Question about Nordic Track Exercise & Fitness
My Nordictrack 9800 incline trainer walking belt won't turn, console says it is but isn't
Controller "pwc" light blinking...."tach" light lit, "9volt" lit
  • 14 Answers
SOURCE: nordictrack apex4100i level incline will not work
Try this calibration procedure.
Turn the power switch on. Remove the safety key. Hold the Stop and Speed Up or Speed Plus buttons down then insert the safety key.
The display should show some numbers.
Press the stop key one time and the display should show some other numbers and some 00's. Press the Incline Up button and see if the Incline begins to move, if it does let it go all the way up and then all the way down, wait a few seconds after it stops, then hit the stop key 4 times. It should be calibrated. If it didn't move then the board or the incline motor is bad.
Posted on Jul 08, 2009
  • 103 Answers
SOURCE: I NEED THE NORDICTRACK 9600 INCLINE TRAINER TREADMILL SCHEMATIC
contact me @ swflafitnessrepair@yahoo.com I will send this to you.
Posted on Nov 13, 2009
SOURCE: I have a NordicTrack A2250, about 2 years old.
Will the treadmill work when the chip is not plugged in, or does it just beep every time you select a button? If so, your problem is easy to solve. The board that supports the two adjacent up and down buttons has slipped. To fix, you'll need to remove the panel and remove the 3-inch retaining bar which is held in my two screws. Realign the board so the buttons are free to move in the available slots. Good luck.
Posted on Dec 19, 2009
outfield502
  • 79 Answers
SOURCE: Nordictrack Model A2550: Incline function!!??
this function is to give a little more intensity exercise, while helping to raise the heart rate and thus burn fat. watch it more practical as a stress test.can use the runner at a speed of 3.5 mph and an elevation of 7.5 of inclination and see good results
Posted on Feb 09, 2010
  • 34 Answers
SOURCE: will my ifit treadmill card work in an incline
Technically, the Incline Trainer and the treadmill are two different type of machines. The incline trainer raises much higher so the card that is designed for the treadmill will not work on the incline trainer unfortunately.
Posted on May 24, 2010
Keypad doesn work
the red light should only blink when it is running. does the incline work? if nothing works most likely a console issue
Aug 11, 2014 | Proform XP 580 Trainer Treadmill
Consol on nordictrack T9.1 has error code 58 when I switch it on then it goes in to a loop of the preset programs but you can't select them
follow this steps and fix it. God bless you
Step 1
Plug the power cord into a UL 1449 single-outlet surge suppressor and then plug the surge suppressor into an electrical outlet that is not GFCI-equipped if the power does not turn on. If the treadmill is plugged in and the power still does not work, make sure the key is in the console and that the Reset/Off circuit breaker has not been tripped. Press the switch to "Reset" if it has been tripped.
Sponsored Links
Gym Equipment Choose from 1M+ Verified Suppliers. Contact Directly & Get Live Quotes! www.alibaba.com/Gym-Equipment
Step 2
Check the Reset/Off circuit breaker if the power switches off while in use. Wait five minutes and switch the button to reset. Check that the power cord is still plugged in securely; pull the plug out and plug it back in after five minutes. Pull out the console key and reinsert to see if the machine will turn back on.
Step 3
Place the chest pulse sensor tightly right underneath your pectoral muscles or breasts for it to operate properly. Position it lower or higher on your chest if it does not work properly. Wet the electrodes with a saline solution. Walk near the walking belt's center within an arm's reach of the console.
Step 4
Remove the console key and unplug the treadmill to loosen the walking belt if it slows when in use. Turn the rear roller bolts counterclockwise with the hex key 1/4 of a turn until you can lift the walking belt's edges 3 to 4 inches from the platform.
Step 5
Remove the key and unplug the treadmill to adjust the walking belt if it is off-center or slips when in use. Loosen the rear roller bolts with the hex key and reposition the walking belt. Tighten the roller bolts. Walk on the treadmill to determine if the walking belt is centered. If not, loosen the roller bolts again and make adjustments until the walking belt is centered.
Step 6
Recalibrate the incline system if the treadmill's incline does not adjust correctly. Press the "Incline" button and remove the console key. Wait a few seconds and replace the console key. The incline will automatically recalibrate by moving to the maximum incline level and then the minimum level.
Step 7
Press the "Stop" button for a few seconds to turn off the demo mode if the console display stays lit after you remove the console key.
Oct 03, 2013 | Nordic Track Exercise & Fitness
I have the 1750 Commercial Treadmill and the screen is "froze" on the program for the sd card or WiFi. When I push on the stop button or unplug and replug in the power it still is STUCK on that screen. ...
use this steps and fix it. God bless you
Step 1
Sponsored Links
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Read more: http://www.livestrong.com/article/241157-nordic-track-treadmill-troubleshooting/#ixzz2geWlKdPR
Oct 02, 2013 | Nordic Track NordicTrack COMMERCIAL 1750...
I just bought a Nordic Track X9i incline trainer. Started working well, however after a few hours of use I cannot use any control keys and belt and incline does not work. The touch screen display works but...
