if things have loosened. Repeat oil/heat and retest until your machine is moving freely.
Be sure to keep your machine cleaned and oiled on a regular basis (every 8-10 hours of constant use or every six months if not in use) to prevent this from happening again.
Aug 10, 2015 | Sewing Machines
White model 935 maintenance help
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Jul 27, 2013 | White Sewing 935 Mechanical Sewing Machine
I have a Kenmore 385 model and I can not make it zig zag????
even an oldie is still a goodie,, when a sewing machine has not
been used for a long time the grease and oil can become yecky
and it sounds like the machine needs to be serviced with new grease
and oil and see if that help the machine, also having the zig zag
gear or cam checked would be a good idea.
Dec 07, 2012 | Sewing Machines
Threading diagram
need to know make and model number which can usually be found inside the base of machine...I place kitchen paper towel in the base of machine case and oil all moving parts the towel soaks up any excess oil...remove it after 24hrs..
Feb 07, 2012 | Sewing Machines
Material not moving through sewing machine.
Yours is an oldie (but goodie) mechanical machine. If it has not been given a thorough oiling with fresh, good quality sewing machine oil, then she probably needs some TLC. If the feed dogs are up and the stitch length is set to at least the midway point but the fabric is still not moving through the machine, it could be the feed dogs are seized because the old oil has dried and they are not moving like they should. Following the method below, your machine will be humming along in a day or so. Periodic attention will keep her humming.
Wheel on right side that controls the needle up and down is very tight...
Also, something to remember. When threading the top thread, ALWAYS RAISE the presser foot!
Jul 15, 2017 | Kenmore Sewing Machines
Sewing Machines Logo
93 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
