Question about Husqvarna Chain Saw 20" Bar
Husqvarna chain saw oiler
MY husqvarna chain saw stopped oiling. Resevoir is full, but the chain is dry. what is the problem and the solution.
  • 1 more comment
  • gusplaer Dec 26, 2008
    Anyone know where the oil adjustment is on an older 380 husky? Late 70's model? gusplaer@hotmail.com
  • Anonymous May 09, 2009
    The first time I used our Husqvarna 141 it would not oil, they replaced the oil pump but it did not fix the problem.
  • Anonymous Mar 18, 2014
    i just got this saw worked good for an hour then started to rev up and down when the throtle is at full
My Husky 36 did this. The oil pump drive gear was stripped and had to be replace. It's located under the flywheel/sprocket so you have to pull that. I couldn't find info on how to do that so had a local shop repair it for $70! Parts are cheap, labor is not.
Posted on Nov 11, 2008
  • aminor295
    aminor295 Aug 09, 2012
    Thanks! I had the same problem on my 350. Managed to get the clutch off by carefully stuffing rope in the spark plug socket and using large channel locks on the reverse threads of the clutch (I didn't want to buy the tools). The pump drive wheel was clearly stripped. Thanks again.
Hi!
Oil pump mechanism is broken or the oil exit is clogged
Mark
Posted on Oct 24, 2008
HOW AND WHERE TO ADJUST THE OILER ON THE 240 HUSQVARNA
The Husqvarna 240 does not have an adjustable oiler. Always use good quality bar and chain lube, never motor oil.
Jun 14, 2014 | Husqvarna Garden
My husqvarna automatic chain oiler doesn,t work...235 husqvarna any fixes?.
You may have gotten some saw dust particles inside the oil resevoir that got sucked into the delivery tube, thus clogging up the oiler...you can drain the oil out of resevoir and run some seafoam thru the oil resevoir to see if you can get it unclogged
Jan 23, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Excessive oil from the chain oiler. oil resevoir is empty and fuel is still 3/4 full. Saw is two weeks old. Oil sprays off the bar.
What kind of oil did you put in there?? The bar and chain oil is so thick, i can't see it slinging anywhere, you must have used 2 stroke in there. It's OK, That is all I use in my Husky, but it doesn't sling off. I don't know if you have a part missing or what, but there is a little damper right under the chain guard. Check it out, hope this helps.
Oct 19, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Can't seem to get my oiler to work properly. oil emerges when i run the saw with the bar removed, but chain is dry and hot when run put together.
Some saw manufactures design their oilers to only work with their bars. Are you running the mfg suggested or stock bar? Chain? Stihl Chain is designed to use 30% less oil because of oil groves cut into each drive link directed to the rivets. So if your running an aftermarket bar/chain, the oiling ports may not line up. Especially if it oils with no bar & chain
Oct 09, 2010 | Husqvarna Chain Saw 20" Bar
Bar & Chain combo interchange
A longer bar will allow you to cut larger trees easier but if you don't need to cut larger diameter trees and just want to cut faster you can get a more aggressive chain but use caution as you should be VERY experienced as the chain has the ability to pull you right into the work if you are not careful! Using a very aggressive chain should only be done by professionals with full safety gear.
Jul 31, 2010 | Husqvarna Chain Saw 18" 450 Model...
I have a husqvarna 235, my oiler has quit working. I pulled the clutch assembly & cleaner the oiler gear but still no oil, resavoir is full
If you spin the oiler with the when it is desmantled does any oil come threw? (if so then the drum may not be linking to the oiler properly) also check the screw that determins how much oil is coming threw is turned up. And check the filter in the bottom of the oil tank is not blocked
  • Open in Google Docs Viewer
  • Open link in new tab
  • Open link in new window
  • Download file
  • Copy link address
hope this helps a bit
Apr 21, 2010 | Husqvarna Forest & Garden #952802239 235E...
Problems with the 350 husqvarna bar.
If all you say is true and when revved up the saw oozes oil with the bar removed, then I suspect the bar is incompatible with the saw. Has the bar been replaced? The oiler holes in the bar must align with the channel in the saw. Oiler hole placement is part of the reason there are so many different part numbers for bars. The mount is only part of the requirement.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 03, 2010 | Husqvarna Forest & Garden #952802239 235E...
Husqvarna chain saw oiler problem
I fear you are correct about the oiler problem. I see a lot of oiler problems on these saws. Sooner or later Husky will have to address it. Ask the dealer about modifying your oiler; the 350 has an adjustable and might fit 1 or both of these saws. I think Husky needs to admit the nonadjustable is a mistake, and come up with a fix.
If you want to do some research start with the IPLs here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Please post back (below) with what happens at the dealer. Take your buddy and his saw with you! Good Luck. HTH
Lou
If Husky starts modifying all these with 350 oilers I want compensation...LOL
Feb 17, 2010 | Husqvarna 450 e-series 18" Chain Saw
Ryobi 40cc chain saw oiler not working correctly
Hi
Check and clean the oil filter from oil tank.Check the worm gear wich engages with the oil piston pump(under the clutch).Near the hole where the oil comes out from oil tank there is an oil tank valve(see if it is clogged),it equalises the presure between interior and exterior of the oil tank.
best reagards savumihai71
Dec 23, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna chain saw, model 455 will not oil properly bar and chai
hi cindilou50
check the oil filter from the oil tank,the oil line ,the worm gear and the oiler under the clutch.Clean the ways where the oil goes with compresed air.(after you fill out the oil tank)Also check the oil hose.
best regards savumihai71
Nov 30, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna Chain Saw 20" Bar Logo
3,752 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
