Question about LG RUMOR Cellular Phone
Adding my bluetooth to my phone
I have a LG Rumor and a Jabra bluetooth headset. How do I get them hooked up? I did the tools, add new device, I did it in the "on" mode I did it in the "pairing" mode. I don't know what to do. And its a problem because I the phone is so small that its hard to type and talk at the same time.
Please help me
Lou
  • 599 Answers
It needs to see the jabra..could be a timing issue...start phone (charged) start headset (charged) phone should announce it has found a device *would you like to connect?* message.....another thing..in tools you need to tell phone to look for bluetooth devices (on)
Posted on Oct 22, 2008
WE ARE UNABLE TO CONNECT-OUR LG RUMOR TWO PHONE IT'S NOT CONNECTING
first switch on the power of the bluetooth headset.For that, please press the power key of the headset and dont remove your finger until you get the green light.Then go to your phone`s bluetooth setting and search for the device.Once you see the device in your phone connect it
Mar 05, 2010 | Jabra Bluetooth Headset with Adjustable...
I had a jabra headset that i used for my rumor. i now have a rumor 2 and i tried to pair it with my jabra, but it wont pick it up. whats wrong?
You might want to delete the Jabra headset from the Rumor first, and make sure the phone is powered off. Then put the Jabra into pairing mode (usually done by powering on the Jabra and pressing and holding until the indicator light flashes) and set the Rumor 2 to detect new devices. Once it detects the Jabra, connect and input 0000 (four zeros) and it should connect.
Aug 14, 2009 | LG Car Charger For LX150, LX260, Rumor
Need to re-pair bluetooth to phone
Go to ur phones bluetooth settings - activate pair new device - at the same time press and hold the on button on your blue tooth head set for about 10-15 seconds - this will enter the device into pair mode - on your phone - click on pair with new device etc etc, the default access code is either 0000 or 1234
Jun 29, 2009 | Jabra Bluetooth Headset with Adjustable...
LG Rumor cannot bluetooth with headset
To pair your phone with another Bluetooth device, perform the following steps: 1. Press the Menu/OK key, select Settings/Tools, select Tools, select Bluetooth, select Add New, and then select Search. Your phone displays a list of discovered in-range Bluetooth devices. 2. Select a device, and press the Menu/OK key. 3. Enter the passkey, and press the Menu/OK key.
http://support.sprint.com/doc/sp10800.xml?selectedDeviceId=9207&related=y&Referring%20Related%20DocID%20List%20Index=1&navtypeid=6&pagetypeid=7&prevPageIndex=8
May 04, 2009 | LG RUMOR Cellular Phone
Motorola H715 not connecting with my LG Rumor
Do this:
Turn the headset off.
Set your rumor to find new devices, then immediately turn the headset back on. The devices should pair together. If the rumor asks for a code, the code is 0000.
Mar 12, 2009 | LG Rumor LX260 Cellular Phone
Jabra bluetooth
you need to go to the Bluetooth menu on the phone and select "Add Device" then search for your headset.
Jun 22, 2008 | Jabra BT350 Bluetooth Headset Headset
Jabra BT2010 Bluetooth Headset help
Hey guys, hold the button pressed for 6 sec. until led is solid. then search bluetooth devices on phone click on Bluetooth headset insert '0000' press OK now it should work, or check http://jabra.com for compatibility. Best wishes, htmlfreak.
Jan 03, 2008 | Radio Communications
How do I pair my Jabra Bluetooth -48D
well what you have to do is to go to the bluetooth menu turn  it on and select add new device now on you jabra headset it has an answer button wich you can press untill the blue light stays on that when the env can find and paire the device
Oct 22, 2007 | LG enV VX9900 Cellular Phone
LG RUMOR Cellular Phone Logo
499 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
