Question about Magellan GPS
The internal connection where the cord that charges the gps system will noe hold the cord connection and thus will not charge the systwm.
  • 728 Answers
You might have the wrong charging cord which is why it might not fit or stay in for it to charge. All you need is to buy the right-sized cord.
Posted on Oct 22, 2008
I turn it on, logo comes on, and it turns off. I've tried holding the on button 8 sec, no luck.
With the limited information provided, a simple first step is to make sure the internal battery is either fully charged or is in a condition to accept a charge. When the internal battery's charge is allowed to below a certain level, it will no longer be capable of accepting a charge via the car charger.
The battery can be conditioned to accept a charge easily, however. This is done by connecting the GPS to the computer via USB port, NOT the car charger. Some Garmin GPS units come with a 120 volt charger that connects to the USB port of the GPS - this method is also an acceptable charge / condition method. Leave the GPS connected for 8 hours or longer (over night) and try to power up again.
I hope this helps!
Oct 24, 2009 | Garmin nuvi 205W GPS Receiver
Gps 350
Press the Power button on the top right corner of the case.
If unit will not power on, battery may be dead. Try connecting car charger or power adapter to unit.
To charge battery faster, leave unit connected to power adapter or car cord. Press and hold Power button to turn unit off. Screen will show "Going into charge mode."
Jul 25, 2009 | Garmin nuvi 350 GPS Receiver
Gps wont turn on without it being connected to chargers
This means that the internal battery of the gps system is completely dead and can not hold a charge. All you will need to do is replace the battery and it should work like new. The battery is fairly cheap to buy and replace.
Jul 01, 2009 | Magellan Maestro Elite 4370 GPS Receiver
My gps system does not charge when install dash board mount
does it charge via an AC charger? As most GPS units do better on an initial AC charge prior to being hooked up to DC.
Your charge circuit is possibly faulty, or the internal battery has collapsed and needs changing
Jun 22, 2009 | Pioneer AVIC-F500BT Multiumedia GPS...
My garmin nuvi 200 worked fine the first 3 times
Connect your GPS to your computer with the USB cable and this will charge the GPS internal battery. Of course your computer will have to be on during the charging process. After a few hours turn on your GPS and see if it now works. If it now works then go to http://www.garmin.com and register the GPS. While you are on line also download the latest USB drivers for your computer and install them. When you reboot your GPS should be properly connected to the computer for Operating system downloads etc.
Apr 07, 2009 | Garmin nuvi 200W GPS
Garmin nuvi 200 pick up charger as a usb cable
The problem is very simple... The GPS unit perceives whatever you plug in depending on the power supply figure.
If you car charger is not giving enough power, then the GPS perceive the cable as being connected to a pc.... thus not charging. Check with an car electrician if you can raise the power supply on your car...
Nov 24, 2008 | Garmin nuvi 350 GPS Receiver
WE CHARGE THE MAGELLAN GPS AND TURN IT OFF. BUT WHEN WE GO TO USE IT AGAIN IT IS DEAD. I ONLY HAVE THE LIGHTER OUTLET TO HOOK UP FOR POWER SO WHEN I NEED TO PROGRAM IT IN THE HOUSE I DO NOT HAVE A WAY TO...
Hello kdiltzbook,
Most GPS units can be charged three different ways:
1. Connection to a computer via USB port
2. Connection to a automobile via cigarette lighter plug
3. Connection to a wall outlet via an AC adapter
Typically most GPS devices these days include only the USB cord. Some GPS units also include the cigarette lighter plug. For most GPS units the cigarette lighter plug and AC adapter are optional accessories have to be purchased in addition to the GPS.
You don't mention which model of Magellan GPS you have so I am not sure which cords your GPS should have included. It sounds like you have the cigarette lighter cord and the USB cord? I am sure that Magellan has an AC adapter available for your GPS. You will want to contact them directly (their website is http://www.magellangps.com) or visit an electronics store that sells Magellan GPS receivers (such as Best Buy™) to purchase the adapter.
