Question about NorStar M7310 Corded Phone
I can't get an outside line? Norstar M7208
I can't get an outside line. I tried it with pushing 9 first and without pushing 9 and just picking a line but both ways it's always busy. How do I fix this.
And when I tried moving the phone to another desk all it does is flash arrows. How do I fix this?
Please help
  • 31 Answers
SOURCE: Programming a phone to pick up calls
I need more information. When calls come in, does the triangles appear on the phones you want to pick up? Do you have all the lines on the phones? Is sounds like you want only the "ringing sound" to happen on your phone, but have it appear on the others. Is this correct??
Posted on May 23, 2007
NASAIT
  • 4 Answers
SOURCE: Call forwarding to outside line
To send a call to another telephone within your system, or to an external
telephone. You may not be able to transfer a call on an external line
to an external telephone, depending on the capabilities of the lines.
1. Make or answer a call.
2. Press the feature button then press 70.
3. Call the person you want to transfer the call to.
4. Stay on the line if you wish to speak to the person first.
5. Press the Release button to complete the transfer.
If an external call is transferred to a busy internal or network
extension, or is not answered after a few rings, the call automatically
rings you back.
Posted on Oct 29, 2008
ynotphone
  • 192 Answers
SOURCE: How do you page with a Meridian Norstar M7208
There is another page, acting more like a directed intercom page...
If you want to talk to someone and you know where they are (general area) you can do a FEATURE 6 6 and the extension number.
This is a direct page and when you page this way, that person can respond back and you can hear them.
Posted on May 02, 2009
  • 4 Answers
SOURCE: How do you set up caller ID on a Norstar M7208
There are a few other things you need before it will just work on your phones. You need to get Caller-Id activated by your carrier on each of the 4 lines. You also need to make sure your system has a Trunk card capable of Caller-Id. The card in your systems should be labeled CID.
After this you still need to program the lines for Caller-Id in the configuration section of programming.
Posted on Jul 30, 2009
consultel1
  • 860 Answers
SOURCE: Norstar M7208 - Only 1 of 3 phones will ring
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should sat line 001: appear only press CHNG til it says appear &ring.
press next key (lower right arrow)
The display should say line 002: appear only
Repeat same procedure as line 001 til all available lines are done
press the release key when finished
Posted on Sep 21, 2009
NorStar M7208 - How to remove global ringing?
This is tech side of programming and not Admin, if you don't know config password or how to program then call a tech.
If you do know then:
First find out what line #, do F*0 then press the button and note the full number on the display.
i.e. Line 5 in programming is Line 005, 025 or 031 depending on software version.
Sets/LineAccess/LineAssignment/Show line ***/Change to Appear Only or Not Assigned.
Jul 25, 2012 | NorStar M7208 Corded Phone
Long distance is blocked
Some of our phones we need to dial 9 for an outside line
May 21, 2010 | NorStar M7208 Corded Phone
Do the Norstar M7208 and Aastra 9120 phones compatible on the same PBX? I have a M7208 that works fine on current PBX, but new Aastra 9120 doesn't work. Should they both operate on the same PBX?
No, the M7208 is a propriatary set which requires the PBX to function, whereas the aastra phone is a stand alone set which requires a standard telephone line and a power source.
Dec 23, 2009 | NorStar M7208 Corded Phone
Won't generate tones from keys when connected
Any other phones on system with the problem?
DTMF or touch tones are generated through the trunk card(s) of the sytem problem. Chances are there may be more then one phone that has a problem.
Also on the outside of things, just try calling the same number from a different phone on the system, and if possible try using the trunk/line that you did with the m7208 in question, same problem? If yes possible trunk issue. If no, then try another phone where the problem set is plugged into.
Another thing you can try is call another service that uses a touch tone menu, using the phone in question, see if you have the same problem.
May 11, 2009 | NorStar M7208 Corded Phone
My intercom wont turn off when i pick up my phone
Dial 1 thru 9 to access an outside line, or press a line key
Dec 09, 2008 | NorStar M7208 Corded Phone
Caller id only displays after i pick up the line
it is a progrsamming issue that can be fixed where are yuou located?
you can call me at 3107016774
Sep 18, 2008 | NorStar Meridian M7310 Phone
Norstar M7208 display screen garbled
Increase the contrast of display of ur phone it might fix the problem
May 13, 2008 | NorStar M7208 Corded Phone
NorStar M7208
Reboot the phone system.
Unplug the main control unit.
Jan 10, 2008 | NorStar M7208 Corded Phone
Dec 14, 2006 | NorStar M7310 Corded Phone
NorStar M7310 Corded Phone Logo
162 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
