Question about Irons
I have a swan s15041 steam generator iron? how do i know when i need a new filter in?
snakehead
  • 1074 Answers
SOURCE: My Tefal Steam Generater Iron will not steam
check the little tube that regulates the water to the holes it needs to be changed.good luck.
Posted on Apr 18, 2007
DiYerTech
  • 70 Answers
SOURCE: no steam comes out of iron
Hi, there is probably a something broken in the moulded plastic trigger assembly (there is a plastic broken finger that actuates a micro-switch under the rubber handle cover). If you are so inclined, use an orange stick and gently pry up the rubber handle cover on either side from the front to the rear cord end to access, inspect and troubleshoot. I am in SoCal and use the California Electric website to obtain parts or go to the Rowenta home website to locate useful manual information, PDF reader and dealer near you.
Posted on Jul 21, 2008
geokohler
  • 304 Answers
SOURCE: tefal proline express steam generator iron needs de scaling
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up the vinegar concentration but do not go higher than 2 cup to 1.
George
Posted on Jul 24, 2008
SOURCE: have just bought kenwood steam generator iron but
Press the variable steam control and the power on/off button to stop the light flashing - that worked for mine!
Posted on Sep 30, 2009
SOURCE: I have a Swan S15040 steam generator iron, the
I had same issue , now , once you turn the unit on , you should see displayed 3 steam jets and the flashing standby , turn the dial on the iron to max ,press the steam button on the machine to max steam , leave for a minute or so , now press the steam button on the iron , does it make a noise ? if it does , slightly raise the whole front end of the unit ( easier if you have the iron on the worktop and not on the unit !) for a minute then try and press the steam button on the iron again . I think there is a bit of an issue about the conection between the water tank and the filter . This solved my issues and i do hope it will help you .
Posted on Oct 16, 2009
Swan steam generator 2400w doesn't pump steam. Would a new filter help
It may be that neither are at fault, the problem is likely the heating element is burned out.
Jun 21, 2016 | Irons
Swan steam iron
The iron has failed and is leaking steam where it shouldn't be leaking.
May 23, 2017 | Irons
Swan steam generator iron not steaming
The steam vents may be blocked. Add some vinegar into your iron box and try to steam for a few time. then clean the steam vent gently with a tooth pick. Drain out the added vinegar and start using your steamer as usual.
Oct 29, 2012 | Tefal Ultraglide 1549 Iron
I need a manual for swan steam generator iron item si4030n
http://www.swan-brand.co.uk/swan-2200w-steam-generator-iron-1.html see Documentation http://www.swan-brand.co.uk/media/swan/ib/SI4030N.pdf
Jun 15, 2012 | Irons
Would anyone have the instructions for the SI5040N Swan Steam Generator please? I would really appreciate it. michelle.darker@btinternet.com.
I have just bought a Swan SI5040N and would be able to photocoppy the instructions and let you have them or I can email them.
Jan 01, 2010 | Black & Decker Steam Generator SG200 Iron
I have a Swan S15040 steam generator iron, the stand by light is permanently flashing, no matter what temperature setting i put the iron on. No steam is generated. I have tried holding the steam button...
Jul 18, 2009 | Black & Decker Steam Generator SG200 Iron
I have bought a swan s15040n steam generator iron and it does turn on but I can't get to generate any steam. I have tried holding the steam button down for 20 seconds ( and more) but still nothing. Any...
Try holding the iron well below the base with the cord straight and pressing the steam button, this will release any airlock caused by a changing the filter
Jul 13, 2009 | Black & Decker Steam Generator SG200 Iron
Irons Logo
158 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
