Majestic electric fireplace: flame doesn't flicker
When I turn on the fireplace, the "flames" light up, but they no longer flicker (to simulate a real fire). Any idea what controls this function? Is it easy to repair?
detox101
SOURCE: Gas fireplace pilot flame won't stay lit.
Hi , you can try and pull the panel on the bottom of fireplace out and check the adapter in fireplace. Sometimes they go bad. When you open in also check to see if there is an adapter plugged in and a option to use the battery operated function. If this goes bad the pilot will not stay lit.
Posted on Jan 14, 2009
SOURCE: my heat n glow fireplace comes on fine with all
Therinnaiguy - Thanks for the response and I have a follow up comment adn question.
I'm having a similar problem with a Heat'n'Glo fireplace in a new house I just bought. Fireplace lights but goes out after 10-15 seconds .. and yes I think on mine the flames do go all blue and lift up as it extinguishes from right to left.
My fireplace has the Direct Spark Ignition (DSI) so there is no pilot light. Besides the igniter connecting to the DSI module below, there are not any other sensors connected (unless there well hidden or one is wrapped in the igniter).
The LED on the DSI module blinks fast when turned on, which indicated "Normal Operation. Call for Heat." Before all the flames go out I can hear the igniter try to relight a few more times.
Any additional thougths on the problems? What should I do to ensure that the vents are not plugged or anything?
Posted on Nov 06, 2009
  • 6 Answers
SOURCE: I have a pyromaster electric fireplace model HEF
Unplug the motor wire connector and jump it with a 9V. battery. If the motor spins it's good. Chances are the FLAME SPEED CONTOL (Part Number 10001589) circuit board is bad. I had to replace mine. It's at the bottom of the fireplace behind the contols panel.
Good Luck
Perry Gibbs
Posted on Dec 05, 2009
  • 3 Answers
SOURCE: Charmglow electric fireplace flame does not
You will have to connect a 12v dc power supply to the flame motor. The controller on the board has fried. I built a regulated 12 v dc power supply and tapped it into the bulb circuit so it will power the motor when the bulbs come on. You may have to find an electrician or techie to rig this up safely.Good luck!
Posted on Dec 28, 2009
  • 2598 Answers
SOURCE: Martin gas heater with logs flames hot but hard to see.
Hi do you the make and model
Posted on Feb 12, 2010
What kind of a light bulb is needed for the febo flame electric fireplace?
Flickering flame fires generally use a fairly ordinary tungsten filament incandescent bulb, except the Fireglow bulbs are coated with an amber coloured lacquer. The heat from the bulb causes an upward current of air causing a small "windmill" to turn and cause the light to flicker.
That is the traditional method but ultra modern fires might use a higher-tech solution.
Oct 22, 2016 | Heating & Cooling
Tip
Portable Heat Flame Electric Fireplace
Electric fireplaces are becoming more and more popular with today's homeowner's. The main advantage of the electric fireplace is generally portability, convenience, low initial cost is important. They also are a good choice when the looks are not as important as function.
Some electric fireplaces have simulated flames that give the look of traditional fireplaces. Another great option to include is a built-in fan to help distribute the heat more effectively. With some of these high end units it can be very hard to tell the difference between an electric fireplace and a wood burning stove. Along with this option may come a heatless setting the will give the look of flames but produce no heat. The remote control has also found its way to the fireplace market. There are many units that can be remotely controlled.
Electric fireplaces are generally cheaper than gas fireplaces. A good unit can be bought for about $500 (there are cheaper models available, but they tend to have fewer options and the flames are not as real looking). These fireplace units are fairly easy to install compared to a gas fireplaces or wood-burning stoves (both of which usually need flues to vent). If you can plug in an electric cord then this type of fireplace may be for you. The electric units are perfect for apartment buildings and condominiums. These places are not suitable for the traditional wood fireplace.
Just like other types of portable electric heaters, electric fireplaces will radiate heat very quickly extreme care must be taken to not have any combustibles too close to them.
You will see how an electric fireplace can transform any setting for you. The newest modern, advanced electric units have far more aesthetically appealing views. They might include fiber optic displays, or randomized lights designed to make the look of dancing flames.
Now whether you're living in a condo or apartment and can't have a real fireplace, the electric fireplace can be a great way to get some of the warmth and ambiance. Also remember that these units are very portable, so you can take them with you when it's time to move. Even though I have never been a big fan of electric fireplaces, because of the expense of their operation, I can see why they would be very popular with many apartment or condos owners.
http://www.fixya.com/support/r3707111-flame_electric_fireplace_electric
on Dec 25, 2009 | Heating & Cooling
Tip
Flame Electric Fireplace Electric Fireplace Heat
Fireplaces have become the heart of the home, a warm place to gather with friends and family. Fireplaces turn any blank wall into a gorgeous focal point. A fireplace fits any decor and is a stylish addition to any room. Electric fireplace logs have improved greatly over the past few years and now days can look so good that they can fool people into believing that they are looking at a real fire, something which is especially true when you have crackling effect of fireplace logs, which aim to imitate the sound of a real fire.
