Question about Ricoh Aficio 450 Copier
Sc 925 afficio error code - Ricoh Aficio 450 Copier
Bubbabear64
  • 2794 Answers
SOURCE: afficio 450
Goto to copytechnet.com. Someone can help you locate the error codes you are looking for. That one is supported by copier technicians.
Posted on Aug 06, 2008
  • 126 Answers
SOURCE: AFFICIO 450. WHILE STARTING A MACHINE GETTING A
sc 329 is the laser unit problem. the noise is not gear, it is laser noise. you have to replace the laser unit mate. thats the only solution.
Posted on Dec 26, 2010
  • 62 Answers
change the lazer diode unit -thanks
Posted on Jan 06, 2011
  • 15 Answers
SOURCE: AFFICIO 1075 CODES SC 627
BCU (Base Engine Control Unit) LCT (Large Capacity Tray), Communication/Timeout Error
During Communication with the LCT, the BCU recieved a break(low) signal.
Possible Cause:
Serial line connection unstable.
External Noise on line.
Posted on Jan 28, 2011
santosj27
  • 263 Answers
SOURCE: ricoh afficio mp 1600 "sc 559 " help me
This code is related to a jam in Fusing Unit.
First of all you need to repare that jam problem. (Probably a stripper pawl out of the place) and after that you can disable that message by in SP mode. The main problem is the jams. After that reply to me and i help you disable the message
Posted on Apr 22, 2011
Ricoh Afficio cl 7000 sc 552 code what is it?
Try the procedure below. Its a hardware error on the device
Press and hold online + escape, then power on.
Use up and down arrow keys to select SP2
Press Enter
Use up and down arror to locate SP5
Press Enter
Use up and down arrow keys to select 810
Press Enter
Confirm the selection
Power off and on.
The error code is now cleared.
Aug 18, 2008 | Ricoh Aficio CL7000 Laser Printer
Afficio 1013 has error 550 problem
SC Code 550 - Standby temperature error 1
Symptom: Fusing temperature failed to
drop to expected level within a
given time (15 seconds, 15
minutes, or 25 minutes,
depending on mode) after
entering standby or low-power
mode.
Possible Cause:
• TRIAC short
• Fan not running
May 05, 2011 | Ricoh Aficio 1013F Copier
Ricoh afficio mp 1600 "sc 559 " help me
Apr 22, 2011 | Ricoh Aficio MP 1600L Black and White...
Possible Cause:
Jan 28, 2011 | Ricoh Office Equipment & Supplies
Hello, ricoh aficio 1018d error code display sc 925 what can i do for it.
IMB non-connected error
Symptom:
IMB is not connected. This SC only
appears with B040 and B043 version
machines.
Possible Cause:
• IMB is not connected
• Poor connection between BiCU and
IMB
• IMB defective
• BiCU defective
Sep 27, 2010 | Ricoh Aficio 1018D Copier
Have an aficio 1018 copier with an error code SC544 any ideas ?
that's a fuser unit error do an Sc reset and restart the machine if not replace the fuser unit
May 19, 2010 | Ricoh Aficio 1018 Printer
Error code
SC No. Item Definition Possible Cause Related
SCs Troubleshooting Procedure Type
SC
393-
001
TD sensor error
during warming
up
393-001: K
393-002: Y
393-003: C
393-004: M
The development-unit drive
starts. TD sensor signal is 0.78
V or less.
• Loose cable
connection
• Positioning plate out
of place
• Defective TD sensor
• Development unit not
found
1. Turn the main switch off and on.
2. Check that the development unit is
correctly installed.
3. Remove the development unit and
check the connector on the rear.
4. Check the positioning plate.
5. Replace the development unit.
Hope this can help you , seems the problem is on the black development unit
Aug 12, 2008 | Office Equipment & Supplies
Afficio 450
Aug 05, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
593 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
