Question about Panasonic Televison & Video
Panasonic NV-VP30. DVD displaying fault H02
When I put a DVD into the player it begins 'reading' the disc but then 'H02' flashs up on the display panel and then 'STOP'. I have also lost the manual so I don't even know what fault it refers to.
  • Anonymous Jan 11, 2009
    i have the same problem with my player nv vp30
SOURCE: wont play discs
couls u help me
Posted on Dec 11, 2007
  • 3 Answers
SOURCE: Polaroid PDX-0073 7 LCD Portable DVD Player
Hello
I had that problem, the problem is that where you put the disc (the black Circle) tends to get a bit loose so it moves downwards.
so the distance between the lens and the under surface of the DVD / CD is reduce, so the beam is NOT return to the lens.
The way I fix it is by pulling the black circle EXTREMELY carefully and SLOWLY while you are turning it.
Once is out, with a toothpick or a needle put a small amount of crazy glue in the inner walls of the hole that is in the center ( where the pole of the rotor goes in) this way the hole is reduce.
Wait till it dries, then gently put it back in, it will be a tight fit, IT MOST NOT GO ALL THE WAY IN!!!
By this i mean that you will see the pole of the rotor go into the hole, but it most not reach all the way, it should be below the surface. The distance between the end of the pole and the surface of the black circle should be THE THICKNESS OF THE BLACK CIRCLE.
The way to know that the distance is right, put in a CD and play some songs, then try it with a DVD.
If it reads no disc it means you inserted the disc to much, pull it out a bit, then try again.
Once it reads both CD and DVD, fill in the hole with a drop of crazy glue, this way the black disc will not move anymore.
One more thing, I do not recommend to use alcohol in the lens, 'cause some lenses are now made of polymers non resistant to abrasive, instead use a cue-tip (cottonete, little pole with cotton to clean your ear) moistened with bottle water or distiled water.
Note MOISTENED not soaked or wet.
Hope it works for you.
Best Regards
Luis.
Posted on Dec 29, 2008
satavlad
  • 405 Answers
SOURCE: ERROR H02
Spindle motor in DVD mechanism require replacement, not practical to repair, just buy new one, upconverting DVD player would cost you less then repair of your old one.
Posted on Dec 01, 2009
SOURCE: error H02 for panasonic dvd s35
My Panasonic DVD Player Model S55 does not read the DVD disk. I get a H02 then no disk reading on the display.
Posted on Jan 19, 2010
  • 155 Answers
SOURCE: H02
The HO2 message means the disc is not spinning,it's not about the lens
or the laser.It is easy to take the lid off.Once you do that,plug it in,open the tray with the remote,put in a DVD,close the tray and then give the white plastic wheel on the top a gentle little nudge to get the disc spinning.
Posted on Jan 30, 2010
H02
Jan 30, 2010 | Panasonic DVD-LS50 Portable DVD Player
Error H02 for panasonic dvd s35
Jan 17, 2010 | Panasonic DVD-S35 DVD Player
ERROR H02
Dec 01, 2009 | Panasonic Televison & Video
Technics dv290 system
i once had a panasonic dvd player which displayed the same code H02 and used the same drive mechanism as your player. this turned out to be a worn spindle motor and once replaced, all worked fine. you may well have the same fault. hope this helps?
Sep 06, 2009 | Technics SC-DV290 System
Code H02
Your DVD player is having an issue with the spindle motor (the thing that spins the DVD around). The following solution works for most people, and you should only have to do this once.
  1. Unplug the DVD player.
  2. Take the cover off.
  3. Place a disc on the spindle.
  4. Put a little pressure on the disc (so it doesn't slip) and spin it around a few times.
  5. Remove the disc, reassemble, and plug back in.
  6. Try to play a DVD.
  7. Report back if this solved your problem, or if more troubleshooting is needed.
Aug 02, 2009 | Panasonic DVD-S55 DVD Player
PANASONIC SA-HT800V
Ouch - This generally one of two things.
1 - Run up speed is not sufficient due to motor wear.
2 - The laser head sits within a 'plastic' runner, which wear down slowly, causing the laser to be misaligned - therefore not reading adequately.
Depending how adventurous you are feeling - you could dismantle the unit - and 'space off' the laser unit (Single piece of paper) this will lift up the laser.
Or you may be able to adjust the calibration power of the laser using a variable pot (unlikely to be available as these are generally hard coded nowadays - and not physical pots)
Aug 15, 2008 | Panasonic DVD-LA95 Portable DVD Player
Does not read disc including cleaning disc
The problem with your unit is the "Spindle Motor", this motor is the one that spins the disc so the laser can read it. I sugest you to take your player to a shop, or back for service if the unit still under manufacturer warranty.
Dec 23, 2007 | Panasonic DVD-RP56 DVD Player
Error message when playing any DVD in Hi-fi
Feb 28, 2007 | Technics SCHD560 CD Shelf System
Televison & Video Logo
257 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