Even though electric fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. If you need a fireplace to heat your home you may want to consider a gas fireplace for better efficiency. If you need a fireplace for more decorative purposes a cheap electric burning unit might better suit your needs. The electric fireplace has experienced a quantum leap from those electric logs with reflective tin foil drums that adorned the hearth while the lava lamps were in vogue. An electric fireplace can add a great deal to a home, in terms of both form and function, and are also very effective at heating up a room.
Electric fireplace heaters simulate the look of a fireplace, but don't actually burn gas or wood like a traditional fireplace. Electric fireplace inserts simply fit into existing fireplaces and provide an artificial fire that creates the warmth and ambiance you want with just a flip of a switch. A modern electric fireplace insert does not require any type of venting system and many units are portable.
Even though these fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. They plug into the wall, and can run on a "flame only" setting, or can be used as a heater, typically with 4,500–5,000 BTU (4,700–5,300 kJ), that can heat a 400 sq ft (37 m2) room. Since there is no real flame or combustion taking place, electric fireplace heaters release no toxic fumes or dangerous gases.
Everyone knows that a fireplace is about more than heat, especially when you're looking at a real fire, when one of the most entrancing things about it is the fact that you can see real flames. Most electric logs use a standard 110 volt power source, and come with various levels of flame of brightness. By choosing a really good set of electric fireplace logs, and particularly those which have a crackling effect and real flames, you can be assured that your fireplace will not be simply a unit in the room to make the room feel warm, but will be something that you enjoy looking at as well.
Electric fireside inserts are also a good option if there are issues with your hearth which make them a hazard with wood burning fires. Electric fireplace log inserts typically include an electric fireplace log set and an ember bed, and inserts are incredibly easy to install. Electric fireplace inserts are safe and clean. Most importantly whether you choose a modern electric fireplace or any other type make sure it will be most cost effective and suitable for its purpose in your home.
http://www.fixya.com/support/r3710316-portable_heat_flame_electric_fireplace
on Dec 24, 2009 | Heating & Cooling
Flame has stopped flickering on our Century Heating electric fireplace, model HEF26. Fuses or motor?
Probably, neither. If there's no brightness at all, the bulbs are burned out and need to be replaced. If the brightness is there, but no flickering, then it's probably the motor or the shaft that the bulbs are on is stuck and can't rotate. Really not an uncommon problem with electric fireplaces, no matter who the manufacturer is. If you don't hear a humming noise when the flame function is turned ON. the motor may have overheated and shut down.
To test this, turn the Master ON/OFF Switch to OFF and unplug the fireplace from the wall outlet. Wait 12 - 15 minutes. Plug the unit back in and Turn the Master ON/OFF Switch to ON. Turn just the flame function ON. If it starts right up, the motor has cooled and the unit reset itself. If this continues to occur on a regular basis, contact the manufacturer's Technical Service Dept. If nothing happened after it was turned back ON, contact the manufacturer for replacement parts.
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
May 04, 2011 | Heating & Cooling
Flame does not flicke in my electric fireplace
if flame not flickering and you can see the globes lighting flame its the fan that moves the ribbons is faulty unless it has fuse to it which may have blown, but how the flame works is by globes lighting through ribbons that are moved by a fan to give a flicker effect unless its rotating glass wheel like some, that turn with the globes behind that give you a flickering effect its always better with electrical to have an electrician look if it was the globes yes that is an easy replace but to change a fan or rotating glass wheels
Nov 28, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
I have a pyromaster electric fireplace model HEF 33..my flame does not flicker ,it lights upand heats but no flame
I have the same model and problem there must be some part to get to replace it it seems to be a motor problem. would appreciate any ideas
Nov 09, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Pyromaster electric fire place motor for flickering flame
Any Vermont Castings stove dealer can order the parts for you.
Apr 04, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Flame doesn't flicker
The "flicker" function in my unit operates with a system of rotating, reflective fins. The tiny, AC synchronous motor driving the fins failed and I got one one-line for cheap. A fairly simple R&R.
Only downside is the motor does not always start in the proper direction, but a start/stop or two resolves the issue.
Apr 08, 2017 | Kitchen Appliances - Others
Chicagao electric fireplace heater doesn't work
MY HEATER NOT WORKING,BLOWER AND LIGHT COME ON NO HEAT
Oct 25, 2008 | Heating & Cooling
Replace light bulb in a Charmglow electric fireplace
you have to remove the doors and then the lower ember cover, he lighs are underneath.... i am looking on how o make he flame move, it froze and won look like real fire anymore
Oct 21, 2008 | Kitchen Appliances - Others
Heating & Cooling Logo
101 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
