Question about Panasonic Televison & Video
I own a panasonic ae900u LCD projector. Recently, while watching TV (or DVD etc...) my projector would suddenly turn to the 'blue' screen as though it was not receiving an input signal. This would be remedied by basically touching or rocking the projector (moving the cables in the back). Now when i try to watch TV, it doesn't receive any input (S-vid, compnent, RCA, nothing!)! The bulb is new and the menu page displays fine. I'm fairly literate in audio/visual so I know it's hooked up correctly. I have a feeling it has something to do with the electronics running the inputs! Help! Thanks. -Jeremy
techman
  • 3130 Answers
SOURCE: video input problems
If its a brand new set and never worked from the get go I bet ya 10 to 1 that theres a plug or clip lose in the set someware. Hope ya got a warrantee as you should have unless you bought if off A corner someware. Call the repair service # thats in the owners manual to get it fixed asap. Good Luck
Posted on May 28, 2006
  • 198 Answers
SOURCE: **L@@K** How To Connect Laptop To Projector To Receiver!! HELP!!!
"the PT-AE900U supports a full range of input sources, including DVD and video players, PCs and game machines. An HDMI input provides compatibility with HD digital sources, while component video input terminals deliver full-quality, detailed images from high-end, progressive-scan DVD players. The PC IN terminal can be connected to a game machine or PC. Other terminals include composite and S-video, as well as a serial terminal for connecting a touch panel controller or similar device." You can go to Dell support to either read your manual, but your laptop model's manual is there for the reading. It lists all the outputs. if you have a problem figuring which to use, they will tell you. your manual can be found at http://support.dell.com/support/dsn/dsnsearchresult.aspx?c=us&cs=19&l=en&s=dhs&Query=bWFudWFs&SystemID=INS_PNT_P4_9400&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1
You may either have to connect the laptop directly to the Panasonic, or you may be able to connect it through the Harmon Kardon, but I doubt if there will be any advantage to doing that.
Posted on Mar 15, 2008
  • 21 Answers
SOURCE: input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Posted on Jul 26, 2008
  • 231 Answers
SOURCE: PDP4210EA1 Plasma TV black and white pic on reg RF input-no signal on other inputs
does the DVD player connect to the same port as the regular cable vision ?
If no I would be looking at the port that the cable vision connects to, to see if part of that circuit is shot.
Another question, has the T.V. been moved from one location to another just prior to this happenning? As plasma T.V.s can only be tilted on a 15 degree angle.
Posted on Oct 16, 2008
mistersony
  • 320 Answers
SOURCE: HDMI Input Stopped Working Sony Bravia KDL-40S2000
Bad input board BU or AU
Posted on Oct 18, 2008
Home cinema projector (panasonic) and blue ray player only show half an image
To me itcsounds like ypu have a 1080p signal, 1080i is what it accepts. The 1080p signal will only show up on half the screen. Switch blue ray player to 720p or 1080i output.
Jun 26, 2014 | Panasonic PT-AE900U Multimedia Projector
Help! Projection snowscreening!
in side the projector is a small like an lcd screen i cannot remember the name, but they are not cheap this is how the projector displays the output so you can see the screen programs, this would of gone they do this, over time, this would need replacing, they are not cheap but you can replace it. its at the end of the light chamber in between the lenses. the part is called DMD
Jul 08, 2017 | Panasonic PT-AE900U Multimedia Projector
MY PT-AE700U LCD PROJECTOR HAS A BLUE HAZE RUNNING VERTICALLY ON THE LEFT HALF OF THE PICTURE.
Open the upper cover remove screw back side of the projector
Remove LCD connector and clean with soft cloth and fix it again.
close the upper cover and then POWER ON if the problem exist then the blue LCD is faulty and need to be replaced.
(very carefully because the ribbon cables and connector of the LCD is very senstive)
Jan 22, 2011 | Panasonic PT-AE900U Multimedia Projector
I own a panasonic pt-ae900e i have notice a thin uneven green transpairant line in the middle of the screen lamp time 1987 hrs
Experience:
There is three LCD (liquid crystal display) in your projector when one LCD faulty he display a line some time flickering line one or two lines. Due to other two LCD is working well so this line is looking transparent. If BLUE LCD faulty than the line color is very light green or yellow.
Second option is this that your projector lamp life is near to end and after 2000 hours projector is very dirty inside and need service.
(service of LCDs and other parts of projector is a very technical job and I don't know you can do it or not)
Jan 16, 2011 | Panasonic PT-AE900U Multimedia Projector
Our projector (Panasonic PT AE900U) is still working but the picture seems very dark all of a sudden. we are wondering if this means we need to replace the bulb and if so, what do we replace it with.
You need a new lamp. Cost is around $350. The following site shows replacement:
http://www.shopvsc.com/Replacement-Lamps-for-Panasonic-Projectors-s/284.htm?searching=Y&sort=7&cat=284&show=50&page=1&f-PT-AE900=109462
Oct 16, 2010 | Panasonic (ETLAE900) Projector Lamp for...
I have a Panasonic pt-ae900u projector that doesn't project an image. The lamp fires up but no light makes it past the LCD panels, no video or menu graphics, nothing...help would be appreciated
I have the exact same issue with my projector and was wondering if anybody has an idea what the problem/solution could be? Have checked all internal connections, wiring, etc. but nothing is physically wrong with it. Powers on and off with no issues; bulb is working but no light out of the lens. Please help!
Oct 14, 2010 | Panasonic PT-AE900U Multimedia Projector
Bulb not coming on?
Hi - You can download the manual by clicking the link underlined in blue below:
PT-AE900U
Most likely the air filter needs cleaning. See page 55
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 13, 2008 | Panasonic PT-AE900U Multimedia Projector
PANASONIC LCD PROJECTOR MODEL # PT-AE900U
The manual says that it will do this as a reminder that it has ended the recommended lamp life (on mine PTAE900E this starts at 2700hrs and supposedly can blow from then until the max of 3000hrs)
sounds scary enough i guess but they put that 10minutes on/off thing in there to kinda force you to get it changed...
mine is at 2600 anyone know of a good place to get a new lamp in melbourne australia?
cheers dave
Jul 13, 2008 | Panasonic (ETLAE900) Projector Lamp for...
Panasonic PT-AE900U
Very confusing posting !
RGB input for DVD Player ?
HDMI input missing ?
Apr 13, 2008 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT-AE900U displays black and white only
sounds like bad cables, or wrong setting on projector you may have it set to compoent instead of composite,, you don't tell how you are hooking it up. (what type of cables you are using)
Oct 25, 2007 | Panasonic PT-AE900U Multimedia Projector
Televison & Video Logo
52 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
