Question about Trekstor DataStation Maxi x.u 320GB External (68143) 320 GB USB 2.0 Hard Drive
Trekstor DataStation Maxi x.u 200gb not install windows 7
4 Suggested Answers
  • 12 Answers
SOURCE: DataStation Maxi M.U. 500 Gb blinks red and blue, doesn't read
I just had this problem with both my external drives (I was using the same power cable and just alternating between them). I went and got drive B's power cable and they work fine now. Try replacing the power cable
Posted on Jul 29, 2009
  • 13433 Answers
SOURCE: I dropped my TrekStor DataStation maxi g.u - 3.5"
Hello
You need to understand that a hard drive is very similar to glass, if you drop it, its done for, and it breaks.
contact a data recovery service if you had something of importance in the drive, you will not be able to recover anything out from it yourself if you really dropped it.
they break, they can break even if the case falls over on it self on the table.
let me know if you have any other questions.
Thanks.
Ekse
Posted on Feb 04, 2011
bronk50
  • 27725 Answers
SOURCE: My computer does not reconize my Trekstor
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Posted on Oct 04, 2011
Windows 8 wont see my Trek Stor hard drive
See if your product is listed at the official manufacturer site
http://www.trekstor.co.uk/downloads-en.html
, or contact them there. Be very careful with other 'third party' sites that offer drivers; many are unscrupulous sites that will give you a 'driver' that contains spyware, or makes things even worse.
Dec 02, 2013 | Trekstor DataStation maxi m.u SATA 3.5"...
Need software because my computer says it needs to be formated
Improve the Fixya.com experience for everyone by voting!
Click on the following link for the official Trekstor DataStation Maxi mu site: Trekstar DataStation
If that official site doesn't provide you with the required driver, continue reading.
Click on the following link for the largest FREE driver database on the internet. Driver Download
All the best,
Ben
Jul 15, 2011 | Trekstor DataStation maxi m.u SATA 3.5"...
Hello
Thanks.
Ekse
Feb 04, 2011 | Trekstor DataStation maxi m.u SATA 3.5"...
How do I use the network resouce to fix my problem?
Connect the Trekstor to your network, and be sure that it has an IP-address.
On Windows, click Start
Click Run
Type \\192.168.xxx.yyy
where this is the IP-address assigned to the Trekstor.
The windows that opens will be a window onto the Trekstor's files.
Dec 31, 2010 | Trekstor DataStation maxi m.u SATA 3.5"...
I have Trekstor Datastation maxi 160Gb hard drive, I dropped it, making a terrible clicking noise, laptop or telly won't see it when plugged in, trying to remove casing, took 3 screws a long bottom, can't...
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Nov 08, 2010 | Trekstor DataStation maxi m.u SATA 3.5"...
Just need to ask, trekstor external HD light is
Hi, unfortunately your are probably right. You can buy a new hard drive and install your self as the cheepest option?
Jul 10, 2010 | Trekstor DataStation maxi m.u SATA 3.5"...
Trekstor TrekStor DataStation m.u stopped being recognised by PC
Have you tried going to the manufacturer's website and downloading and installing the drivers for your product?
Sep 03, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
Datastation m.u stopped working : (
Dropping a drive can be catastophic but usually isn't.
I suspect you may get lucky and find out it's just some of the circuitry in the trekstor shell that is damaged.
Take the Trekstor unit to your nearest PC shop and ask the technicians there to remove the Hard Drive and put it in a new enclosure to test it. If it works in the new enclosure, buy the enclosure and your done. If it doesn't work in the new enclosure then you may be suffering from worse issues that will require the help of a pro.
Either way let me know how you make out, if you need a pro for the next step, reply back with you location(Country, State, City) and I will refer you to the closest facility who can assist you.
Hope this Helps FixYa,
Chris
Aug 19, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
Not loading
You will need some kind of disc utility.
Open the utility with the drive connected and it should show up in the options of drives.
You should then be able to format the drive.
It should then be usable.
If not take it back to the shop..
Dec 16, 2008 | Trekstor DataStation maxi m.u SATA 3.5"...
Trekstor DataStation Maxi x.u 320GB External (68143) 320 GB USB 2.0 Hard Drive Logo
225 people viewed this question
Top Trekstor Computers & Internet Experts
Marcin
vojvodabudva
ray gallant
Are you a Trekstor Computer and Internet Expert? Answer questions, earn points and help others
