Question about Sony Network Walkman NW-A3000 MP3 Player
Sony Nwa3000 appears dead??
Walkman was working ok, but software messed up so got the latest 4.0 sonicstage software. uppon adding a few albums, my laptop switched off due to low battery. My walkman now doesnt switch on or even show a connecting or charging screen??
  • Anonymous Nov 04, 2007
    Similar problem. When trying to connect the Connect software now tells me the device failed to initialise correctly - error 02040100. Will try suggested fix.
    Tried to reformat the device from Connect player but that had no effect.
  • wetenhr Nov 05, 2007
    My NW-A3000 registered a connection problem. Neither the Connect software nor the new Sonicstage software would properly connect it. Both reported problems in connection. The device simply said that it was trying to connect.
    I reinstalled the firmware to level 3.0 as described below. Then I used Sonicstage to delete all the information on the Walkman. This took quite a while, but you need to be patient! Additionally, I used the Connect software to format the Walkman. Finally (belt and braces), I reformatted the disk through the Walkman itself by using the Restore Factory Settings options from the menu.
    Finally, I deleted the Connect software from my computer entirely and switched just to using SonicStage. Loaded everything into the SonicStage library, checked the synchonisation options, then let it run. All worked fine and everything synched.
    The one thing to note - a lot of these actions take a long time to run ( a couple of hours) and the software doesn't tell you much. However, don't give up and re-boot!
    Also, once the whole synchronisation process has concluded the Walkman will still say 'Connecting', although the SonicStage product will say it has completed. Provided the Walkman doesn't say 'Do not disconnect' you are safe to disconnect.
    Problem Solver:
  • 5 Answers
First things first-have you pressed the reset button on the bottom of the unit? Secondly- try updating the firmware on your unit the manual way - Go to this link. http://www.sony.co.uk/view/ShowArticle.action?section=en_GB_Products&articlesection=1&article=1154694485490&productcategory=%2FAudio%2FNetwork+Walkman&productmodel=%2FAudio%2FNetwork+Walkman%2FNW-A3000&productsku=NWA3000B.CEK&site=odw_en_GB Go to download the latest version of Sonicstage but dont actually do it. At some point there is a link to update your firmware to version 3.0. Try doing this again, going through the update procedure it suggests, even if you already have 3.0 installed. This might work. Worth a try at least!
Posted on Jan 05, 2007
I want to add video songs via sonic stage but they are not added..
The NWZ-S616F Walkman Player is not transferring the music using the SonicStage Software. Sony old Walkman player was using the SonicStage Software for transferring the files. You can use Windows Media Player 11 or higher, Media Manager for Walkman, Content Transfer Software or Windows Explorer for transferring the files to the Player.
Click here and select the operating System to download the Software for transferring the files.
Thanks for using FixYa.
May 06, 2011 | Sony Walkman NWZ-S616F MP3 Player
Tip
No Data/Format error on Sony Network Walkman
Sony Network Walkman does not support adding / removing of files, or formatting if it is not done from SonicStage, their software.
If music is added of removed from windows explorer or other software, the player gives an error message 'No data' or something similar.
To fix the problem, download and install SonicStage from Sony support website.
Select your model and click continue, then scroll down, select your operating system in the select box to the bottom of the page and select the software you want to download...
After installing, connect the player to your computer and select 'format' from the menu (This will remove all data from the player, so you might want to make a backup).
Now transfer your music files to the player using sonicstage.
Good Luck
on Apr 01, 2008 | Sony Network Walkman NW-E005 MP3 Player
I am not able to install songs. i have installed sonic stage software. it detecting the player. after disconnectiog and playing, it shows no playlist.
The issue happens as the songs transferred to the player is not using the SonicStage Software. I suggest that you backup the songs in the Computer and then Format the Player. To Format the Player; press and hold the DISPLAY/HOME button, select Settings-->Advanced Settings-->Initialize--> Format-->OK.
