Question about Magic Chef 31000 Gas Kitchen Range
Magic chef model #31DA-7
Everything works on this almond colored model, EXCEPT the oven if off about 50-70 degrees from the control knob. A parts supply person told me that the oven thermistate was obsolete and no longer available. However, I might be able to adjust the temperature in the owen by the adjustment screws located behind the Oven Knob. Do you know how I might go about this??????
aborcass
  • 2651 Answers
SOURCE: Magic Chef 61EA-3KX oven knob hard to turn
nothing magical here, sounds like the thermostats on its way out, not servicable part needs replacing.
Posted on Feb 26, 2008
57 varieties
  • 1653 Answers
SOURCE: Oven is not reaching proper temperatures
You most likely have either a faulty thermistor or heating element that will need to be replaced.
Posted on Nov 10, 2009
localwonder
  • 6784 Answers
SOURCE: Magic Chef Oven 3888VRA beeps and shows F-1.
Hi this is indicating a Defective touch pad or clock (ERC).
This simple test will help determine whether the ERC (Electronic Range Control board or Clock) or the touch pad is defective when F1 error code is present. Follow carefully, and with caution.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: Do not preform this test if you feel as if you are not qualified to do so. Contact your local service depot, if needed.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Posted on Nov 17, 2009
  • 111 Answers
SOURCE: My Magic Chef gas oven thermostat is not working
ther is a temp sensor that goes from the control valve to the oven,this may be the problem, make sure sensor probe is tight where it screws into the gas valve and other end is not just hanging in the oven, it attaches to the top of oven,if it's where it's supose to be, I'd change that first
Posted on Jan 31, 2010
  • 152 Answers
SOURCE: We have the magic chef magic chef 64HA-4TKVW
First unplug for a couple of minutes to reset the control. If that doesn't work you need a new control.
Posted on Feb 14, 2010
Chef Banquet - turns off after 7 minutes? Why
It appears the problem is in the keypad controller board, it will only run for 7 minutes and give a loud beep, you need a professional for this, to assess the situation.
Mar 27, 2012 | Magic Chef MCD1311ST Microwave Oven
Oven, model number 3510PRW does not reach the temperature dialed. To get to 300 degrees I have to put it on 500 degrees. Thank you for your help!
Either 2 thing can go wrong
1. you temp sense probe is failing
2. you temp offset on your dial got loose, or your knob is messed up
Dec 18, 2010 | Magic Chef Ovens
My Magic Chef gas oven thermostat is not working properly. At 400 degrees it only heats to 200 degrees and at 500 degrees it only heats to 300 degrees. Do I need to replace it or can I calibrate it?
Jan 31, 2010 | Magic Chef CGR3725 Gas Kitchen Range
No heat on magic chef microwave
Check the door safety interlock switches.
Dec 29, 2009 | Magic Chef MCD1311ST Microwave Oven
Almond or Bisque Color the same??
Your range is almond. The AA at the end of the model number is the color code for almond. Paint on a range may be affected by high heat be sure to use one that is tolerant of high heat. Almond is more yellow and bisque is more white, not the same color.
Jan 02, 2009 | KitchenAid KESC307 Electric Kitchen Range
Magic Chef oven won't heat up past 200 degrees
You obviously have one or more elements not working, you need to test same, and replace as req'd.
Dec 12, 2008 | Magic Chef Ovens
Magic Chef 31000 Gas Kitchen Range Logo
207 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
