Washing machine edesa 1L -84 IS NOT EJECTING WATER AFTER WASHING THE CLOTHES
WASHING MACHINE WAHES CLOTHES BUT NOT EJECTING WATER
  • 1294 Answers
SOURCE: washing machine stops mid-cycle and full of water
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 06, 2008
  • 1294 Answers
SOURCE: Does not Spin out the water at the end of a load
If it spins the balance is okay. Check out your filter now. And then the pump (after the spigot prob below) Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
SOURCE: washing machine not spinning or draining water
I have the same washer, WT-R801. Does the machine stop all together when the spin cycle arrives?, if so check the pump on the drain. Mine was burnt out. Its available for $61.00 delivered from Adelaide. Steve.
Posted on Mar 31, 2008
SOURCE: My Washing machine stains clothes;
my washing machine leaves stains on my black clothes only
Posted on Oct 12, 2008
MNTECH
  • 1543 Answers
SOURCE: Visible water level in front-load clothes washing machine?
Yes, it is normal. There is water in the machine. One of the big draws for this style machine is that they use much less water than top load machines. If you stopped the cycle and opened the door, dug down in the clothes, you would find water. The machine fills a small amount of water (below the level of the door) and tumbles. As the water is absorbed by the clothing, the water level drops, so the machine adds more to maintain the water level. This is basically how the washer figures out how big your clothes load is and how much water that load needs. (Of course most sales persons at the big box stores and Sears have no idea how this works)
If you'd like, try running a cycle with no clothes to see how much water is in the machine. (It's not a lot) Now remember this: Because there is so much less water use than a top load machine, you must cut way way way back on the amount of soap and fabric softener used. Use no more than one tablespoon of HE (High Efficiency) soap (even less if it is 2x or 3x concentrate) and one teaspoon of fabric softener per load !!!!!
This should be a Fix-Ya for your question. Thanks.
Posted on Dec 14, 2008
How do i fix my washing machine,it only drains water instead of washing clothes.
call a service technician as it may be a faulty program board
Nov 20, 2015 | Washing Machines
How to more dry after completed washing
A washing machine does not really dry clothes. All it does is that it helps remove most but not all water from the clothes by spinning the clothes at a very high speed and the water comes out because of centrifugal force.
To further dry the clothes, you need to buy a clothes dryer. This machine has a heater inside that actually dries the clothes while keep it spinning at a slow speed.
Usually the company that made your washing machine will also have a dryer in the product portfolio.
Hope that helps
Feb 22, 2015 | Washing Machines
My moms pipes froze to her washing machine. They thawed and the machine filled with water but they won't wash. She can hear a buzzing sound like the machine is trying to wash the clothes but nothi
Yes , I think the valves also must have jammed in the process and when the hot water filled up in due course it must have released.
It is best to switch off water supply to the machine in such times.
Jan 23, 2013 | Washing Machines
Water does not drain automatically wahes and spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 04, 2011 | Washing Machines
I have whirlpool washing machine AWZ475, after starting it take water in & at the same time ejecting too, and stops warking.
Sounds like your water is being siphoned out as its going in. Check your drain pie and make sure it rises over half way up the machine before it goes into the drain. Hope this helps
Feb 28, 2011 | Whirlpool Washing Machines
Is it any user manual available in the web? I could not find any :)
i dont think you can but you can use the instructions below to operate you washing machine
Washing machines may have different technology, but ultimately have the same features and purposes. They all require the proper settings, soap, water and clothes to wash. Yet, there are some things you should know to properly use a washing machine. Follow these steps for success in doing your laundry.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
Instructions
  1. Read thoroughly your washing machine owner's manual. These instructions are designed for your particular washing machine. If you don't have an owner's manual, read the button control labels on your washing machine to get an idea of what they do.
  2. Sort your clothes. You should wash white or light-colored clothes together and dark-colored clothes together. Clothes should be further sorted according to their material. Heavy fabrics should be washed together and light fabrics should be washed together.
  3. Add detergent to your washing machine. Follow the instructions on the detergent box. The detergent should go on the bottom of the washing machine unless your washing machine instruction manual specifies otherwise.
  4. Use the special bleach or fabric softener dispensers for your particular washing machine, if you are adding bleach or fabric softener. Otherwise, follow the instructions on the bleach and fabric softener packaging to find out how much and when you should add them to the washing machine.
  5. Load your clothes loosely into the washing machine. Load the laundry as high as your owner's manual specifies or to the top row of holes in the tub.
  6. Close the lid and set the controls of your washing machine according to what you are washing. Use hot water for only white cottons. Use warm or cold water for colored fabrics. Set the other controls according to the weight and durability of your clothing.
  7. Turn on your washing machine. Allow it to work through all of the cycles and turn itself off before you unload the washed laundry.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Tips & Warnings
  • If you're going on vacation or not going to be using your washing machine for awhile, turn off the water faucets to your machine. It will relieve pressure on hoses and valves and minimize any leakage, should it occur.
  • Do not leave coins, nails, screws or anything else in the pockets of your clothes when putting them in the washing machine. They could easily cause damage or even puncture a hole in the drum.
  • Do not wash items that have been spotted or soaked with combustible substances. They could ignite or explode.
  • If you haven't used your washing machine for at least two weeks, and haven't used any hot water in your household, turn on your hot water faucets. Allow them to run for several minutes to release any built up hydrogen gas in your water heater.
Jan 09, 2011 | Washing Machines
No water comes into my clothes washer.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Oct 20, 2010 | Washing Machines
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
