Question about Samsung Lands Phones
I have a samsung idcs 28d, how do I change the after hours message and time
  • 201 Answers
SOURCE: MLX-28D Corded Phone Change Time
The time is stored on the phone system, not the phone. You first need to know which phone system you have. This phone will work on a few different Avaya phone systems (AT&T and Lucent are now Avaya)
You can find all the manuals for free at www.avaya.com but you first need to know which system you have.
Posted on Jan 28, 2008
SOURCE: samsung idcs 18d
Wow thank you sooooo much! We were trying to figure this out at work, and Ramoth's suggestion worked perfect. Thanks again!
Posted on Nov 04, 2008
SOURCE: Samsung iDCS 28D Voicemail Problems
If you have administrator access use the following steps to change the code:
Access the Administratin Main Menu and select 4 for mailbox programming.
Select the mailbox to program. Dial option code 1402. The current value will be played. To hear the current value press 1, to enter a new value press 2, to hear the range of valid values press 3. Press 2 to enter new value. Enter the access code for the mailbox. The value you entered is played back. Press1 to save or 2 to re-enter. Press 3 to exit without saving. Press # to exiit or hang up.
Posted on Aug 06, 2009
SOURCE: I have a Samsung iDCS
Regarding "Same Problem": Probably said "unavailiable CBT"? In that case it's because a call button hasn't been programmed into the keyset.
Posted on May 27, 2010
PhoneSystems
  • 213 Answers
SOURCE: I have the samsung IDCS
Hi, all you need to do is to go into your voice mail via the voice mail key, once in listen to the prompts until it says ' to assign your no answer greeting'. The prompts give the option to listen and record a greeting, however make sure that you delete the original and record a new greeting other wise the messages play back-to-back! I've posted a video to help you to do this, or visit www.abbeytelecom.com for further advise
Posted on Jan 06, 2011
How do yo block a number on samsung idcs 28d?
^67 then dial the number. Test it out first by calling a phone of your own with caller ID. Also try turning off the "Show Caller ID" in the settings.
Aug 05, 2014 | Samsung Falcon iDCS 28D 28-Button Keyset...
How do I reset the time on the display ?
1. Press the transfer button and enter 200
2. Enter password ** 1234** default.
3. Enter 1 to enable
4. Press SPK button and enter 505
5. Display will read
OLD: 1040703: 1125
NEW:WMMDDYY:HHMM
For Monday April 7. time 1:00p.m
enter the following
104070313:00 and then press the Transfer button.
6. Display will return to normal..
Jun 12, 2014 | Samsung Ds-24d 24 Button Display Phone For...
Flashing red light with no messages
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Mar 30, 2013 | Samsung Falcon iDCS 28D 28-Button Keyset...
How do you reset the password on a Samsung iDCS 28D
From the Subscriber Services Menu, Press [#] [7] [1] ....you will then hear the old password XXXXX you will be able to change it...
The Manual for a typical Samsung iDCS system is available here....
http://www.samsungidcsphonesystems.com/pdf files/idcs 16/iDCS_16_user_ins.pdf
Jul 20, 2012 | Samsung Falcon iDCS 28D 28-Button Keyset...
I have a samsung idcs 28d keyset, and the phone is working but when I try to dial out it brings up the message SETUP_ACK msg! and it wont allow me to dial out or people to dial in, but I can still dial...
Don't know the model but if it is a PBX phone you have to program it to call out if you have extensions dial 9 to get out and so on ,its a lengthy process .Check your manual.
Mar 28, 2011 | Samsung DCS 12 Corded Phone
I have the samsung idcs 28d and I want to change the no answer greeting (if someone calls that is the message that they hear) How do I do that
Hi I am assuming that your are using the Samsung Voice Mail, if so to change the no answer greeting;
enter voicemail, press the Voice Message Key, the pass code will be set in default to 0000. Your mailbox will not function properly until you have put your voice message on. To do this, press option 0, followed by 5 followed by 7. When you have got the message you require press the #. If you regularly change your voicemail message, you must press 3, delete the original message and reset the message followed by the #.
have uploaded a video off http://www.abbeytelecom.com which explains Voice-mail in more detail, if you are operating a differant system then I can only suggest that you rafer to the relevant operators manual
Mar 17, 2011 | Samsung DCS 12 Corded Phone
We have a Samsung idcs 28d phone. How do you change a voicemail passcode if you do not know the current passcode to the phone?
Hi, unfortunately you have to go in via the engineering passcodes, your telecoms supplier should be able to help with this. there is written instruction regarding Voice Mail on http://www.abbeytelecom
Feb 11, 2011 | Samsung DCS 12 Corded Phone
How do i change my voicemail greeting on my samsung idcs 28d?
Hi, to change your Voice Mail greeting press your Voice-Mail key, enter your passcode, press 0 , 5 , 7 listen to your greeting, press 3 to delete and re-record your message. when you have done this press the # key to save. I have sent you a Voice Mail training video, i have over 65 others like it giving help and advise on the Samsung DCS.
http://www.abbeytelecom.com for written copy
Jan 29, 2010 | Samsung DCS 12 Corded Phone
Lands Phones Logo
43 people viewed this question
Top Samsung Lands Phones Experts
ray gallant
richie46
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
