When i try to play a cd or a dvd on my laptop, there is a message that says, the request could not perform because of an I/O device error. how can i rectify this?
  • 749 Answers
Could be caused by alot of factors but is more than likely the drive getting ready to fail. Could also be a bad cable, if you reboot and the problem fixes itself I wouldn't worry too much about it, but if it continues you might want to replace the drive. Also you might want to update the firmware for the drive (this I have found usually doesn't do anything unless ther is a known issue with your drive's firmware).
Posted on Oct 22, 2008
When I try put a disc in my cuvd20u sharestation, the computer sees it but it won't play a movie or open, it displays message The request could not be performed because of an I/O device error. Could...
Hello page305,
IF you can use it in the server then there is no problem with the drive. There might be a problem on the network settings, if you have double checked the settings you can try to restart bought of the computer the server and the other one. You can also try sharing it with administrator access. And also if it is a dvd you can try updating your video player software for codecs.
Please reply if this doesn't solve it so that I can provide the right resolution.
Sep 21, 2011 | JVC Everio Share Station DVD Burner Burner
Hi, I have Windows 7 on my MSi L1350 laptop. Whenever I try to play a DVD on my RockSoul DVD Multi Recorder (RW) on Windows Media Player, I get the following error message: "Windows Media Player...
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area or
hope this helps
Apr 04, 2011 | Toshiba ROCKSOUL ED100 USB slim external...
A I/O device error would point to a faulty installation source. Is the CD/DVD in good shape ? no scratches?
Try cleaning it delicatly and install again. If this fails try to copy CD contents to your local drive and install from there.
Nov 11, 2009 | Video Game Consoles & Games
I can't use my CD/DVD-ROM.. i try to put a disc on it, it appears D: is not accessible and the request could not be performed because of an I/O device error. Please help me. i dont know what to do. thanks
Check you system hardware and see if it see the CD/DVD device. check to see if you have the drives and software loaded for that device. Go to toshiba web site and check for latest drives and patches. Some of there CD/DVD drives had upgrade software to make the DVD work right make sure you have everything you need loaded. Then put a blank CD in and try writing to it using there software package. if you can write and read a CD you just brunt then the CD is working. Next try reading a DVD movie see if it plays.
Mar 20, 2009 | Toshiba Satellite A75-S2112 Notebook
DVDs/CDs no longer play on my laptop
You can try cleaning the pickup lens with a cotton swab or cloth. Be careful not to damage anything. Also try a different DVD to verify the disks integrity.
Good luck.
Mar 19, 2009 | Dell Inspiron 1521 Laptop
Drive is not accessible. I/O Device Error
Method 1: Change the transfer mode for your CD drive in IDE Channel Properties
1. Click Start, right-click My Computer, and then click Manage.
2. Under Computer Management (Local), click Device Manager.
3. On the right side, expand IDE ATA/ATAPI controllers.
4. Right-click the channel where your CD drive is connected, and then click Properties. Typically, this channel is Secondary IDE Channel.
5. On the Advanced Settings tab, in the Transfer Mode box for the device that represents your CD drive, click PIO Only. Typically, this device is Device 0. Then, click OK.
If the issue is not resolved after you change the transfer mode for the secondary IDE channel device 0, your CD drive may not be located there. Use the same procedure to change the transfer mode back to DMA if available. Then, repeat these steps to change the transfer mode for IDE devices in the following order until the issue is resolved:
• Primary IDE channel, device 1
• Secondary IDE channel, device 1
Note Primary IDE channel, device 0 is connected to your boot disk. This is the hard disk that typically contains your operating system.
Make sure that all cables are connected correctly
If you have another cable, try to use it. For USB devices, try to use another USB port. If it is internal dirve is there then Reseat it that means remove it and reinstal that
Then Set the BIOS as Default for that restart the system and before windows screen it gives the instructions how to boot in setup once you are in setup, on the bottom it says press F9 or F10 to set as default; different BIOS have different options so do the as the on screen instructons says.
Try to access the media or device on another computer; try it on your friend or family computer
if it is not working contact your H/W Vendor
Aug 14, 2008 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
Computers & Internet Logo
David Payne
David Payne
