Small plastic cover with part number 44314
We were repair my washing machine, when we closed the covers after finishing repair , we missed to locate a small plastic cover belong to the washing machine and written behind part# 44314 it is triangle with about 10x5 cm , we dont know where it should be placed , we tried everything, but we did not find out where the right place . any idea or any help ???
  • 1 more comment
  • mohramohra Oct 25, 2008
    dear silver top :
    1) the repair done on the control panel due to the problem related to stop spin and rotate of the washing machine.. my husband did it., there was some defected parts in the module ( he is a so genious electrical engineer/power).
    2) the color of the cover is grey on pistage . see a real photo of the cover here (back and front):
    http://img201.imageshack.us/my.php?image...
    I realy appreciate your help .
    Dear silver ; if you mean by dust cover , the thing which save the dust of fibers and materials of the clothes, and located in the bottom of my washing machine model (WFM 2010) , I checked and from the first look I saw it is not at all... I wrote hereup the model ,realy appreciate your help .
  • grant weatherall May 11, 2010
    wot type of machine is it
  • 566 Answers
Out of curiosity ?? what repair have you carried out and panel/s did you need to remove? what colour is cover and any screw?holes in it? alsoas prev question what make is machine
Posted on Oct 22, 2008
  • silver top Oct 25, 2008
    hi thanks for update/ pictures looking at the cover? the 2nd/reverse side has 2x prize to release hook clips on the ends yes? i would be inclined to look at the component your hubby attend to/fix i suspect this is a dust cover off the top or bottom of i suspect rotating timer module that sets for type of wash you req ? and feel sure he will locate its position and be able to fit without strip down ? hope this helps jog hubby's memory ? i will try to verify its location and will get back asap in mean time best wishes
Printer brand brother model DCP-J125. does not working properly, Close ink cover has appear the LCD monitor
The sensor for this is actually used for both the scanner cover and the ink cover,
there are two flags that both must sit into the sensor to reach a ready state.
If you examine the ink cover there's a small piece of plastic that paths into a hole on the machines frame. This piece of plastic pushes a small black plastic flag that tells the sensor the door is closed.
If it's constantly telling you to close the ink cover inspect both the cover itself to verify that piece of plastic isn't broken and is going into the hole; and look inside and verify the flag isn't broken or damaged (flashlight and a small eyeglass screwdriver help here)
Either can be fixed for cheap at any reputable printer repair shop, I would look for a brother warranty place even if it's out of warranty as they'll be more likely to have donor machines sitting around for spare parts.
Jun 01, 2011 | Brother Office Equipment & Supplies
The clear plastic door cover of my Bosch front load washer has come loose at the top, so that when it spins, it vibrates. From the "looks" of it, seems like there are supposed to be 4 screws that...
Try sealing the dome onto the door with silicone sealant. Smooth it well into the inside of the door so that it will not be caught by the washing. Also smear liberal amounts on the outside to hold the dome in place, but smooth it off for appearance sale. Smoothing is best done with a wet finger to leave a good finish.
Mar 11, 2011 | Bosch Washing Machines
Water is leaking out from under the front part of the machine (this is a top load machine). Doesn't matter whether use small or large fill. have checked hoses and drainage in back they are not leaking....
have u checked the pump that is located iin the front of the machine? Remove the entire cover of the machine look down in the very front when the cover is removed turn the machine on and you should be able to see exactly where ur leak is coming from your pump is located on the motor small white or grey plastic round like object sometimes it can leak fromthe center of the pump in any case test the machine with the cover off and you willbe able to find the leak hope this helps
Jun 24, 2010 | Washing Machines
Indesit WG1234T - is there a filter and spin cycle not effective
If there is no filter located at the bottom right front of washer behind a re- moveable cover, then you need to remove the rear cover of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should help solve your prob.
Jan 05, 2010 | Indesit W 123 Front Load Washer
The top off Hotpoint WMA35 washing machine?
Located at the front end of the top cover, are 2 plastic covers, prise them out with a small screw driver or something similar, and inside are 2 torx screws, get a torx screwdriver, and undo the 2 screws, if tyou don't have the correct screwdriver, you may be able to undo them with a small screwdriver.
Give the top a good hard push towards the rear, and it should come off..
Hope this helps.
Dec 28, 2009 | Hotpoint WMA35 Front Load Washer
Error message - can not print
Try checking the little "trip switch" that is actuated when oyu close the cover. To find it, locate a small plastic tip in the cover that goes into a small hole when you close the cover. This tells the printer when the cover is opened or closed. Should be on the right or left side of the cover towards the front. The tip may have broken off OR the switch is misaligned. If the tip is there try GENTLY inserting a small screwdriver into the hole and see if that solves it. Otherwise, it is a board malfunction...
Nov 25, 2009 | Dell 922 All-In-One InkJet Printer
Lg wf-s6607tc
This is probably a lid cover open protection. Check to see if there is a magnet on the cover, positioned almost to centre (slightly to the right) at edge of the cover. There is some sort of plastic catch to house the magnet. If it is not there, place a magnet at the corresponding area on the washer where the plastic catch will touch when the lid cover close.
Aug 16, 2009 | LG WFT1071TP Top Load Washer
Broken battery compartment door switch
The switch is a micro switch that is depressed(and not sad :)) by a plastic tag moulded on the battery cover. Once the cover is moved into position and closed, the tag presses on the micro switch closing the switch and thus removing the error message. As with any switch, a switch is simply open or closed, Open = high resistance or O/L, while closed = 0 ohms reistance. You can use a small wire to overcome the switch by soldering the wire to both tags of the switch so it is permenantly 0 ohms. This will send a message to the microprocessor that cover is closed and camera ready for use. Hope this helps.
Twitcha
Sep 28, 2008 | Olympus FE-140 Digital Camera
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
