Question about GE GSS25SGMBS Side by Side Refrigerator
Reviews on GE refrigerator model GSS25SGMD BS
  • 24 Answers
SOURCE: we have a ge side by side and the refrigerator is
Is it all areas of the fresh food side that are freezing your items, or is it the drawer area?
There is a direct connection (on my GE side-by-side, at least) between the freezer compartment and the drawers in the fresh food compartment. The size of the connection is controlled with a wheel or a slider. This could contribute to freezing in that area of the fresh food compartment.
Otherwise, it could be the temp sensor(s) in the fresh food compartment. If the computer thinks the temp is too high in the fresh food compartment, it will continue to cool.
It could be a problem with the motorized door that connects the freezer compartment to the fresh food compartment, located at the top of the dividing wall between the compartment. That door should close when the temp in the fresh food compartment is cold enough. If that door mechanism has failed, is disconnected, or otherwise blocked in the open position, cold air from the freezer compartment will continue to circulate into the fresh food compartment.
Posted on Jul 30, 2009
aasc
  • 1606 Answers
SOURCE: where is the thermostat on a GE profile refrigerator Side-by-Side
There is no thermostat ( cold control ) on your model refrigerator . It works off thermistors ( 3 in the refrig section and 2 in the freezer section ) . These thermistors , operate by the coldness which in turn , less resistance to the main control board the colder or warmer it will provide .
Posted on Sep 12, 2009
marka19
  • 1430 Answers
SOURCE: Refrigerator is too cold (28 degrees)
this is likely one of the thermistors on the fresh food side has failed. They are usually located under a small cover inside the fridge. They should have a reading of 15.5k-16.5k ohms at 72 degrees. They are easy to check and replace. Here is a link that should help. You can also enter your model # for diagrams and illustrations of your specific model. http://appliancehelponline.com/sxsfreshthermistor.html
Posted on Jul 16, 2010
  • 1891 Answers
SOURCE: the middle black strip on
this is the wall between the freezer and the frg i think . it is warm when the compressor is running . and if hot / then look under neath unit and i thing you will fing the coils ar very dirty or the fan is not going or both . so clean coils every 3 to 4 times a year and repl fan if it has failed . and things will get better .. ,mm
Posted on Aug 17, 2010
  • 351 Answers
SOURCE: I have a GE Profile side be side refrigerator
hi sound like you have a bad damper. the damper is in the top of the refrigerator side from middle to left
Posted on Oct 19, 2010
My freezer has stopped freezing on my GE
sounds like the compressor has quit running or there is a Freon leak... either way it looks like a sealed system issue..... on some ge models if the cond fan motor quits it will heat up between the ref and fzr doors....
Oct 09, 2014 | Refrigerators
Ge profile arctica model #ps123sgna bs, leaking water from fresh food side?
Plugged or frozen drain pan located under the evaporator (cooling coil), located in the freezer.
Aug 31, 2014 | GE Profile PSW26P Stainless Steel Side by...
Freezer only getting 48' and frig side is only at 49 degrees
take the back panel off and see if the fan is running and if not see if it has power to it if it does replace the fan and see if ur problem is solved the coil underneath the fan should not be frozen even if the fan is gone out this could be a sign that the lil black element that runs through the coil is gone out now if all this is good and still same problem ur probably gonna have a freon issue and unless u know how to charge one i advise u call a tech and if its only 6 years old yes it worth trying to fix
Mar 01, 2010 | GE GSS25SGMBS Side by Side Refrigerator
GE Side by Side Heating Up and Frost on Panel in Freezer
sounds like your defrost heater termanator switch,or defrost timer is bad-mike
Jan 22, 2010 | Refrigerators
I have a GE model GSL22JFPH BS refridgerater and
Then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . There is a heater for the water dispensor tube , pt # WR49X10173 , which should keep this from happening again .
Nov 18, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Where is the thermostat on a GE profile refrigerator Side-by-Side
Sep 12, 2009 | GE Refrigerators
Howling Refrigerator
I am having the same problem with my GE 2005 refrigerator. Anyone find a solution yet?
Apr 17, 2008 | Refrigerators
GE GSS25SGMBS Side by Side Refrigerator Logo
111 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
