Question about PSC QuickScan 6500
Have been using the PSC Quickscan 6500 for a long time with Follett's Sagebrush Library Management System. Have switched to LibrayWorld's web based Library Management System and immediately ever time I scan a patron or book barcode there is an asterisk at the begining of the number and the end of the number. The system will not recognize my numbers with these asterisks. Am scanning same barcodes that I always have.
4 Suggested Answers
  • 25 Answers
SOURCE: psc quickscan 6000plus
That scanner has been constrained to accept a digit length of 12 or less .. probably IPC codes which are 12 digits in length.
Do you know the symbology of the barcode you are scanning? (i.e. UPC, EAN, I2of5, C3of9 etc).
Posted on Jan 05, 2008
  • 144 Answers
SOURCE: quickscan 6000 will read not read programming barcodes
usually there is a laminated like square piece of paper that gives you 4 options to scan and one of them is auto
Posted on Jun 06, 2009
  • 38 Answers
SOURCE: scanner is putting an asterisk before and after
Hello mtechman. The first thing you should know is that some people use Code39 barcode 'fonts' to create their barcodes. With these, the creator will need to put an asterisk before and after the barcode's 'human data' to transmit a 'start/stop' command. Sometimes, the barcode already has a start/stop command integrated so the asterisks that are put in the 'human data' are extraneous and are perceived as part of the code that needs to be transmitted. If this is the case, then unfortunately, there really isn't a good way to remove those asterisks.
However, I think this will fix your problem. I have the programming manual hosted on my company's website for our clients (www.shiftintoblue.com/resources/QS6000_configuration.pdf). Take a look at page 63. This page has the options on whether to transmit start/stop characters (the asterisks). This should take care of your problem. I hope this helps. Good luck!
Posted on Jan 08, 2010
Scanner won't scan library barcodes.
The barcode reader is something that the backup software typically uses to identify which tape it is dealing with.
So typically your backup software can already natively read the barcode and therefor you don't need any other software.
The linked barcode reader is probably for reading a barcode that was provided via a picture (from a scanner or camera). This has nothing to do with the barcode reader that can be part of a tape library. NET UPC Barcode Reader
Dec 14, 2012 | Datalogic QuickScan I QD2100 Wired Wand...
QuickScan 6000 hardware connectivity.
A ps2 / USB converter costs a few quid - worth a try?
Sep 17, 2009 | PSC QuickScan 6000 Handheld
Driver for psc quickscan 6000 plus scanner
Hi!
Your PSC QuickScan 6000 should not require any drivers. If this unit plugs into your keyboard port, you should be able to scan a barcode and view the data results in a text editor, such as Notepad. This technology is called "Keyboard Wedge" and consists of a cable with three ends. The first is plugged into your hand-held scanner. The second and third are rather close together and are at the end of the cable. This cable is called a "Y" cable because it resembles the uppercase letter "Y". The bottom part of the "Y" plugs into your scanner, while the first upper part plugs into your computer. The second upper part of the "Y" should be a female plug, allowing you to plug your keyboard into it.
Now if you are using a Keyboard Wedge scanner with a USB keyboard, the female end of the "Y" cable would not have anything plugged into. Unfortunately, the scanner will most likely not operate properly if no keyboard is attached to the keyboard port.
I suspect you may have an RS232 or "serial" scanner. Does your scanner have a power supply that plugs into a standard wall outlet? If so, you may have a serial interface scanner. You could use a program called Com to Keyboard, which would convert RS232 or "serial" data into keyboard data. This is a free program, however, it is a resource hog and may slow your system down.
Feel free to call if you have any additional questions.
Good Luck & I Hope this helps!
-Dave
Dave Krause
Founder, Bluesky America's GetOpen.com
720.771.5194 Direct 888.7.GETOPEN Toll-Free
Mar 31, 2009 | PSC QuickScan 6000 Plus Handheld Barcode...
PSC 6000 Plus not scanning
There are a few questions:
What kind of cable do you use?
USB, SERIAL, PS2
What kind of computer?
Normal computer or Laptop?
Then...
When you recieve the scanner like new you always have to program it.
First you do
Reset to factory defaults.... Never do this with working scanners
then
you have to program it.
First the Connection type
and then if needed a computer type.
After that you usually have to scan a suffix.
This means when you scan a barcode it needs to do something after.
normally it doesn't give Enter after you scan.
That is what the suffix is for.
and then you scan additional symbologies to scan
Like Code 39, UPC A etc. etc.
It needs to be programmed with the manual you recieved.
if you don't have it you can download here.
http://www.scanning.datalogic.com/sitefiles/manuals.aspx
go down in the list to quickscan 6000
and programming manual.
please don't print all the pages. only what you need.
If you need more help i will hear it.
good luck.
Jan 09, 2009 | Datalogic QuickScan® QS6000 Plus...
Problems with very small Barcodes
Default settings set a global limit of 4.
You can set the global minimum code length by following the instructions in the user manual on page 24:
1) Start
2) Set Global Min Length
3) Scan the number on page 303: I.e. '0' followed by '3' to set length to 3
4) Set
5) End
Jan 09, 2009 | Datalogic PSC QuickScan QS6500 Handheld...
Scanner won't read the barcode
you read the code base?
Try another computer, if it is the same, council liaison without base.Direct bluetooth.
Dec 17, 2008 | PSC Quickscan 6500 Handheld
GP5385 incompatible with EAN 13
Dear Akiong, Please try to reset your scanner configuration, using some utilities from it's manual book (usually available at it's case/box), restore it by scanning it to factory configuration,or scan a label that would enable all symbologies.
Aug 24, 2007 | PSC Quickscan GP5385 Handheld
PSC QuickScan GP5385-104342 RS-232 / DOESN'T WORK!
I think the problem you all are having is that this model of scanner requires a "decoder" to work correctly. It is another box which goes in-line between the scanner and the RS-232 port or ps/2 port of the pc. I'm not 100% positive about this, but I am pretty sure this is the problem. You need to look on e-bay for a psc barcode decoder.
Dec 15, 2006 | PSC Quickscan GP5385 Handheld
PSC QuickScan 6500 Logo
53 people viewed this question
Top PSC Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Jax Planet
Jax Planet
Electric Dime
Electric Dime
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
