Question about Tanita Health & Beauty
INSTRUCTIONS MANUAL FOR THE TANITA BF-682 PERSONAL BATHROOM SCALE
SOURCE: How do I set Tanita digital scale with 2 memory
Go to www.Tanista.com/ProductManual/PDFs/2001_manual.pdf
This should provide the answers you are looking for.
law4644
Posted on Jan 21, 2009
fitnessbalan
  • 59 Answers
SOURCE: Want an English manual for Tanita 2240 Body Fat Scale
here is a link for the manual http://www.theusermanualsite.com/mdownloads/9bdb1c74-c15c-4760-bc30-42b15d11a9f2.pdf
this does have an english manual. there is not an english only manual Tanita is a european company and supplies to many countries with different languages to make things simple they print the manuals in many languages. There is an english version of the manual on the link.
Posted on Apr 17, 2009
SOURCE: Tanita Ultimate Scale 2001 - no user manual -how to set it?
does your scale have an orange SET button and a button with a triangle (or arrow) below the display?
Try this... make sure the scale is turned off. (and you are not standing on it)
Now press the SET button.
2 arrows should appear on the display. use the arrow/triangle key below the display to make changes and the SET key to choose.
If you have the same scale as me, you are prompted to chose Adult/Child followed by Male/Female, and finally input your height in feet/inches by pushing the arrow/triangle key until the display shows the desired height.
Press SET to finish and step on the scale like you usually do. It will now show your weight followed by your body fat %.
Hope this helps you!
Jacob
Posted on Jul 14, 2009
SOURCE: need to reset scale bf-681 tanita scale
I have a tanita body composition scale BC-534. It suddenly stopped working. I have new batteries. Is there a way to reset the digital disolay?
Posted on Jan 20, 2010
  • 5 Answers
SOURCE: Weight Watchers bathroom scale, Model WW60X
I got it! Press "set". You should see "start goal" in the bottom right. Press the user # you want to save as and press "set" again. The display will blink then display "0.0". Step on the scale to get your current weight. Once it's read you current weight, press "set". A goal weight will display. Press "User 1" to make your goal weight go up and "User 2" to make it go down. Press "set" when the display shows your goal weight. That's it. Now all you have to do is press your user # and wait for "0.0" to display before stepping on the scale.
Posted on Mar 26, 2010
Our tanita HD351 scale not working
It is possible the replacement batteries are defective, the wrong type, or not installed correctly.
Jul 14, 2016 | Tanita HD 351 High Capacity Bathroom Scale
How to calibrate mgp-1014
There are different digital scales available for the home, or in your business (like your kitchen scale, bathroom scale, weight scale or food scale), but you have to calibrate them first before you can use them. There are different brands of digital scales like Primo and Tanita, and each of these brands has different instructions on how to operate them for calibration.
Infor from: OBD diagnostic tool one stop supplier
Mar 06, 2014 | 760Li Brief instructions f01, f02, f03....
Error code r5 on Tanita BF-350
Just spoke with Tanita Tech support- r5 indicates if the scale is in PC mode (able to receive data from scale). There is a button sequence to toggle between PC mode and stand-alone mode.
1. Press&Hold Zero button, then Press&Hold On/Off.
2. Release.
3. Arrow buttons toggle between PC mode and Stand-Alone, select which mode you would like.
4. Press Set button to select mode.
Hope this helps!
Mar 23, 2012 | Tanita BF 350 Pro Body Composition...
I have a Tanita Digital Scale with no user manual. Is there a web site where I can download the user manual?
Hi yokoone...
You did not say which model Tanita scale you have, so I will send you to the following webpage and you can download a free user manual for your scale.
Please take time to rate me
http://www.tanita.com/en/digital-scales/
Aug 18, 2011 | Home
I had to change the batteries and now it only reads in "kg" how do i change that on the model 2204?
Since your problem started with a battery change, I am going to assume that method 1 is most likely going to fix your problem...Good luck!
Method 1
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Method 2
Body Fat Monitor/Scales: BF-542, TBF-551, TBF-521, TBF-531, BF-681, BF-682, BF-679, BF-680, BF-578, all Ironman products, and all InnerScan products.
Select the preferred weight mode by using switch on the back of the measuring platform.
Jan 12, 2011 | Tanita 2204 Body Fat Scale
Need to reset scale bf-681 tanita scale
Jan 12, 2010 | Tanita Bf681 Body Fat Monitor Scale...
Tanita Scales
Not sure what model you have but here is link to product website of the manufaturer. http://www.tanita.com/en/personal if you click on your manual there is a link to download manual
Mar 23, 2009 | Tanita Digital Body Fat Scale with 2...
Can't set scales
Not sure what model you have but here is the tanita website, where you can look up the model and download the manual from there. http://www.tanita.com/en/personal
Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Mar 13, 2009 | Tanita 2204 Body Fat Scale
Health & Beauty Logo
209 people viewed this question
Top Tanita Health & Beauty Experts
Tre Elkins
Ankit Chandel
Ankit Chandel
Tom Chichester
Are you a Tanita Health and Beauty Expert? Answer questions, earn points and help others
