Question about Toastmaster 1193 Bread Maker
Crust is too hard!
Love my bread machine but the crust is so hard! It's very soft inside but its like cutting into a rock.(-: What am I doing wrong?
  • 3 Answers
First be sure your dough consistency is correct.
It should be very soft almost sticky. To make it a bit softer you can
add an extra tablespoon of fat.
Posted on Mar 17, 2010
Bread crust burns even on "Light" setting
Contact Oster for advice. Here is their contact info-
https://www.oster.com/contactus?cid=contact-us
Jul 28, 2015 | Oster 2 Lbs. Deluxe Bread & Dough Maker...
Bread sticks to the pan and the dough blade what am I doing wrong
It is not uncommon for the paddle to get stuck in the bread loaf especially with thick crust breads (i.e. french) Be sure to choose light crust and sometime using milk instead of water help too.
Feb 08, 2013 | Kitchen Appliances - Others
My bread is massive and with the crust in hard lumps the entire 3lbs bread is usless.
Hi...Try making a smaller bread...say 2lbs or even 1-1/2. A 3 lb bread is way to much. Hank
Feb 21, 2011 | Black & Decker Bread Machine
Why is the crust on my bread hard? I follow the basic recipe to the letter. The bread is nice but I waste so much as I have to cut the crust off.
Replace the recipes that call for water with milk. Your bread will be softer and much lighter crust and will be healthier too. Be sure of course to choose light crust.
Nov 25, 2010 | Breadman TR2500BC Bread Maker
The crust of the bread is thick and hard. What is
Are you using water? Water will make a crust crunchier, while substituting milk will give you a squishier crust. Also depends on what kind of bread you're making.
Aug 06, 2009 | Breadman Kitchen Appliances - Others
Bread comes out hard, dense, lump
I had a similar concern with a different breadmaker. Finally gave up and settled for a different setting and it seems to mix, and rise fine but have to settle for a different texture/hardness for the crust. I can only guess some computer chip has failed in that setting!
Mar 13, 2009 | Toastmaster 1183N Bread Maker
The bread is too dry
Welcome to FixYa, if you appreciate our solution, please rate our services.
Breadmakers usually don't have as many crust settings as this one does. Darker crust settings usually equate to dryer bread because the bread bakes longer. The longer the bread bakes, the more moisture is removed. Accordingly, if you've tried this many recipes with dry texture, try progressively lighter crust settings until you get the moisture you desire. As for me, I rarely bake my bread in the machine (I don't like the hole in the bottom of the loaf). I do, however, appreciate the dough setting which does all the hard work, and I just bake it in the pan. I think the results are better and I get a better shaped loaf.
If this information has been helpful, don't forget to give me an appropriate rating. Thanks again and good baking!
Jan 30, 2009 | Black & Decker B2300 Bread Machine
Hard crusts
I have an OSTER Breadmaker but if I wish a very light crust I simply turn the machine off 10-15 minutes early and leave the lid closed, which keeps the steam in and allows the crust to be softer. Then I have a new cold stick of margarine or butter, unwrapped part way, and slowly pass it over the top and sides of the new bread loaf. Sometimes due to weather changes or altitude we need to adjust our recipies, from those in our manuals. If your kitchen is 10-15 degrees warmer in the summer this can affect your machine. As with the amount of moisture in the air. My Gramma never made bread if it was rainy or a snow storm was brewing. The drop in air pressure made it uncertain if her bread would rise. Don't be afraid to fiddle with your recipe and adjust the amount of flour or kind of flour you use. Also have all ingredients at room temperature, for any recipe. Try various amounts of oil, water, an egg added, even if the recipe doesn't ask for one..! It is your bread and you get to eat it, it should be as you like it. The first adjustment is less time. Pull the plug early. Second would be the margarine. Third is play with the contents and adjust. Feed the birds the NOPES. Last reduce the amount of flour, but only by 3 tbsp at a time. This is the trick-y-est. Keep track on a paper and then re-write YOUR RECIPE on the inside front cover of your bread book.
Nov 20, 2008 | Black & Decker B2300 Bread Machine
Hard crust
Do you take it out right away?  If you let it rest in the machine for about an hour the crust stays soft as the bread sucks back in the moisture it gave off during baking.  Doing this does not make the bread soggy.  It's just physics.  If you take the bread out immediately the heat (+moisture) will be drawn out and diffused into the cooler environment.  Hope this helps.
Oct 17, 2008 | Sunbeam 5891 Bread Maker
Bread is getting to done
sounds like fulty heat sensor timer out of wwack bestthing now to do is just watch bread pull it out when brown golden dont wait for rely on timer any more would be hard to get its parts brain to itto fix it ok so best bet is watch it
Feb 10, 2008 | Toastmaster 1147 Bread Maker
Kitchen Appliances - Others Logo
313 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Oscar Netto
Oscar Netto
Mohamed Ismail
Mohamed Ismail
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
