Question about SAMTRON 55V 15" CRT Monitor
56 V - faint horizontal lines across the display
This set was dead. IC 601 DP704C in power supply was burst. After replacing this IC, montior shows faint horizontal lines along with display. These lines are somewhat like we see when the monitor is in interlace mode. Is this due to filtering problem?
  • 2 more comments
  • Discoman Nov 27, 2007
    I can not find DATA SHEET for DP704C.Can you help me?
  • Anonymous Dec 31, 2007
    I am having a similar problem. Turned on this morning and there are faint horizontal lines...
  • postal111 Jan 08, 2009
    i have monitor using dp704c and HOT C5931.it shows power but after 2 seconds it goes of and on again with 2 seconds interval.and hearing a tik-tak sound in its relay...can any one help for this problem? thanks
  • KEMODATA1 Mar 26, 2009
    I HAVE SAME PROBLEM BUT I CHEC ALL PARTS IN DP CIRCUIT AND ITS APPEAR GOOD SO I WILL TRY TO CHANGE DP104C AND IF THE TRAIL SUCCESS I WILL TEL Y
U can search problem in vertical section may be sum IC component was dry resold them .
Posted on Nov 04, 2012
Replace all disks in SMPS section
Posted on Sep 28, 2006
How do I fix horizontal thin lines across the screen?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Sep 26, 2015 | Samsung UN60EH6003F 60" LED TV 1920x1080,...
My question about philips 21 ctv with ic tea1507p at power supply.when first time iplug in the set is run for few second but after that set dead.
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in the brand name of your device, in the search box [at the top right] of the display window. It will make surf easy.
Jul 03, 2015 | Philips Televison & Video
How to solve horizontal lines on a CRT TV monitor and what could be the possible courses for it
Monitor horizontal lines problems usually caused by a defective vertical output/driver ic. A missing supply voltage to the vertical output ic may caused similar faults which is one horizontal line across the display. Dry joints and missing vertical output pulse from vertical oscillator ic also could contribute the same symptom. If you discovered that the protection resistor (usually from 1 to 4.7 ohm) open circuit or burnt, then replacing it won't solve the problem. The resistor burnt or open circuit was due to a short in the vertical output ic. Thus you have to replace the vertical output ic and the burnt resistor together before you switch on the monitor.
Jun 12, 2015 | Televison & Video
Despite inserting new black cartridge (Brother LC57 BK), print is faint and on spreadsheets is blurred and has horizontal lines across pictures.
Hi
If a single inkjet in your printer is not functioning then output will appear as a horizontal line across the page. If one of the jets is on all of the time then output will have black or colored lines across the page. Use the following steps to isolate the problem: - Replace the ink cartridge - Check the flexible cabling for continuity and for short circuits between adjacent conductors - Exchange the control board for a good one - Finally check the power supply
Good Luck
Mar 09, 2011 | Brother MFC 210C All-In-One InkJet Printer
Please give me z card i need some so bad please!!!!!!!!!!!!!!!!!!
You may have one of two problems. A vertical one in which you may have horizontal lines across the top of the screen. Or one bright centered horizontal line. The fix here is to resolder the vertical IC and replace the capacitors near and next to the vertical IC. The second problem would be the dead set. In this case , the power supply will need reworked. You will need the following components. Replace the powerline regulator STR53041, the regulator N4923 and capacitors of these values, 25 volt at 100 MF and a 35 volt 22 Mf. these components are near and next to the regulator STR 53041. Now,next to or in front of the flyback transformer there is a small cap at high voltage...I believe this one may be a 200 volt at 1 or 2.2 Mf. replace this, and the other capacitor near two heat sinks on the edge of the board in front of the vertical IC is a 25 volt 220 Mf cap that is also dead. It has been a very longtime since I have repaired this one. But the information, will get your TV up and running again! Find an electronic hobbiest or a TV tech to repair this for you. This info will help you get a reasonable repair bill. Thanks for asking and show a few hands of support.
Jan 30, 2011 | Zenith B27A11Z 27" TV
My Samsung HL56A650 turns on, but no picture. We were watching it, and the picture just quit. When you turn it on now, the power recycles several times then all you get are 5 or 6 thin horizontal lines...
Now ur tv still get a solid power LED light?Yes,only few colors strip lines show up,mean ur tv board that call the T-CON decoders board is dead.This T-CON decoders board sit in the niddle bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Jan 23, 2011 | Samsung HL56A650 56 in. TV
No picture, only a horizontal line across the screen
Hi and welcome to FixYa,
Your described problem indicates failure at the vertical deflection circuitry. Almost always, this would be a defective vertical IC. In some instances, this could also be caused by the absence of Vcc (supply voltage) to the said IC. This is a relatively easy/quick repair. What would be more challenging is identifying the IC, removing it, and replacing. Replacement would be readily available from most electronics part stores including Radio Shack.
Good luck and thank you for using FixYa.
Feb 24, 2009 | Zenith Televison & Video
JVC AV-K21TR
The faint white lines at the top of the screen is the warning that the pump-up capacitor in the vertical output circuit is going bad and the output itself is about to short out. When the TV stops working, the vertical output IC has finally shorted out. Replacing the vertical output IC, the pump-up capacitor and possibly a small value resistor next to the flyback (B+ for the v-out) should bring the set back to life.
Jan 26, 2008 | JVC AV-27230 27" TV
Mitsubishi cs-35401television
HORIZONTAL FAILURE AND LINE DOWN THE SCREEN. REPLACE T5A1 LOCATED ON PCC-3-PCB. PT#349P145030(FOR CS-35401,CK-35402 ONLY) Hope this helps! Troy
Sep 11, 2007 | Televison & Video
SMPS IC for Samsung 753S Monitor
Can you help me about SMPS IC DP704c on jitendereco@gmail.com
Aug 18, 2006 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
700 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