Once the Walkman Player is Formatted, install the latest version of the SonicStage Software in the Computer and transfer the songs again using the Software to the Walkman Player. Click here to install the latest version of the SonicStage Software.
This should resolve the issue.
Apr 06, 2011 | Sony NWS706 - 4GB Walkman MP3 Player -...
NW-E003F and i am having FORMAT ERROR
The FORMAT ERROR message may occur if the Walkman player has been formatted using the format utility in Windows Explorer. To correct this issue, initialize (format) the portable player using the Initialize or Format utility built into your Walkman player.
Home button-->Menu-->Advanced Menu-->Initialize-->Format-->OK.
Reset the unit by pressing the RESET button with a small object such as a paper clip. Reset button is located near the volume buttons.
If the issue occurs after making any changes in the SonicStage Software, then reinstall the Software in the Computer using the latest version. Click here to download the latest version of the SonicStage Software.
Apr 06, 2011 | Sony Network Walkman NW-E005 MP3 Player
I CAN NOT PLAY THE MP3 SONGS OR OTHERS. WHAT SHOULD I DO ?
The NWE503 Walkma player is compatible only with the ATRAC3/ATRAC3+ and MP3 songs. These songs format will work only when transferred through the supplied SonicStage Software.You can download the latest version of the SonicStage Software from here
Transferring the songs using the SonicStage Software will resolve the issue.
GoodLuck!!
Nov 02, 2010 | Sony Network Walkman NW-E503 MP3 Player
I have been given a Sony Walkman ATRAC AD MP3 playerwhere i can obtain software to comunicate with it?
The Software for tranferring the songs can be installed depending upon the Operating System installed in the Computer. Before installing the SonicStage Software in the Computer, install the SonicStage Security update. Click here to install the SonicStage Security update.
Install the Software from the link given below: SonicStage 4.3 for Windows Vista SonicStage for Windows XP
Good Luck! FixYa
Oct 30, 2010 | Sony NW-HD5 MP3 Player
Hi there I have a sony NWS203FS walkman when clicking into the icon i get Error Code: 00004e2e How do I fix it?? Thanks
This seems to be an error message when the database of the SonicStage Software has been changed. I suggest you to backup all the Songs in the Player and update the Software. Make sure that the SonicStage Backup Tool is used for creating a backup disc. Then, uninstall the SonicStage Software and install the latest version of the SonicStage Software(ver 4.3). Before installing the Software install the SonicStage Security update and then the SonicStage Software version 4.3 for Windows Vista.
After installing the Software the issue will get resolved.
GoodLuck FixYa
Oct 29, 2010 | Audio Players & Recorders
SonicStage won't open
I don't know if this will help but have you tried Sony's website? There is a security update for Sonic Stage 4.3 that they say must be installed in order to make the program run properly. Go to Sony USA and type in minidisc players in the search window. Then click on the link for minidisc players. When that window opens type in your model number and the page displaying that particular model should open. There you should find the latest software updates. I downloaded Sonic Stage 4.3 along with all of the needed updates from Sony's site and it works just fine for me. You may have to uninstall your current software and reinstall it after installing the security update as the installation instructions on the website said that the installation must be done in that order or the Sonic Stage software may not work properly. Sony also offers email tech support.
Good luck.
Feb 23, 2009 | Sony Net MD Walkman MZ-NE410 Recorder
Deleting album files from Sony Walkman NW-S205F
In the file manager which is in the menu, u'll have options such as camera album, music and all.....U can delete the album u dont want from that.
plz do comment and rate.
Aug 24, 2008 | Sony Walkman Sport Series NW-S205F MP3...
Format Error
I hade just that prob. "format error" used to display. I did this:
1. dwl sonicStage (free)
2.- in the walkman went to menu/initialize/format
then displayed a confirmation screen, I confirmed
it displayed "formating...... COMPLETE"
3.- THEN plugged into the PC and transfered songs with Sonic
and it worked!
Jan 16, 2008 | Sony NW-E003F MP3 Player
Sony Network Walkman NW-A3000 MP3 Player Logo
230 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
