Question about Watches
Instructions for avia-tec 149300
I need a instruction manual
Avia tec 187201 user guide
Try Googling (avia)(187201)(manual) without parens.
Apr 26, 2018 | The Watches
AVIA stop watch instructions
Try Googling (avia)(model)(manual) without parens to get instructions.
Mar 17, 2018 | Watches
Instructions for AVIA-TEC stop watch
Try Googling (AVIA-TEC)(model)(manual) without parens.
Removing the beep sound from an avia stopwatch?
If your Avia stopwatch has no option for muting the beeps, there is a very simple way to achieve a semi-permanent mute capability.
1. Using a small screw driver, remove the case back of the stop watch.
2. You will see on the inside of the back panel, a small circle stuck to it. This is the piezo speaker that beeps.
3. Take a small piece of tape and apply it to the speaker. Best choice would be a smooth painter's tape (blue) or electrical tape (black). But thick clear packing tape might work as well. It doesn't need to be a big piece -- just large enough to be in position between the speaker and the metal contact from the stopwatch module.
4. Re-assemble the watch.
5. Test for sound.
Jan 03, 2018 | The Watches
Where can i get a replacement battery for a Ohsen wr30m Watch?
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
Apr 01, 2015 | Watches
How do I cancel the Alarm setting on my Avia-Tec sports watch?
Hold in button on bottom right and press the top right button once and that should clear the alarm set. (the bell icon in top right of display should disappear). VL1500 Tony.
Mar 23, 2011 | Watches
Need instruction manual for citizen 3100 calibre watch
You can get instructions from the Citizen web site.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical
support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on
"get setting instructions"
Jul 24, 2010 | Citizen Eco Drive Calibre 3100 #BT0000 07E...
can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Jul 20, 2010 | Timex Sports Ironman Triathlon 50-Lap...
Instruction manual for invicta elite 9225 need help with the dials and need to know how to use it
Their web site gives a list of generic instructions which you need to
scroll through to find the section that suits your watch.
You can get an instruction manual by going to their web site
(www.invictawatch.com/), put your cursor over "collections" in the
menu across the top and then clicking on "instruction manual".
Click on the link below the "Invicta" logo and download the instructions.
May 21, 2010 | Invicta ELITE 9225 Wrist Watch
Watches Logo
56 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
