Question about NRS Hoveround MPV 5 - Used Power Wheelchair
My hoveround won't move; it just flashes 5 times when I try to move.
When I turn the chair on; it lights normally, but when I try to move; it jumps a little then all of the lights flash 5 times. If I turn it off and back on; it does the same thing. What's wrong?
SOURCE: Hoveround MPV4
Problem solved.
Posted on Dec 12, 2009
HoverTech
  • 232 Answers
SOURCE: How do I charge the Hoveround mpv 4? I plugged the
Firstly, it is bad news to use an extension cord with the charger as it can get very hot. It will sometimes take 8-12 hours to get a full charge on the batteries. If the light does not go to green on the charger, the batteries may be damaged and not able to take a charge. This is especially true if the Power chair was stored after your father in law died; the gel in the batteries may have gone solid. The lights on the controller will go left to right then back if the charger is connected properly.
The brake release knobs both need to be in the UP/DRIVE position for the motors to engage.
Posted on Oct 01, 2010
HoverTech
  • 232 Answers
SOURCE: Hoveround MPV 5 - Used Power Wheelchair: i have a hoeround xhd and pickup lift where does t...
You will need tie downs to the power chair. It is a metal piece the fits over the chair post and sits under the seat and had two metal loops to hook on to. The Hoveround field technician will install it for you.You need to order the tie downs from Hoveround, your insurance will most likely NOT cover the cost.
Posted on Oct 20, 2010
HoverTech
  • 232 Answers
SOURCE: hoveround technique rwd motorized chair charge
Normally the power chairs will not operate when connected to the charger. If you mean the controller comes on when connected to the charger but it wont come on when the charger is disconnected, I would test the batteries first, then the connections and fuses. Did a technician inspect your power chair to determine a controller was needed, or was that just a guess by the representative over the phone? If your insurance will not cover the repairs, I would recommend spending $50 for a technician from Hoveround to come out and inspect the chair to determine what is needed to fix it so you know for SURE. It may be something simple and inexpensive.
Posted on Oct 29, 2010
  • 692 Answers
SOURCE: my uncle left my hoveround
Angel the charger light should only turn green when the chair is fully charged. If you know the chair isn't fully charged then there is a problem with the charging system. if the circuit board in the joystick got wet then that is a serious problem. If you have a voltmeter you can check the battery voltage thru the charging port located under the front of your joystick Set the meter to 200 volts dc and plug the leads into the 2 outter holes of the charger port. Fully charged you should read 27-30 volts if you aren't getting any reading then the batteries are completly dead or there is a problem with the charging circuit (the reason you are getting a green light on the charger) The joystick will have to be replaced sorry If Medicare paid for your chair then they will pay 80% of the repair costs to get your chair working again If they did contact Roadrunner Mobility @ 1-800-467-2668 to get it fixed thru Medicare Hope this helps
Posted on Apr 28, 2011
Hoveround mpv 5 turns off when trying to unlock
Linda, did you keep the instruction manual that came with your Hovaround for such a time as this? For You need it now! Also look for the receipt so that you can see if there is a money back Guarantee with the purchase of that product.
There should be a 1-800 type # that you can call to, to get answers to your problems with that model of Hovaround Motor Chair. Good Luck on your search.
May 05, 2017 | The Health & Beauty
Tip
How to Diagnose Trouble Lights on Hoveround Power Wheel Chairs
Here is a link with descriptions of the flashing controller lights for most power wheel chair controllers. This will allow you a fast diagnosis to save time and money on your repair; it may be as simple as a brake reset instead of a costly motor replacement! The first page you will see is especially for Hoverounds, but you might be able to find other brands if you know the manufacturer of the controller.
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
on Oct 05, 2010 | NRS Hoveround MPV 5 - Used Power...
Hoveround won't move.
Double check to be sure drive levers are fully engaged. Go down and up a few times. If problem persists have Hoveround come and check it out. One of the drive motors may have shorted out when you continued driving with gravel in the wheel.
Mar 29, 2015 | Hoveround MPV5 Electric Wheelchair - Used...
Chair won't move..lights flash continuously
You may have locked it by holding the power button . try turning it on then hit thee horn 2 times . That should unlock it.
Jul 16, 2014 | Jet 3 Ultra Power Chair
Lights turn on cant move
Be sure the free-wheel \ brake release handles are set to drive\lock position prior to turning on. After that, if chair still does not move, you will need to count the flashes on the joystick to determine the error or issue with the chair.
A user manual can be purchased on ebay.
Nov 11, 2013 | NRS Hoveround MPV 5 - Used Power...
Red light flashing on joystick about 10 min after charging
Most of the time it may be the batteries at fault. One more thing to try is charging the chair with the Joystick on all night 10-14 hours uninterrupted charging. Your chair may suffer from current roll back. There is a circuit in your system that has to be reset by the long charge cycle to reset it. I did not make this up. it occurs when the motors over heat or have a a large current draw. the chair will operate normally for ten maybe even twenty mins. then suddenly drop down to 2 flashing red lights.
Feb 18, 2013 | NRS Hoveround MPV 5 - Used Power...
Hoveround mpv4 won't charge Why?
If you obtained the Hoveround directly through Hoveround, please contact them for expert solutions. http://www.hoveround.com or 1-800-96-HOVER. They made the chair, they KNOW the chair best, and can provide the right answers!
Oct 28, 2011 | NRS Hoveround MPV 5 - Used Power...
My hoveround light flash and then goes off wont move.it is in forward gear and the batters are ok.thank Charles
The number of lights that are flashing will indicate what the problem is related to.
You can visit this website to find answers on what the flashing trouble indicator lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the page that has the controller used on your power chair/scooter and count how many lights are flashing to diagnose the trouble. Try resetting your brakes to see if that will help reset the system (makre sure the power chair is turned off first.) If your insurance purchased the power chair for you, they may also cover the repairs; contact Hoveround for an appointment.
Dec 08, 2010 | NRS Hoveround MPV 5 - Used Power...
The speed control light goes back and fourth on the console.
If the lights are chasing left to right then you are in inhibit mode meaning a charger is attached or there is a problem in the joystick with the inhibit functio. Right to left chasing I think means you are in freewheel. Turn the Power off and reset the levers in front on the chair then turn the power back on and hope the lights are steady and the chair will work. If this doesn't do it maybe you are in lockout mode. If you have the manual for this chair it should explain how to get out of "lockout". If not try turning the power on and within 10 seconds push the joystick straight forward and hold until you hear a beep then immediately move the joystick to the rear and hold until you hear another beep then release joystick to the center. This should get it out of "lockout" Hope this helps!!! Of course you could always call Hoveround and ask for tech support to help with this. Checkout their website for phone number Hoveround.com
Aug 19, 2010 | NRS Hoveround MPV 5 - Used Power...
My hoveround MPV5 will not operate. fully charged battery charger light turns green. the brakes are in run position and when the unit is turned on the charge bar just flashes and the chair will not...
You will need to take it in for repair. 8 bar flash usually means you have a bad joystick/controller. They can sometimes send it in to the manufacturer to have it repaired. Find a reputable dealer and relay this info to them.
Apr 14, 2009 | NRS Hoveround MPV 5 - Used Power...
NRS Hoveround MPV 5 - Used Power Wheelchair Logo
Top NRS Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Are you a NRS Health and Beauty Expert? Answer questions, earn points and help others
