Question about HP Photosmart C6180 All-In-One InkJet Printer
Ox19a0023 Ink system failure but cartridges are new. Help
  • 105 Answers
SOURCE: HP Photosmart C7280 Ink System Failure
Hello rjjgraphics.
This is a serious hardware issue in the unit and in most cases , the unit needs to be replaced, so there is a less chance of the issue getting resolved.
Thx
All the best
Posted on Oct 09, 2008
  • 107 Answers
SOURCE: ink system failure - printer documentation error 0xc18a0105
Okay basically you either need a firmware update or you have air in your lines. If your unit is in warranty call HP for an exchange. If not the your kind of in a pickle. It will cost you to get the firmware update and there really isnt much to do for ISF. I do not have a purge command for that model. I am sorry.
Posted on Dec 09, 2008
  • 54 Answers
SOURCE: Oxc19a0023 INK System failure
Issue: An Ink system failure message and error code appears on the printer display.
Solution:
Step one: Reset the printer
Press the On button to turn off the printer.
Unplug the power cord and universal serial bus (USB) cable from the back of the printer.
Wait 30 seconds.
Plug the power cord back into the printer.
Press the On button to turn the printer on.
If Ink system failure does not display, the issue is resolved; reconnect the USB cable and resume using the printer.
If the previous steps have not cleared the message, continue to the next step.
Step two: Download and install firmware update
Go to the product support page to download the update.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=443024&lc=en&cc=us&dlc=en&lang=en&cc=us
Click on the appropriate operating system link.
Click on the Recommended update to fix long power-on cycle and ink system failures link and follow the instructions to download the file.
After downloading is complete, disconnect all other USB devices from the PC. Make sure the product is powered ON and plugged into the USB port.
With the printer directly connected to the PC, click the downloaded file FirmwareEnable_Release.EXE.
Click Open/Run.
Click OK at the Update successful window. The error should have been cleared from the printer display.
If you get a message saying a device was not detected, make sure the printer is powered ON and the USB cable is connected to both the printer and PC and try step five again. Source(s): Full instructions found on...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00719450&cc=us&lc=en&dlc=en&product=443024&dlc=en&lang=en
Posted on Apr 09, 2009
  • 84 Answers
SOURCE: Ink System Failure on a HP Photosmart C6280 All-in One
This is likely a cartridge problem except if the carriage is not moving at all. If you still have some of the used cartridges you can used them to trouble shoot by elimination ok. Or contact a nearby technician who has the cartriges to use them for trouble shooting. I strongly believe the one of the print carts is the culprit. Good luck
Posted on Jun 02, 2009
SOURCE: Ink System Failure Series C7280 Error 0xc18a0001
Reset the printer. Thanks.
Posted on Jun 14, 2009
Ink system failure
Plz provide the exact error message
Mar 22, 2014 | HP Photosmart C6180 All-In-One InkJet...
I am getting a error message saying the printer does not have enough ink to ensure printer health. The empty ink cartridge must be replaced to resume printing. I replaced the cartridges and it does not...
These printers have been known to have ink system failure errors. This message can also be caused by using compatible or re-manufactured cartridges. We believe the HP Live update software is also responsible for "dobbing" on you if you use any other brand.
A Fix for the ink system failure can be found below Not sure if it will help with your particular error but it wont hurt to try.
http://fix-your-printer.blogspot.com/2009/03/ink-system-failure-on-hp-photosmart.html
Good luck
Apr 14, 2011 | HP Photosmart C6180 All-In-One InkJet...
0xc18a0401 ink system failure error on hp C6180 printer
Check out this link.
http://www.out-of-warranty.com/ink-system-failure-error-0xc18a-hp/
Apr 28, 2010 | HP Photosmart C6180 All-In-One InkJet...
Printer is showing ink system failure. what does this mean? how can it be fixed?do we just need to replace all of the ink cartridges? help!
Ink system failure indicated that ink delivery mechanism of the printer is experiencing problem. We need to do below resets for this printer to fix this issue.
Solution 1:
  • Press the On button to turn of the printer.
  • Unplug the power cord from the back of the printer and from wall outlet or surge protector.
  • Removed all the ink cartridges
  • Wait for 2 minutes
  • Connect the power cord and turn the printer On.
  • Install the ink cartridges
(Please go to solution 2 if the problem is not resolved)
Solution 2:
  • Remove all the ink cartridges.
  • While the printer is ON, unplug the power cord from the back of the printer.
  • Press and hold OK and Cancel button, while holding these buttons connect the power cord.
  • Release the button after 20 seconds.
  • Turn on the printer if it goes off and install the cartridges.
Regards
Riztech
Mar 04, 2010 | HP Photosmart 3210 Printer
Hp photosmart c7250 ink system failure
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 03, 2010 | HP Photosmart C7250 All-In-One Thermal...
Have a hp 3310 it says ink system failure error 0xc18a0106 it wont print,scan,copy and it does have enough ink. thank 4 ur help
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, press the on button, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't clear the error then you may need to re-prime ink through the system to clear the error. There are good instructions for doing this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Feb 20, 2010 | HP Photosmart 3310 All-In-One InkJet...
HPC8180 Did not follow intitial instructions and now have ink system failure. Hp unable to help sent me brand new ink cartridges, I tried to reset with no success. Any help?
Follow the instructions on this web page http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/ to prime ink through the lines and hopefully clear the error. I don't know why HP sent you new ink cartridges when it should be obvious to them that the cartridges are not the problem.
Nov 25, 2009 | HP Photosmart C8180 InkJet Printer
C5180 not printing red.
replace the ink cartridges as the ink might have finished in refill of its cartridges
Jul 22, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Ink system failure
The problem you have is caused by air in the ink feed tubes. We have a step by step reset posted on our web site at:
www.ccl-la.com/hp.htm
This should get you up and going.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 17, 2009 | HP Photosmart C7280 Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
85 people viewed this question
Seeker5211
Seeker5211
