Question about Sony SNT-V704 (SNTV704) Video Server
How to reset Sony SNT-V704 (SNTV704) Video Server to factory default setting
3 Suggested Answers
Shuttle83
  • 1139 Answers
SOURCE: Sony SNT-V704
If your unit keeps crashing this could be a sign of over heating. There is a way to test if it is an overheating issue and that is as the unit is playing use a hot air gun to raise the temperature and trigger the problem once the bad component is found replace it.
Posted on Sep 13, 2007
  • 414 Answers
SOURCE: I am in search of
To get the drivers you should always go to the manufacturers website (put the word support in front, i.e - if its hp search google for "support.hp") and you should then find your model number and get the drivers from there.
DO NOT TRUST any program that purports to find your drivers for you or locate missing drivers, always get your drivers from the manufacturers site.
Also, NEVER ever pay for drivers, the manufacturers ALWAYS provide drivers for their products and will never ever charge for the drivers.
Please please remember to vote if my solution was helpful to you, and if I did not help then please let me know and I can try further steps to assist you :)
Posted on Nov 01, 2010
Reset brother mfc8880dn
If you wish to reset the print server back to its default factory settings (resetting all information such as the password and IP address information), please follow these steps. Before you factory reset the print server, we recommend that you print a configuration page before resetting the print server.
<For BRAdmin Professional ver.2.xx Users>
Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional Utilities => BRAdmin Professional.
  1. From the main BRAdmin screen double click the appropriate printer.
  2. Enter the print server password (The default password is "access").
  3. Click the Control tab
  4. Click the Restore Factory Defaults button
  5. Click the OK button when you have read the warning message.
  6. The print server will then reset back to its default values.
<For BRAdmin Professional ver.3.xx Users>
  1. Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional 3 => BRAdmin Professional 3.
  2. From the main BRAdmin screen double click the appropriate machine.
  3. Enter the print server password (The default password is "access").
  4. Click Network Configuration tab, Control Panel and select Set Default.
  5. Click on Submit button.
Via a web browser
Because web based management requires the TCP/IP protocol for communication, any reset option you see when managing the machine with a web browser, will not reset the IP address details that are set. If you wish to totally reset all the print server parameters we recommend you reset the print server by using the BRAdmin application.
To reset the print server (excluding TCP/IP parameters) follow these steps:
  1. Connect to the printer using a web browser.
  2. Click Network Configuration.
  3. Enter the print server password (the print server password is detailed in the user guide for the print server) if it's applicable.
  4. Click the Set Default link or Reset Print Server.
Via the control panel (only for network ready models)
  1. Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
  2. Press the Menu or Menu/Set key on the control panel.
  3. Press up or down navigation key to select LAN or Network and press Set, Menu/Set or OK.
  4. Press up or down navigation key to select Factory Reset or Network Reset and press Set, Menu/Set or OK.
  5. Select Reset.
  6. Select Yes.
  7. The machine will re-start, re-connect cables once this is complete.
Jun 19, 2014 | Brother Office Equipment & Supplies
Factory reset
Chapter15 The Init Button
The Init button is used for maintenance: Simultaneously press Init button and turn on (by plugging
in the power adaptor) the Server until USB1 LED indicator simultaneously blinks. After that, the
Server will do the following tasks:
A. Perform a Factory Default of the MFP server, which will restore most of the parameters and
settings to factory default values,
B. Perform a TFTP server. You can upgrade new firmware using any TFTP client tool.
Note: After performing the tasks mentioned above, you have to unplug the power adaptor and then
plug in the power adaptor to restart the Server.
HMPS1U Print Server for Multifunction Printers
Mar 10, 2014 | Hawking (HMPS1U) (DHHMPS1U) Print Server
Cannot get AV Mode
There is a TV/VIDEO button on frond panel of the tv. When you press each time this button then you will able to access different video inputs. if the button is inactive the probably the micro switch for TV/VIDEO button may be faulty. also check the same with the remote. If its doesn't help then try to reset the tv to factory default setting. For that you need the remote. Keep in mind that when you reset the tv to factory default setting all the memorized parameters will erased(like channel memory, personal preference setting etc ). For reseting the tv to factory default do the following
1.Turn on the TV.
2.While holding down the RESET button on the
remote control, press the POWER button on the TV front panel.
The TV will turn itself off, then back on again. Release the
RESET button
Ajin
Jan 23, 2013 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Reboot playstation 3 to factory default
go to settings on the dashboard and the option to reset to factory settings is at the bottom
Jan 27, 2012 | Sony Playstation 3 (PS3) Console
Connection status cannot be confirmed the service requested was not found the server returned with the following reference code 300 on all blu ray options
I have sony bluray disc player S370 I went to set up scrolled down to resetting selected "reset to factory default settings" scrolled down and selected "system settings" and selected "start" turned off the dvd player waited about 5 seconds and turned it back on. Choose netflix, which is what I was having trouble with in the first place, and it connected. I haven't tried other internet connections through the system, however, if this is truly a sony server issue, it should correct any internet connection issue you may be having.
Sep 09, 2011 | Sony BDP-S300 Blu-Ray Disc Player
How do I reboot a Sony SNT-V704?
Reset your SNT-V704:
Open it up and press the reset button on the main PCB 5 times while it is on. You can find the reset switch lower right corner when the front facia faces the ground. This worked for me.
I know this is an old question but I haven't found this solution on the net so let me know if it helps anyone.
Feb 25, 2011 | Sony SNT-V704 (SNTV704) Video Server
I am in search of an installation and user manual for snt-v504 sony video network server
Nov 01, 2010 | Sony SNT-V504 Video Server
Will resetting the factory default settings allow me to change the password w/o knowing the password? Why would you need to reset factory default settings anyways? Also, where can I get a PSP 2000 manual?
the manual can be found here. for all sony game systems.
http://us.playstation.com/support/manuals/index.htm
you would need to reset to factory default setting for the exact problem you are having -- forgetting the password. so your question is "YES".
The Restore Default Settings feature will erase any previously saved settings and restore all of the settings to the default.
  1. From the XMB™ home menu, go to icn_settings.gif (Settings) > icn_systmsetting.gif (System Settings) > [Restore Default Settings].
  2. The message "Do you want to restore the default settings?" should appear. Select "Yes" and press the icn_btnx_color.gif button.
  3. You will then see a message, "All settings will be returned to default settings. Are you sure you want to continue?" Select "Yes" and press the icn_btnx_color.gif button.
  4. All settings are now restored and the system password is reset to "0000".
  5. Press the icn_btnx_color.gif button to restart the system.
  6. Re-enter system settings as appropriate.
this is the site i got the info from
http://us.playstation.com/support/answer/index.htm?a_id=538
May 20, 2010 | Sony PlayStation Portable (PSP) Console
Sony SNT-V704
Sep 12, 2007 | Sony SNT-V704 (SNTV704) Video Server
Will not detect
Ok well all I can suggest is this... first try a NON-crossover cable.. 2nd.. try the address of 10.1.1.1 The server should be setup according to the manual.. and should be detected upon connection, Also is the server to be set up to ASSIGN an address via it's DCHP or to RECIEVE one from ya lappy? I mean basically it is just a network device that sends stuff when asked, not unlike a networked Hard Drive etc. Usually ya set up the lappy for DHCP and the Video Server gets it's address from the lappy, & when "Polled" sends data to whomever "Polled" it.
Aug 25, 2006 | Sony SNT-V704 (SNTV704) Video Server
Sony SNT-V704 (SNTV704) Video Server Logo
113 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
