Question about Mitsubishi WS-55805 55" Rear Projection Television
Mitsubishi hd 1080
Ive had this tv for five years and well it broke last week,im a copier tech by trade should have known the smell well one of the caps went ive put a new one in to fix that problem but it took something else out becouse will power up but no picture green light is on any help would be great. Dan
  • mo5rob Aug 16, 2008
    the volume does not comes on
Power Swiss bord problem
Posted on Sep 08, 2010
I turned on my television, Mitsubishi hd 1080, but then the picture scrambles and the screen turns black with sound...then it shuts off on its own. What do I need to repair this problem?
Posted on Dec 12, 2009
The imput button won't let me off off cable station; I can't change over to DVD of WII and I don't have the original remotr. I have a Time Warner control.
Posted on Sep 08, 2009
The volume does not work
Posted on Aug 16, 2008
    President:
  • 3,130 Answers
Follow that traces that the cap is on, and see if it took out the fusable resistor and/or Diode.
Posted on Aug 02, 2006
  • 3 Answers
Tech Man is right on with his suggested solution. Just wanted to add that your TV may contain a series of pico fuses that will have a bluish of greenish color (sorry...I am a little color blind). They will have a similar shape to a 1/4 watt resistor without the color bands and will have location IDs such as FA005 or FD005 etc. You should also be able to get the values of each of the pico fuses from the circuit board around the location Ids as well. But as mentioned by Tech man, make sure you do not have a defective diode or transistor first or you will not only open the possibility of "back to square one" but things could get worse. Hope this info. helps.
Posted on Aug 20, 2006
I have a Mitsubishi medallion 1080 Hd tv that as I'm watching it It turns off and no matter what I do it just stays on for like five seconds than turns off agsin
This just recently happened to my Samsung DLP. It's a pretty easy fix. You need to replace the lamp. Check your manual for the particulars of that model.
Mar 02, 2015 | Mitsubishi Televison & Video
Every time I turn my HD 1080 series Mitsubishi on 2 1/2 seconds later it turns off by itself
ok, a model number would be helpful but:
when set turns off and green power light goes out: on the front of the set press and hold both the menu and input (device) buttons at the same time for at least five seconds and let both go.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it for a total of 5 times.
This is the error code and indicates where the problem may be---let me know what code you find and I will tell you what it means.
SD TECH
Apr 28, 2012 | Televison & Video
I am attempting to connect a Verizon Fios QIP6200-2 HD set top box to my Mitsubishi WT-46805 HD TV using the Y, Pr and Pb RCA connections (no HDMI port on TV) I cannot get any HD channels to work.
The set will have two component inputs, one is NOT HD.
You want to connect to the DTV input which if you look from the back will be marked 480/1080 I .
Also double check the connections to be sure blue-red-red and green to green.
SD TECH
Aug 18, 2010 | Mitsubishi WT-46805 46" Rear Projection...
I have a 63 inch projection tv, 8 years old, that stopped turning on last week. Not sure what's wrong with it. You can hear the power turn on inside the television though the screen does not turn on. No...
LOOKING AT THE AGE OF THE TV IT MIGHT HAVE DRY JOINTS ON PCB,S SO IF U KNOW ABOUT ELECTRONICS AND GOT SOLDERING IRON RESOLDER SUSPECTED SOLDER JOINTS AND THEN TRY.
Aug 12, 2010 | Mitsubishi Televison & Video
Mitsubishi WS-65907 rear projection TV HD goes blue.
I would look at the source for the Hd signal as being the problem--if you are using some kind of cable or sat box it will deliver the signal to the DTV input on the back of the set--this is the HD input for this set.
It is possible to have a problem like you describe be one in the set--but very unlikely----have you looked on that green signal board for any signs of Glycol?
Anything that will produce a 1080 signal to the DTV input should tell you if the problem is the set or the source of the HD signal that is causing the problem.
If you have questions or need advice let me know--I am here to help people.
if this information has helped you rate this solution as i do this here for free.
SD TECH
Dec 05, 2009 | Mitsubishi WS-65907 65" Rear Projection...
How do I get the hd 1080 to work.
you need to check your inputs, HDMI or DVI not all inputs can except 1080i
Aug 04, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Yellow and blue ghosting
the DM and of the FMT boards are failing.check out www.tv-techs.com the boards need to be rebuilt
Dec 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
I have a ws-a65 tried to install 1080 hd quality through At&t u-verse missing green and red color only shows yellows and blues help!!!
im just going to assume you have it hooked up wrong, call a TV person and they can come look at it, its really hard to do this kind of thing over the internet
Oct 08, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi HDTV 1080 WS-55859. Error Code 12
Did you push in the device and the menu buttons at the same time and get the error code...  I have the same problem and I get a 1,2 code....   I am looking for what the codes stand for...
Have you got any help on this....
Scott
mu email is smartin38@verizon.net
Sep 11, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-55805 55" Rear Projection Television Logo
2,036 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