You should immediately replace the console. That console will just keep getting worse. This is endemic of this brand, however it usually happens a lot further in the life of the unit. When you call Nordictrack have your model number.
Aug 11, 2013 | Nordic Track Incline Trainer X9i...
My NordicTrack T5zi Walking Belt Treadmill won't
Very likely your console went out. I usually check for voltage running to the console (the wires in the back) and if it has juice but will not come on, I replace the console. As far as "why", usually it is power fluctuations, it can be as simple as turning on a high-amperage piece of equipment, or running too many electronics on the same circuit. I see consoles go out from low voltage more often than high voltage.
Nordictrack is an Icon product, you can download the product manual and parts diagrams at iconservice.com.
Feb 02, 2013 | Exercise & Fitness
How to troubleshoot Nordic Track X7i Console not turning on
In normal operation you put in the key and display should light up. Also there is a reset switch on the frame near the power chord which might be off. Below is link to the User Manual for NordicTrack x7i. I got that info on pg 16.
http://www.sportsmith.net/images/product_support%5CNordicTrack%5C248194%20-%20NORDICTRACK%20INCLN%20TRAINER%20X7I%20INTERA%20TREADMILL%5CNTL20909.3-299073.pdf
Jun 19, 2012 | Nordic Track Incline Trainer X7i...
Incline reads 0.0 but is not all the way down
Renee, Here is how to recalibrate the incline motor. Read all of it It will be good to keep.
Plug in your treadmill, do not stand on the walking belt. Hold down the "Stop" and "Speed +" key and insert the safety key or magnet, let go of the two keys. Now press "Stop" key once. This puts you into the level 2 of calibration. Press the "Speed +" key slowly until you see 85 on the console, (at this point the display is going to show the percentage of motor usage and also the actual walking belt speed) at 85% motor usage your top speed should be between 10 and 10.5 MPH or (of 12 and 12.5) depending on the treadmill. You must know your treadmills top speed. (Important the motor may be damaged if you set the maximum speed higher than the maximum speed that your treadmill is made for). If the speed is higher than 10.5 or 12.5 then you need to turn the potentiometer down to the correct level. If the speed it to low you need to turn the potentiometer higher. Once the speed is correct you are done calibrating the speed. Press the (-) speed key to lower the percentage to (0). Next press the incline (+) button, this will make the incline motor go all the way to the maximum incline and come all the way down to the level position. Then remove the safety key and the treadmill will reset into the normal manual mode, when you re-insert the safety key. Matt
Dec 04, 2011 | Nordic Track NordicTrack Treadmill, A2550
My nordictrack is stuck on a program &wont let u do anything else..cant change the speed or incline &the fans wont turn on..its like the consol is frozen or stuck on a program..how can i reset it...
How to Troubleshoot a Nordic Track C2500 X15616db0-ef56-4f0a-afbd-b1ae3379f47f.small.jpg Jolie Johnson
Based in Austin, Texas, Jolie Johnson has been in the fitness industry for over 12 years and has been writing fitness-related articles since 2008 for various websites. She received her Bachelor of Arts in English and philosophy from the University of Illinois.
By Jolie Johnson, eHow Contributor
updated April 15, 2011
Related Searches:
The NordicTrack is a treadmill designed for in-home use. It offers a speed range of 0 to 10 mph and an incline range of 0 to 10 percent. It folds up vertically to save space when you aren't working out and can be rolled to a different room. The console has 16 preset workout programs and features iFit interactive technology. If you have problems with the console or walking belt, you can often fix them yourself with some basic troubleshooting steps
Instructions
  1. Power Turns Off When You're Using the Treadmill
    • 1 Check the reset switch on the bottom of the treadmill near the power cord. If it has tripped, the top of the switch will protrude. Wait 5 minutes then press the switch.
    • 2 Check that the power cord is plugged in completely. If it is plugged in, unplug it, wait 5 minutes then plug it back in.
    • 3 Remove the magnetic key from the console then reinsert it.
    The Console Won't Turn Off
    • 1 Insert the magnetic key into the console. Your C2500 is stuck in demo mode if the console won't turn off after you remove the magnetic key from the console.
    • 2 Hold the "Stop" button down for a few seconds.
    • 3 Press the "Speed" down (-) button. Remove the magnetic key.
    The Incline Does Not Change Correctly
    • 1 Press and hold the "Stop" and the "Speed" up (+) button. While holding the buttons, insert the key into the console, then release the buttons.
    • 2 Press either the "Incline" up or down arrow button. Wait while the incline raises and lowers. This recalibrates the incline system.
    • 3 Remove the key from the console.
    Walking Belt Slows
    • 1 Unplug your C2500 and remove the key from the console.
    • 2 Turn both rear adjustment bolts, located on the back of the walking deck, to the left, a 1/4 turn.
    • 3 Lift the edge of the walking belt in the middle of the deck. You should be able to lift it 2 to 3 inches off the walking platform. If the belt is still too tight, loosen the bolts another 1/4 turn each.
    • 4 Plug the treadmill in and reinsert the console key. Walk on the belt at a slow speed to see if it still slows. Repeat Step 2 if necessary.
Sep 27, 2011 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
285 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