However, most GPS receivers can be charged from the USB programming cord on the computer. However, ensure you are plugging the cord directly into a USB 2.0 on the computer itself NOT a port on a USB hub. (A USB hub may not output enough power to actually power and charge the GPS.)
You will also want to check and replace the fuse on the automobile plug.
I believe that both the USB and automobile cords should be charging the GPS. If neither adapter is charging the unit then the problem may be the GPS unit itself. The GPS may have a bad battery or problem with its charge circuitry. If that’s the case the unit may require factory service as the battery pack is generally not considered to be end user replaceable.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 07, 2008 | GPS
Nuvi 650
Hello Grumpa1350,
There are several possible reasons why a GPS unit might not turn on. For example, there could be something wrong with the charger such as a blown fuse, bad power adapter, or defective cable connection. The internal battery inside of the GPS also might be defective or worn-out. Or, worse yet, the unit may have a more serious hardware fault.
You don't say how you are charging the unit. I'd recommend trying a different charge method. The GPS can be charged one of three ways: connection to you car via the automobile power cord, connection to your computer via a USB cable, or charging from a wall outlet using an optional AC adapter. If you are charging the unit in your car, try connecting it to your computer (or vice versa). If the GPS turns on after being charged using one method but not the other, then that pretty much tells you that the problem is with the cable or adapter being used for charging.
The Garmin NUVI 650 does not contain an internal fuse, but there is a common 3 amp fast-blow fuse located in the vehicle power cord. If you find that the problem happens when trying to charge the unit in your vehicle, then you should change this fuse and see if that corrects the issue. The fuse can be replaced by unscrewing the black round piece at the end of the cigarette lighter plug.
If the unit does not turn on regardless of what charge method you use, then the fault is likely with the GPS itself. Either the internal battery would need to be replaced or the unit would need to be serviced to correct whatever hardware fault is causing the problem.
I would recommend you contact the manufacturer before you attempt to open up the unit. Opening the case of the GPS may void your manufacturer's warranty (if the unit is still under warranty).
Best regards,
Ken
Go Ahead. Use Us.
May 14, 2008 | GPS
Maestro 3250 Charging
I accidentally ran into this problem today when I inadvertantly plugged the wrong charger into the unit. I'm guessing that the device isn't getting the precise current it's expecting and thus thinks it's plugged into a computer. I'd suggest getting hold of a different charger and see if the problem goes away.
Jan 31, 2008 | Magellan Maestro 4040 GPS Receiver
Internal battery won't charge
Common issue. Steps to troubleshoot/solve:
1. Pull off face, press reset tab.
2. If unit wont turn on or if turns off immediately, connect to home computer using mini usb on side of gps (any usb cord that fits will do). This will charge the internal gps battery, which is discharged.
3. You will not be able to see the gps charge indicator while the usb cord is plugged into the unit. To check charge level, disconnect it, turn it on, and note the large "battery" icon.
4 Do you have a dead internal battery? If the gps holds a charge from your computer usb port, you don't.
5. If you have a dead battery, Google DIY replacement. With some soldering it can done for $15 total.
6. If you don't have a dead battery, the issue is charging from the cigarette lighter socket. Your car socket may have blown a fuse (check car manual). Your charger unit may have blown a fuse (unscrew the tip, check fuse inside). Also, some car sockets don't work when the ignition is off. Test yours.
7. There is a good chance the connection of the charger wire to the gps cradle is the problem. Fiddle with that. Replacement cradles are available for the c340 at about $25.
8. If your unit is not charging from the cradle/socket, buy a 12v usb cord. Plug into socket and into usb port of the gps. This is a workaround or alternative to buying a new cradle.
9. IMPORTANT: observe the "battery" icon while driving, esp. if you have doubts about charging. Basically, if you can see the icon, you're not connected to an outside (car or computer) power source. That is, if you can see the battery-charge indication, it means your battery is currently discharging and unless you get another power source to work it will be dead in a few hours.
Aug 27, 2007 | Garmin StreetPilot c340 GPS Receiver
GPS Logo
47 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
